Jan 1 03:00:35 kernel: hub.c: new USB device 00:03.1-1, assigned address 6
Jan 1 03:00:36 kernel: scsi2 : SCSI emulation for USB Mass Storage devices
Jan 1 03:00:36 kernel: Vendor: ZTE Model: USB SCSI CD-ROM Rev: 2.31
Jan 1 03:00:36 kernel: Type: CD-ROM ANSI SCSI revision: 02
Jan 1 03:00:36 kernel: USB device disconnected from the SCSI subsystem
Jan 1 03:00:36 kernel: usbdevfs: process 130 (usb_modeswitch) did not claim interface 0 before use
Jan 1 03:00:41 kernel: usb.c: USB disconnect on device 00:03.1-1 address 6
Jan 1 03:00:46 kernel: hub.c: new USB device 00:03.1-1, assigned address 7
Jan 1 03:00:47 kernel: Vendor: ZTE Model: MMC Storage Rev: 2.31
Jan 1 03:00:47 kernel: Type: Direct-Access ANSI SCSI revision: 02
Jan 1 03:00:47 kernel: Attached scsi removable disk sda at scsi1, channel 0, id 0, lun 0
Jan 1 03:00:47 kernel: sda: Waiting for disc 0 to settle.
Jan 1 03:00:49 kernel: sda: Unit Not Ready, sense:
Jan 1 03:00:49 kernel: Info fld=0x0, Current 00:00: sns = f0 2
Jan 1 03:00:49 kernel: ASC=3a ASCQ= 0
Jan 1 03:00:49 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
Jan 1 03:00:49 dnsmasq-dhcp[72]: DHCPINFORM(br0) 192.168.1.170 00:19:66:76:b2:27
Jan 1 03:00:49 dnsmasq-dhcp[72]: DHCPACK(br0) 192.168.1.170 00:19:66:76:b2:27
Jan 1 03:00:50 kernel: sda : READ CAPACITY failed.
Jan 1 03:00:50 kernel: sda : status = 1, message = 00, host = 0, driver = 08
Jan 1 03:00:50 kernel: Info fld=0x0, Current sd00:00: sns = f0 2
Jan 1 03:00:50 kernel: ASC=3a ASCQ= 0
Jan 1 03:00:50 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
Jan 1 03:00:50 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
Jan 1 03:00:50 kernel: /dev/scsi/host1/bus0/target0/lun0: I/O error: dev 08:00, sector 0
Jan 1 03:00:50 kernel: I/O error: dev 08:00, sector 0
Jan 1 03:00:50 kernel: unable to read partition table
Jan 1 03:00:50 kernel: USB device connected to the SCSI subsystem
Jan 1 03:00:50 kernel: usb.c: registered new driver serial
Jan 1 03:00:50 kernel: usbserial.c: USB Serial support registered for Generic
Jan 1 03:00:50 kernel: usbserial.c: USB Serial Driver core v1.4
Jan 1 03:00:50 kernel: usbserial.c: USB Serial support registered for Option GSM modem
Jan 1 03:00:50 kernel: usbserial.c: Option GSM modem converter detected
Jan 1 03:00:50 kernel: usbserial.c: Option GSM modem converter now attached to ttyUSB0 (or usb/tts/0 for devfs)
Jan 1 03:00:50 kernel: usbserial.c: Option GSM modem converter now attached to ttyUSB1 (or usb/tts/1 for devfs)
Jan 1 03:00:50 kernel: usbserial.c: Option GSM modem converter now attached to ttyUSB2 (or usb/tts/2 for devfs)
Jan 1 03:00:50 kernel: option.c: USB Driver for GSM modems: v0.7.2a
Jan 1 03:00:51 kernel: usb.c: registered new driver acm
Jan 1 03:00:51 kernel: acm.c: v0.23:USB Abstract Control Model driver for USB modems and ISDN adapters (patched)
Jan 1 03:00:57 kernel: sda: Waiting for disc 0 to settle.
Jan 1 03:00:59 pppd[203]: pppd 2.4.5 started by admin, uid 0
Jan 1 03:00:59 kernel: sda: Unit Not Ready, sense:
Jan 1 03:00:59 kernel: Info fld=0x0, Current 00:00: sns = f0 2
Jan 1 03:00:59 kernel: ASC=3a ASCQ= 0
Jan 1 03:00:59 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
Jan 1 03:01:00 kernel: sda : READ CAPACITY failed.
Jan 1 03:01:00 kernel: sda : status = 1, message = 00, host = 0, driver = 08
Jan 1 03:01:00 kernel: Info fld=0x0, Current sd00:00: sns = f0 2
Jan 1 03:01:00 kernel: ASC=3a ASCQ= 0
Jan 1 03:01:00 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
Jan 1 03:01:00 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
Jan 1 03:01:00 kernel: sda: Write Protect is off
Jan 1 03:01:00 kernel: /dev/scsi/host1/bus0/target0/lun0: I/O error: dev 08:00, sector 0
Jan 1 03:01:00 kernel: I/O error: dev 08:00, sector 0
Jan 1 03:01:00 kernel: sda: Waiting for disc 0 to settle.
Jan 1 03:01:01 pppd[203]: Serial connection established.
Jan 1 03:01:01 pppd[203]: Using interface ppp0
Jan 1 03:01:01 pppd[203]: Connect: ppp0 <--> /dev/usb/tts/2
Jan 1 03:01:02 kernel: sda: Unit Not Ready, sense:
Jan 1 03:01:02 kernel: Info fld=0x0, Current 00:00: sns = f0 2
Jan 1 03:01:02 kernel: ASC=3a ASCQ= 0
Jan 1 03:01:02 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
Jan 1 03:01:02 pppd[203]: CHAP authentication succeeded
Jan 1 03:01:03 kernel: sda : READ CAPACITY failed.
Jan 1 03:01:03 kernel: sda : status = 1, message = 00, host = 0, driver = 08
Jan 1 03:01:03 kernel: Info fld=0x0, Current sd00:00: sns = f0 2
Jan 1 03:01:03 kernel: ASC=3a ASCQ= 0
Jan 1 03:01:03 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
Jan 1 03:01:03 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
Jan 1 03:01:03 kernel: sda: Write Protect is off
Jan 1 03:01:03 kernel: /dev/scsi/host1/bus0/target0/lun0: I/O error: dev 08:00, sector 0
Jan 1 03:01:03 kernel: I/O error: dev 08:00, sector 0
Jan 1 03:01:03 kernel: unable to read partition table
Jan 1 03:01:03 pppd[203]: Could not determine remote IP address: defaulting to 10.64.64.64
Jan 1 03:01:03 pppd[203]: local IP address 172.20.7.191
Jan 1 03:01:03 pppd[203]: remote IP address 10.64.64.64
Jan 1 03:01:03 pppd[203]: primary DNS address 217.118.66.243
Jan 1 03:01:03 pppd[203]: secondary DNS address 217.118.66.244
Jan 1 03:01:04 dnsmasq[72]: read /etc/hosts - 2 addresses
Jan 1 03:01:04 dnsmasq[72]: using nameserver 217.118.66.244#53
Jan 1 03:01:04 dnsmasq[72]: using nameserver 217.118.66.243#53
Jan 1 03:01:04 3G USB Modem: connected to ISP
