Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: Всё об Asus RT-N66U
    ASUS RT-N66U B1
    ASUS RT-N66U Dual Band Gigabit Router
    Quote Originally Posted by harsh132 View Post
    Вот что я встретил
    LAN to WAN - 510mbps
    WAN to LAN - 548mbps
    Но пишут, что это beta прошивка была
    Да не читайте вы советских газет ... (c)
    То то в Асусе идиоты сидят - для N56
    LAN to WAN - 862.4
    WAN to LAN - 802.4
    Новая моделька как раз в нижний ценовой диапазон )))
    Ну так в RT-N66U гораздо больше попугаев ...
     WAN -> LAN  	        934 Mbit/s
     LAN -> LAN  	        940 Mbit/s
     WLAN -> LAN 5GHz      229 Mbit/s
     LAN -> WLAN 2,4GHz  	128 Mbit/s
    http://nl.hardware.info/productinfo/...testresultaten
    Всё об Asus RT-N66U
    ASUS RT-N66U Dual Band Gigabit Router Review
    RT-N66U Dual-Band Wireless-N900 Router
    • 2.4 GHz and 5 GHz concurrent dual-band transmissions
    • Up to 8 multi-user SSIDs and parental controls
    • Wall-mount support (mount sold separately)
    • Up to 300,000 sessions to Internet clients
    • Ai Radar omnidirectional radar
    • 2 built in USB 2.0 ports
    • IPv6 support
    http://promos.asus.com/US/rt-n66u/
    Specifications
    Network Standard
    IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IPv4, IPv6
    Data Rate
    802.11a : 6,9,12,18,24,36,48,54Mbps
    802.11b : 1, 2, 5.5, 11Mbps
    802.11g : 6,9,12,18,24,36,48,54Mbps
    802.11n : up to 450Mbps
    Antenna
    Detachable Dipole RP-SMA antenna x 3
    Operating Frequency
    2.4G~2.4835GHz /5.1~5.8GHz
    WAN Connection Type
    Internet connection type :
    Automatic IP,
    Static IP,
    PPPoE(MPPE supported),
    PPTP,
    L2TP
    Dual Link support
    Multicast Proxy support
    Utilities
    Download master
    - support BT, NZB, HTTP, ED2K
    - support encryption, DHT, PEX and magnet link
    - upload and download bandwidth control
    - download scheduling
    Media server:
    Image: JPEG
    Audio: mp3, wma, wav, pcm, mp4, lpcm, ogg
    Video: asf, avi, divx, mpeg, mpg, ts, vob, wmv, mkv, mov
    QoS:
    WMM
    User definable rules for IP/MAC/Port.
    Upload and Download bandwidth management.
    ACK/SYN/FIN/RST/ICMP with Highest priority
    Guest Network
    2.4GHz guest network x 3, 5GHz guest network x 3
    Printer Server:
    multifunctional printer support (Windows only),
    LPR protocol support
    File server:
    Samba and FTP server with account management
    PPTP VPN server
    Network map
    Traffic monitor
    Ports
    4 x RJ45 for 10/100/1000/Gigabits BaseT for LAN,
    1 x RJ45 for 10/100/1000/Gigabits BaseT for WAN,
    Support Ethernet and 802.3 with max. bit rate
    10/100/1000/Gigabits Mbps and auto cross-over function(MDI-X)
    USB 2.0 x 2
    Button
    WPS Button, Reset Button, Power Button
    LED Indicator
    LAN x 4
    WAN x 1
    AIR x 2
    USB x 1
    Power Supply
    AC Input : 110V~240V(50~60Hz)
    DC Output : 19 V with max. 1.58 A current
    Weight / Dimensions
    450g / 207 x 148.8 x 35.5 mm (WxDxH)
    Firmware Version 	3.1.0.3.73
    Routing Throughput
    Direct Connection 	944 Mbps
    Wan to Lan 	        880 Mbps
    Lan to Wan         	907 Mbps
    Max. Sessions      	81772
    USB Storage Throughput
       	Read    	Write
    SAMBA 	107.2 Mbps 	63.2 Mbps
    FTP 	100 Mbps 	76.8 Mbps
    VPN Throughput
    No VPN                	206 Mbps
    VPN no Encryption 	80.5 Mbps
    VPN 40bit MPPE    	47.8 Mbps
    VPN 128bit MPPE 	46.9 Mbps
    http://vr-zone.com/articles/asus-rt-...w/14666-1.html
    http://forums.smallnetbuilder.com/sh...t=6446&page=37
