Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: Asus RT-N16 "Light" and "Cooling" mods
    RT-N16 does not need a fan in my opinion, you can add passive heatsinks that can perfectly do the job, even if you overclock. I have my RT-N16 with 5 heat sinks (CPU, Switch, Radio, Memorys) and temperatures are great
    My advice to all people who have problems with temperatures or not is to remove the top cover of the router, temperatures will drop alot and i don't see any problem with it, router will live longer for sure. I have 2 routers WL-500W and both have the same working hours, one without cover (its just like new) and the other it has 2 capacitors blown, obviously that was influency of the temperatures inside the case, so here is my recomendation to everyone. (including you WPTE) :P
    PS: I hate fans (specially when they get dirty and start to do those known annoying sounds)
    The Netherlands - Eindhoven
    Quote Originally Posted by hggomes View Post
    hmmm yeah that's the thing, I never really opened my routers for warranty purposes
    unlike you might expect, the fan controller I have has really low power fans. it has been running over 3 years now 24/7 and I never cleaned it.
    Still... the sound is lower than my WD mybook 1TB
    I placed another drive on it as well... since it can become pretty hot... 50 degrees or something. It's an old drive, but with the laptop cooler it stays nicely around 30 degrees
    In that case i don't know how you've got installed the fan, where the air from the fan flows? Between cover holes? That should not be very effective. :S
    RT-N16 Pictures
    laptop cooler: http://www2.conrad.nl/goto.php?artikel=999200
    it's not the same one as I have, this one is very luxurious!
    I mean, it has a usb hub and on/off switch
    apart from that it's the very same one
    I've learned from building pc's that just the tiniest little airflow (instead of none) can affect the temperature in a big way.
    btw, spider? you guys have green spiders over there? o.0
    bwaaahahaaha
    hggomes, that spider is a counter-argument of your advise to run the Router without the top-cover
    I don't want anything touching wlan cables or eating parts of the PCB!
    RT-N66U TomatoUSB 1.28.0000 MIPSR2-105 K26 USB AIO-64K running Entware
    lighttpd 1.4.3.0 php 5.4.5 eaccelerator sqlite
    pyload 0.4.9
    minidlna 1.0.25
    samba 3.6.5
    I've noticed that before everyone, and i only noticed after i took the photo, really ironic.
    Never happened before, i have WL-500W working 3 years with top-cover opened, but spiders don't eat cables or PCBs.
    Yes Wpte we have here lots of diferent "animals" here, GREEN spiders too, you haven't understand why? To suit the PCB offcourse ahahaahah
    PS: The spider hasn't entered because i removed the top-cover, it was already there, i removed the cover to take the picture (to show to wpte), !gm in case you haven't noticed the router has holes big enough to such things happen, so don't be surprised to open yours and see a spider "eating" your PCB and cables, if that happen its because it entered other animal heeheheheh, it would be funny to see such thing LOL
    yeah yes, I read the edit mark
    I thought the tiny holes are the only ones.. Now, I did take a closer look (at my device) and yes, found holes on the underside, where you attach the thing at a wall, that are big enough to let spiders and rodents in... (just kidding)
    good night
    pyload 0.4.9
    minidlna 1.0.25
    samba 3.6.5
    That's a LMR400 cable to connect an external antenna, if you notice i have 2 internal antenna's attached and the other one is the cable
    Good night 4 U 2
    Green spiders are not animals, they are spiders from hell
    seriously, if I'd see a green spider here... brix will be shat
    but perhaps it's just green because it ate from your pcb
    edit... noooo it's here:
    Thats exactly the same spider that was on the router, i've tried to catch her but she was fast as hell, she jumped out of the router in 1ms. Do you have scare of spiders?? LOL ehheh
    I hope my PCB don't start to itching
    Look what i've found:
    http://www.surviveoutdoors.com/refer...green_lynx.asp
    She is still alive so i guess we will still see each other someday
    Look to this new ASUS router WPTE:
    http://ednieuw.home.xs4all.nl/austra...alticidae.html
    What do you think of it? Cool ah? eheheheheh
    nope, not scared, as long as they don't have funky colors
    it's like seeing an alien... they look weird
