did you ever get it to "see" the printer on the usb ?
Did you try to connect and turn on your printer, and do a :
You should get something like :
Also, you could try to boot your router with your printer connected but NOT turned on.
Then logon using telnet, and execute :
tail -f /tmp/syslog.log
You will now see the last 10 lines of your syslog file, and see any changes to the syslog as they happen.
Now turn on your printer, and check in the telnet session if something happens in the syslog. In my (with a HP PSC950) I get the following when turning on my printer :
Jun 15 09:15:23 kernel: hub.c: new USB device 01:02.0-1, assigned address 2
Jun 15 09:15:23 kernel: printer.c: usblp0: USB Bidirectional printer dev 2 if 0 alt 1 proto 2 vid 0x03F0 pid 0x1E11
Jun 15 09:15:23 kernel: printer.c: usblp0 Device ID string [247]='MFG:Hewlett-Packard;MDL:PSC 900 Series;SKU:PSC 950;CMD:MLC,PCL,PML;CLASS:PRINTER;DESCRIPTION:Hewlett-Packard PSC 900 Series;1284.3M:f7f,f7f;1284.4DL:4d,4e,1;SERN:MY23GD215MWP;VSTATUS:$HB0$NC0,ff,DN,IDLE,CUT,K0,C0,SM,NR,KP061,CP096;AiO:00;DW-PCL;'