    http://www.hardwareluxx.de/community...re-853441.html
    http://www.dd-wrt.com/phpBB2/viewtop...6437&start=105
    Arrow ASUS RT-N66U B1
    Новая прошивка для ASUS RT-N66U:
    Description ASUS RT-N66U B1 Firmware version 3.1.0.3.90
    • Add USB performance enhancement into RT-N66U
    File Size 18,38 (MBytes) 2012.02.02 update
    http://support.asus.com/Download.asp...R.B1)&p=11&s=2
    http://www.evga.com/forums/tm.aspx?m...e=1&print=true
    ASUS RT-N66U Dark Knight Dual-Band Wireless-N900 Gigabit Router Reviewed - Part 1
    VPN
    • PPTP server
    • PPTP, L2TP, IPsec passthrough (default enable)
    Routing
    • Static and Dynamic IP, PPPoE , PPTP, L2TP WAN connections
    • MTU/MRU adjust (PPPoE only)
    • DHCP Server w/ lease time setting, default domain and primary/secondary DNS
    • DHCP Client list
    • DHCP reservation
    • Multicast routing and forwarding
    • UDP proxy
    • Switch jumbo frame enable
    • UPnP enable/disable
    • IPv4 Static Routes
    • IPv6 support: Native; Native w/DHCP; Tunnel 6to4; Tunnel 6in4; Tunnel 6rd
    • DDNS support for asus.com, dyndns.org, tzo.com, zoneedit.com
    • Five level bandwidth-based QoS for upand download traffic
    Firewall
    • Firewall enable/disable
    • DoS protection enable
    • Virtual Server/port forwarding for single or multiple ports with TCP, UDP or both
      protocols forwarded. Separate source and destination ports, not schedulable
    • Triggered port forwarding for single ports, TCP or UDP, not schedulable
    • URL keyword filter
    • Per client internet access scheduling
    • DMZ Host
    • RTSP passthrough
    • PPPoE relay
    • Ignore Ping Packet from WAN port
    • Outbound port filtering: black/white list with port range, source/destination IP,
      protocol and day/time filter
    Management
    • Remote Management with user configurable port (but no HTTPS)
    • Syslog server support
    • Command line interface via Telnet (default disable)
    • Reboot and reset to factory default
    • Save/restore settings
    • Logs: System console, DHCP, Wireless, port forwarding, routing table
    Wireless
    • WEP, WPA / WPA2 Personal and Enterprise (RADIUS) support
    • Wi-Fi Protected Setup (WPS) support, pushbutton and PIN
    • Auto, N-only, Legacy modes
    • Auto and manual channel set
    • Transmission rate set
    • SSID broadcast enable/disable
    • Radio enable day/time schedule
    • WDS bridging / repeating
    • Multicast transit rate
    • Transmit power adjust
    • Beacon period, RTS threshold, DTIM interval adjusts
    • Transmit burst (default enable), multicast forwarding (default disable),
      WMM APSD (default enable) enables
    • Wireless client isolation (from each other)
    • Scheduled wireless enable/disable
    • AP/router mode switch
    • Four Guest networks per radio
    • Wireless MAC address filtering (allow or deny based on MAC address)
    • WMM disable
    http://www.smallnetbuilder.com/wirel...eviewed-part-1
    http://translate.google.com/translat...s_rt-n66u.html
    Arrow FW_RT_N66U
    ASUS RT-N66U B1 Firmware version 3.0.0.3.96 (18,56MBytes 2012.02.13)
    • 1. Fixed ppp connection fails after setting idle timeout
    • 2. Fixed Turkey lang related bugs
    • 3. Fixed Virtual port fail issue
    • 4. Fixed NAT loopback bug
    • 5. Fixed Media server bug
    • 6. Modified setting DMZ, related pptp packets will be redirected to that DMZ pc
    • 7. Modified WDS site survey
    • For Download master:
      • 1. The file will not be removed when remove the completed task.
