Page 5 of 17 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 242
Thread: Firmware v1.9.2.7 CR6, updated to CR6a ... now CR6b [Oleg]
  1. #61
    Sep 2004
    Ok, try new version - http://wl500g.dyndns.org/1.9.2.7-6a.2/ - seems to be working now.
    Thank You !!
    everything is ok now! You made my day!
  2. #62
    WL500g-1.9.2.7-6a & connect time
    Hi Oleg & Forum!
    I update my router the new firmware (v1927-6a), and I see in log the connect time is wrong:
    ..."Jan 1 01:00:15 PPPoE: connect to ISP
    Jun 21 17:05:54 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 21 19:05:56 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 21 21:06:02 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 21 23:06:08 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 22 01:06:14 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 22 03:06:21 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 22 05:06:27 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 22 07:06:34 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 22 09:06:41 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 22 11:06:48 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 22 13:06:55 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 22 15:07:02 ntp client: Synchronizing time with time.kfki.hu ...
    Jun 22 17:05:32 pppd[76]: LCP terminated by peer
    Jun 22 17:05:33 dnsmasq[50]: read /etc/hosts - 5 addresses
    Jun 22 17:05:33 dnsmasq[50]: reading /tmp/resolv.conf
    Jun 22 17:05:33 dnsmasq[50]: using nameserver 82.144.161.11#53
    Jun 22 17:05:33 PPPoE: Disconnected
    Jun 22 17:05:33 pppd[76]: Child process /tmp/ppp/ip-down (pid 271) terminated with signal 11
    Jun 22 17:05:36 pppd[76]: Connection terminated.
    Jun 22 17:05:36 pppd[76]: Connect time 18657545.4 minutes.
    Jun 22 17:05:36 pppd[76]: Sent 1041850587 bytes, received 605807933 bytes. "
    - Why calculate the routine this giant number?
    Sorry for my wrong english, and THX the quality firmwares, good work Oleg!
    Zitev
  3. #63
    Quote Originally Posted by Zitev
    This is due to time wrap, caused by ntp. Ignore this.
  4. #64
    New testing firmware available for wl500g owners. This one has reworked (one again) WAN port dies workaround - http://oleg.wl500g.info/WL500g-1.9.2.7-6a.3.trx
    Everyone affected with this issue and experienced reboots/locks/disconnects/ping problems should try it.
    macsat: try with emule
    int, jbk: try using it
    catdog: try fix speed set to auto
    guch79: check for wan port dies
    AiKoiN: try this firmware
  5. #65
    Oct 2004
    Portugal
    Test...
    Home Page
    Marco Sousa from PORTUGAL
  6. #66
    Dec 2004
    Frankfurt / Germnay
    Running for 9 hours - no reboot - seems fine for me....
    ciao,
    JBK
  7. #67
    Oct 2004
    Portugal
    Reset problem: Fixed
    When i have test ftp server and samba, and the WL make one "restore default / reset"
    Home Page
  8. #68
    Samba interfaces
    I have discovered, that samba is now binding to all interfaces. 1.9.2.7-5a did binding only on LAN, but now it tries to find browsers even on WAN.
    I thing all users who care should add following to /etc/smb.conf:
    interfaces = br0
    bind interfaces only = yes
  9. #69
    Nov 2004
    Portugal
    Reply:
    Since i switched to 1.9.2.7.6a.2 and put the "WAN Connection Speed:" = 10Mbs half duplex, my wl500g never crashed/reboot/reset again. If i put in "auto" i will have problems again and the internet connection will be very slow.
    Should i switch to 1.9.2.7.6a.3 to see if it works fine or should i stay in 1.9.2.7.6a.2?
    Using WL500g - firmware 1.9.2.7-7e [from Oleg's]
  10. #70
    Hi Oleg,
    there is a problem with WL-HDD and firmware 6a.2 and ethernet speed set to AUTO. I cannot stream to harddisk without errors or dropouts because network speed seems to be slow. Configuration is unchanged.
    If i set ethernet speed to 10 half everything seems to be ok.
  11. #71
    Hello Oleg,
    there is a problem with connection, ''firmware 6a.2'' , dropouts evry 15-20min. I`m back to 1.9.2.7-5a , WL500g runing 24/7 without any problems.
  12. #72
    WDS not working with 6a.2 and 6a.3
    Tried with WPA-PSK and TKIP. But it does not work.
  13. #73
    Dec 2004
    Frankfurt / Germnay
    Smile TOP 1.9.2.7.6a.3
    Trying 1.9.2.7.6a.3 since 2 days with wds and heavy upnp mediaserver traffic. No reconnects until now - after problems with the other releases of 1.9.2.7.6xxx this is the first real stable version for me....
    ciao,
    JBK
  14. #74
    Unhappy Back to cr5a! 6a1,2and3 not working?
    I went back to version cr5a after having problems with wireless connection
    loss and dropouts with cr6.1 and cr6.2, then in version cr6.3 I had no wan connection at all, I`m using adsl pppoe. cr5a seems the most reliable for now.
    regards jelly
  15. #75
    Quote Originally Posted by jbkerner
    ciao,
    JBK
    Are you using WDS with WPA-PSK and TKIP or AES?
    If so, can you please post your settings?
    Thanks,
  1. Firmware v1.9.2.7 CR5, updated: v1.9.2.7 CR5a [Oleg]
    Last Post: 18-06-2005, 12:07
  2. Firmware v1.8.1.7 CR2 [Oleg] - updated ( CR2a )
    Last Post: 08-12-2004, 10:01
  3. Firmware v1.7.5.6 CR3 [Oleg]
    Last Post: 28-07-2004, 21:11
  4. Firmware v1.7.5.6 CR4 [Oleg]
    Last Post: 30-05-2004, 15:56
    Last Post: 07-04-2004, 17:22
