Page 3 of 49 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 729
Thread: Asus RT-N66U
    Thumbs up Asus RT-N66U
    Quote Originally Posted by bmenee View Post
    Comex закончился вчера... "somewhere after Comex"
    Стенд ASUS на выставке ...
    Найдите 10 отличий ... Это чудо больше похоже на RT-N56U с внешними антеннами ...
    Ну а это и есть ASUS RT-N66U Dark Knight Double 450Mbps Dual N Band Router ...
    Asus RT-N66U
    Asus RT-N66U должен появиться в продаже уже в ноябре ...
    Hardware Features
    Chipset - Broadcom BCM4706 (600 MHz)
    Memory - 256 MB RAM / 32 MB Flash (+ mircoSD slot for upgrading)
    WAN - 1x Gigabit Ethernet or 3G/4G USB flash drive & 4x LAN - Gigabit Ethernet
    USB port - 2x USB2.0 USB port for external hard drive, printer, 3G/4G stick supports up to 3A
    Antenna - 3x3 External & internal antennas for 2.4 G & 5GHz
    Active cooling - fan with decent automatic control
    Switch - On/Off, Reset and WPS
    Dimensions - 350 x 270 x 150 mm
    Wireless Features
    2.4GHz & 5GHz frequencies simultaneous data rate of
    • 802.11n (2.4/5GHz): Up to 450 Mbits per band
    • 802.11a / g: Up to 54 Mbits
    • 802.11b: Up to 11 Mbits
    Individually selectable user output
    • 802.11g: 17 ~ 21 dBm
    • 802.11a / g: 17 ~ 21 dBm
    • 802.11b: Up to 23 dBm
    Supports 64/128-bit WEP encryption, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
    Authentication - Wi-Fi Protected Setup (WPS & PIN)
    Software Features
    Network Protocols - Automatic IP, Static IP, PPPoE (MPPE supported), PPTP, L2TP, IPv4, IPv6
    DynDNS - ASUS DDNS Dynamic DNS, DynDNS, TZO, ZoneEdit
    Firewall - NAT and SPI firewall, intrusion detection, DoS protection, port filtering, MAC filtering
    Scheduled - WLAN access control module, MAC filtering, network service filter, URL filter
    Management
    • Web-based administration traffic monitor
    • Performance tuning
    • Telnet Server
    • System Log
    Mode - router or access point
    Downloadmaster - supports BT, NZB, HTTP, FTP downloads
    • Supports encryption, DHT, PEX and Magnet Link
    • Upload and download bandwidth control
    • Download scheduling
    DLNA server
    • Images: JPEG
    • Audio: MP3, WMA, WAV, PCM, MP4, LPCM, OGG
    • Video: ASF, AVI, DIVX, MP2P, MPEG, MPG, TS, VOB, WMV, MKV, MOV
    Print server - support multi-function devices, printers and scanners
    File Server - FTP Server & Samba server with account management
    VPN server PPTP VPN server
    Guest Network - Up to 3 guests per frequency band networks with time-controlled access control
    Other - Wall Bracket
    http://wl500g.info/attachment.php?at...3&d=1316705935
    http://wl500g.info/showpost.php?p=237755&postcount=51
    Question Asus RT-N
    Quote Originally Posted by harsh132 View Post
    Уж лучше бы какой нибудь N57-N59 на дуальном бродкоме с гигабитными портами сваяли
    http://wl500g.info/showpost.php?p=237380&postcount=22
    RT-N66U сваян
    Планируется ли для него прошивка от энтузиастов ?
    Ну и вот тут ещё кое-что новенькое намечалось ...
    WLAN Router/Access Point Roadmap
    • RT-N66U - BCM4706, 3*3, 450Mbps, DB CC, GbE, 2*USB, MP in Aug
    • RT-N56U - RT3662F, 2*3, 300 Mbps, DB CC, MP in Feb.