      • 2. Fixed multi-language related bugs.
    Новая прошивка 3.0.0.3.100 от Асуса: RT-N66U_3.0.0.3_100.trx
    З.Ы. Народ закупается по полной программе ...
    Exclamation ASUS RT-N66U B1
    ASUS RT-N66U B1 Firmware Version 3.0.0.3.102
    Fixed
    • 1. httpd abnormal after adding more than 24 IP/MAC entries
    • 2. RF power decrease issue reported in 3.0.0.3.96
    • 3. Download master:The HTTP and FTP task cannot continue when WAN reconnect to Internet.
    • 4. Download master: some multi-language strings issue.
    • 5. Download master: Bit torrent association tool compatibility issue.
    Modified
    • 1. allow user to modify scanning directory of media server
    • 2. allow user to select attached clients into static dhcp ip list
    • 3. CTF ability automatically adjustment
    • 4. change the WPA key rotation interval default value from 0 to 3600
    http://www.4shared.com/dir/h9J1MTAx/_online.html
    MicroSD
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    After sticking in a 2GB MicroSD card and rebooting, the card is seen and mounted to /tmp/mnt/sda1
    #df -h
    Filesystem                Size      Used Available Use% Mounted on
    /dev/root                17.0M     17.0M         0 100% /
    tmpfs                   124.8M    412.0K    124.4M   0% /tmp
    devfs                   124.8M         0    124.8M   0% /dev
    /dev/sda1                 1.9G     24.0K      1.9G   0% /tmp/mnt/sda1
    Contents can be shared via samba in OEM firmware, now to figure out how to run custom scripts from the oem firmware.
    Asus RT-N66U vB1 Front Labels
    Asus RT-N66U vB1 Back Labels
    http://www.techinfodepot.info/index....us_RT-N66U_vB1
    Arrow FW_RT-N66U
    Новые тестовые бета-прошивки от Асус:
    Беспроводной роутер RT-N66U (06.04.2012):
    • Black UI firmware
    httр://www.asus.ru/ftp/NW_TO_TEST/RT-N66U_3.0.0.3_116b.trx
    Беспроводной роутер RT-N66U (21.03.2012)
    • WEB UI improvements
    • Download Master fix
    • Manual and DHCP routing fix
    • DNS renew for VPN fix
    httр://www.asus.ru/ftp/NW_TO_TEST/RT-N66U_3.0.0.3_113.trx
    http://forum.asus.ru/viewtopic.php?f=4&t=44107 http://search.4shared.com/q/alltime/CCAD/1/N66U
    Новая прошивка от Asus FW_RT-N66U_3003_114: http://www.4shared.com/file/5nFyylwI...U_3003_114.htm
    Обзор от IXBT: Высокопроизводительный двухдиапазонный беспроводной роутер ASUS RT-N66U
    Часть 1. Внешний вид, настройка и возможности: http://www.ixbt.com/comm/asus-rt-n66u-part1.shtml
    Часть 2. Тестирование производительности: http://www.ixbt.com/comm/asus-rt-n66u-part2.shtml
    Arrow Всё об Asus RT-N66U
    Обзор от 3DNews: Роутер ASUS RT-N66U Dark Knight и адаптер EA-N66 - тёмный рыцарь и дзен-пирамида
    Ещё один интересный обзор на сайте FoxNetwork: ASUS RT-N66U, или 900 Мбит/с без проводов
    Аппаратная платформа ASUS RT-N66U представлена одной текстолитовой платой, основные элементы которой скрыты под двумя
    металлическими экранами. На обратной стороне платы доступен для обозрения лишь модуль флеш-памяти Spansion S29GL256P10TFI01.
    С лицевой и оборотной стороны к экранам и чипам прикреплены большие металлические радиаторы для увеличения теплоотвода. К счастью,
    также как и в других моделях ASUS, RT-N66U не содержит внутреннего вентилятора, то есть используется схема пассивного охлаждения.
    ASUS RT-N66U имеет отключаемый аппаратный ускоритель NAT. Мы решили провести тесты скорости маршрутизации и трансляции с
    включенным и отключенным ускорителем (HWA – Hardware Accelerator). Ниже приведены скорости передачи данных для одного, пяти
    и пятнадцати одновременных TCP-сессий. К сожалению, аппаратное ускорение применимо исключительно к сессиям с трансляцией
    адресов, на простой маршрутизации наличие аппаратного ускорителя не сказывается.
