Originally Posted by
yeager
cpu probe
prom init
cpu report
CPU revision is: 00024000
Loading BCM4710 MMU routines.
Primary instruction cache 8kb, linesize 16 bytes (2 ways)
Primary data cache 4kb, linesize 16 bytes (2 ways)
Linux version 2.4.20 (root@omnibook) (gcc version 3.2.3 with Broadcom modifications) #9 Thu May 26 23:29:45 MSD 2005
Setting the PFC value as 0x15
Determined physical RAM map:
memory: 01000000 @ 00000000 (usable)
On node 0 totalpages: 4096
zone(0): 4096 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc console=ttyS0,115200
CPU: BCM4710 rev 0 at 125 MHz
!unable to setup serial console!
Calibrating delay loop... 82.94 BogoMIPS
Memory: 13868k/16384k available (1767k kernel code, 2516k reserved, 248k data, 72k init, 0k highmem)
Dentry cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode cache hash table entries: 1024 (order: 1, 8192 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
Checking for 'wait' instruction... unavailable.
POSIX conformance testing by UNIFIX
PCI: Fixing up bus 0
PCI: Fixing up bridge
PCI: Fixing up bus 1
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Journalled Block Device driver loaded
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
NTFS driver v1.1.22 [Flags: R/O]
pty: 256 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
loop: loaded (max 8 devices)
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
MPPE/MPPC encryption/compression module registered
Amd/Fujitsu Extended Query Table v1.1 at 0x0040
Physically mapped flash: Swapping erase regions for broken CFI table.
number of CFI chips: 1
Flash device: 0x400000 at 0x1fc00000
Physically mapped flash: squashfs filesystem found at block 942
Creating 5 MTD partitions on "Physically mapped flash":
0x00000000-0x00040000 : "pmon"
0x00040000-0x003e0000 : "linux"
0x000eba00-0x003e0000 : "rootfs"
0x003f0000-0x00400000 : "nvram"
0x003e0000-0x003f0000 : "config"
sflash: chipcommon not found
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
ip_conntrack version 2.1 (128 buckets, 1024 max) - 344 bytes per conntrack
ip_conntrack_pptp version 1.9 loaded
ip_nat_pptp version 1.5 loaded
ip_tables: (C) 2000-2002 Netfilter core team
ipt_time loading
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
IPv6 v0.8 for NET4.0
IPv6 over IPv4 tunneling driver
NET4: Ethernet Bridge 008 for NET4.0
802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
FAT: bogus logical sector size 13056
NTFS: Unable to set blocksize 512.
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 72k freed
Warning: unable to open an initial console.
Algorithmics/MIPS FPU Emulator v1.5
eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.7.0
eth1: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.7.0
PCI: Enabling device 01:02.0 (0004 -> 0006)
eth2: Broadcom BCM4301 802.11 Wireless Controller 3.90.23.0
device eth1 entered promiscuous mode
device eth0 entered promiscuous mode
br0: port 2(eth0) entering listening state
br0: port 1(eth1) entering listening state
br0: port 2(eth0) entering learning state
br0: port 1(eth1) entering learning state
br0: port 2(eth0) entering forwarding state
br0: topology change detected, propagating
br0: port 1(eth1) entering forwarding state
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb-ohci.c: USB OHCI at membase 0xb8004000, IRQ 2
usb-ohci.c: usb-00:04.0, PCI device 14e4:4715
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 2 ports detected
hub.c: new USB device 00:04.0-1, assigned address 2
usb.c: USB device 2 (vend/prod 0x4e8/0x100) is not claimed by any active driver.
lp0: using parport0 (polling).
usb.c: registered new driver usblp
printer.c: v0.13: USB Printer Device Class driver
usb.c: registered new driver audio
audio.c: v1.0.0:USB Audio Class driver
Linux video capture interface: v1.00
SCSI subsystem driver Revision: 1.00
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
scsi0 : SCSI emulation for USB Mass Storage devices
usb.c: USB disconnect on device 00:04.0-1 address 2
eth1: no IPv6 routers present
eth0: no IPv6 routers present
br0: no IPv6 routers present
hub.c: Cannot enable port 1 of hub 1, disabling port.
hub.c: Maybe the USB cable is bad?
usb_control/bulk_msg: timeout
usb-ohci.c: unlink URB timeout