    • RT-N53 - BCM5358, 2*2, 300Mbps, DB CC, FE, MP in Aug
    • RT-N37U (N57U) - ?, 2*3, GbE
    • RT-N36 (N76U) - ?, 2*2, GbE
    • RT-N16 B1 - BCM 47186, 2*3, GbE, 2*USB, MP in Aug
    • RT-N16 - BCM4718, 2*3, GbE, 2*USB
    • RT-N15U - BCM 47186, 2*2, GbE, 1*USB, MP in Oct
    • RT-N13U B1 - RT3052F, 2*2, 1*USB, 3.5G
    • RT-N12 B1 - BCM 5357, 2*2, MP in Aug
    • RT-N12 - BCM4716, 2*2, @3Cems
    • RT-N10+ B1 - RT3050F, 1*1, 150Mbps
    • RT-N10U - BCM?, 1*1, 150Mbps, MP in Aug
    • RT-N10 - BCM5356, 1*1, 150Mbps
    Wireless Router
    1x1
    • RT-N10
    • RT-N11
    2x2, FE
    • RT-N12
    • RT-N13
    • RT-N53
    2x2, 2x3, Gigabit
    • RT-N15
    • RT-N16
    • RT-N36
    • RT-N37U
    • RT-N56U
    3x3, Gigabit
    • RT-N66U
    Маршрутизаторы Asus с прошивкой "от энтузиастов"
    http://code.google.com/p/wl500g/wiki/Devices
    http://en.wikipedia.org/wiki/Asus_Routers
    Nov 2006
    Планируется, но всё будет сильно зависить от Broadcom SDK. BCM5357/BCM5358 поддерживается только начиная с SDK 5.60 (уже доступен и планируем миграцию), BCM4706 поддерживается вроде только SDK 5.100 (GPL от ASUS пока еще нет), а про BCM47186 информации нет совсем.
    "Chipset - Broadcom BCM4706 (600 MHz)
    Dimensions - 350 x 270 x 150 mm"
    Перестали пугать чудовищными размерами памяти,
    но
    начали пугать чудовищными размерами самого девайса
    На лампах однако...
    Quote Originally Posted by ArCan View Post
    но
    На лампах однако...
    визуально - компактнее N16-го, как по длине, так и по тощине
    Кажется по указанным размерам явная ошибка
    или раутер всё-таки может быть размером с дипломат?
    Хотя это не так и важно.
    Важнее цена и ещё важнее КОГДА?
    Устал ждать.
    Хотя инво по цене и датам вроде проклёвывается,
    например
    http://www.pccanada.com/viewitem.asp?id=35647
    http://www.broadbandbuyer.co.uk/Shop...roductID=11867
    ну ооочень занятный зверек. все замечательно, непонятно след. вещи:
    1. будет ли на него альтернативная прошивка
    2. какая реальная скорость usb порта
    3. ну и ест-но какая у него будет цена....
    RT-N66U Tomato Firmware 1.28.0000 MIPSR2-109 K26 USB AIO-64K
    WL-500W: 1.9.2.7-d-r2624 + huawei 353 - дачный интернет
    Пардон если ссылочка была, но вот что встрелил в сети
    http://klseet.com/index.php?option=c...114&Itemid=105
    соответсвенно оттуда
    Странно как-то расположен расположен слот для флешки. Его что разбирать надо будет, чтобы microSD воткнуть??? Как на это дело посмотрит гарантия?
    А так же учитывая отсутствие необходимости экономить каждый миллиметр(в отличие от мобильников), странно видеть microSD, а не полноразмерный разъем.
    Apr 2008
    город самоваров и пряников
    Да уж... Взяли и вентилятор засунули Что ж теперь, роутер на ночь выключать придётся, чтоб шум не слышать?
    Для расширения чего нужна флешка micro-sd, для optware?
    Самое фиговое, что вентилятор мелкий. Шумный очень может быть. Засунули бы большой...
    Omega, а в чем разница между RT-N66U в корпусе от RT-N16 (только черном и раскрашеном) вот отсюда и RT-N66U в корпусе от RT-N56U вот отсюда?
    Quote Originally Posted by Basile View Post
    Ну, похоже, что только в дизайне и кол-ве оперативной памяти ...
    В ROG версии роутера память может быть расширена до 1 GB ...
    З.Ы. Насчет кулера - можно будет регулировать обороты и порог ...
    Сдается мне скоро буду продавать свой N56
  1. Asus RT-N66U/AC56U/AC66U/AC68U и USB-модемы 4G/3G/CDMA
    By sugrey in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 28-07-2017, 10:06
  2. Моддинг системы охлаждения роутера Asus RT-N66U/AC66U/AC68U
    Last Post: 31-08-2016, 11:05
  3. Asus RT-N66U - восстановление прошивки
    Last Post: 24-02-2015, 19:03
  4. New Asus RT-N66U Router
    By hggomes in forum English Discussion
    Last Post: 02-07-2013, 19:29
  5. Всё про Asus RT-N66U
    Last Post: 22-06-2012, 20:53