    Беспроводной маршрутизатор ASUS RT-N66U позволяет одновременно работать в двух беспроводных диапазонах: на частотах 2,4 и 5 ГГц.
    Для каждого из диапазонов максимальная теоретическая скорость передачи составляет 450 Мбит/с. Мы решили выяснить практические
    скорости. Для данного теста мы использовали беспроводной адаптер ASUS EA-N66, о котором мы уже рассказывали ранее. Результаты
    измерений для обоих диапазонов мы представили на диаграмме. Наконец-то мы перешагнули рубеж в 200 Мбит/с!
    http://www.foxnetwork.ru/index.php/r...s-rt-n66u.html
    FW_RT-N66U
    Новая тестовая прошивка: http://www.asus.ru/ftp/NW_TO_TEST/RT-N66U_3.0.0.3_147.trx
    Отчет по тестированию билда RT-N66U_3.0.0.3_147 http://wl500g.info/entry.php?76
    Потетировал тут текущую бетту прошивки, дабы не затруднять читателей обилием бяквовок приведу только резюме -
    Резюме: В текущем состоянии прошивка непригодна для использования на клиентском оборудовании -
    1. Конфигурирование через WEB интерфейс - частично неработоспособно
    2. Multicast Route проводной - полностью неработоспособно
    3. Multicast Route Wi-Fi - полностью неработоспособно
    3. IPV6 - полностью неработоспособно
    4. Wi-Fi 2,4GHz - частично неработоспособно
    5. Работа с SIP провайдерами - частично работоспособно
    6. Отображение параметров в WEB интерфейсе - частично неработоспособно
    7. Нестабильная работа L2TP
    Что, так прям всё плохо? И что это значит - "частично (не)работоспособно"?
    Типа немного беременна? Может что-нибудь подправить в консерватории?
    http://www.asus.ru/ftp/NW_TO_TEST/RT....0.0.3_131.trx
    http://www.asus.ru/ftp/NW_TO_TEST/RT....0.0.3_135.trx
    http://www.asus.ru/ftp/NW_TO_TEST/RT....0.0.3_144.trx
    Релиз 095 новой прошивки Tomato от Shibby: http://tomato.groov.pl
    [RELEASE] version 095
    Changelog:
    - fix working PS3 with minidlna
    - fix [bwlimit] link on overview-devices page
    - fix „ug” bug with running shell scripts on RT-N66u
    - remove garbage from Router Name
    - enable USB Support by default
    - enable SD Card support for RT-N66u by default
    - samba security fix – „root” credential remote code execution
    - wl_mitigation disabled by default
    - VLAN:
    - experimental VLAN/VID mapping GUI (allows creating
    VLANs with 802.1Q tags larger than 15 via GUI)
    - allow DMZ-style forwarding to alternative LAN bridges
    - PPTP:
    - allow specify ‘custom’ config/settings
    - dnsmasq to answer DNS queries on pppX interfaces
    - MultiSSID: some minor fixes
    • tomato-K26USB-1.28.RT-N5x-MIPSR2-095-AIO.trx
    • tomato-K26USB-1.28.RT-N5x-MIPSR2-095-Mega-VPN.trx
    • tomato-K26USB-1.28.RT-N5x-MIPSR2-095-Big-VPN.trx
    • tomato-K26USB-1.28.RT-N5x-MIPSR2-095-BT-VPN.trx
    • tomato-K26USB-1.28.RT-N5x-MIPSR2-095-Nocat-VPN.trx
    • tomato-K26USB-1.28.RT-N5x-MIPSR2-095-VPN.trx
  1. Настройка DynDNS на роутере Asus
    By idtelecom in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 24-04-2013, 06:49
  2. Настройка FTP сервера на ASUS WL500G Premium
    By RonS in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 27-11-2011, 15:57
  3. Проблемы с DHCP
    By Alex Kud in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 30-08-2009, 06:12
  4. Asus WL-500G en Linksys NSLU2
    By VEJ in forum Dutch Discussion - Nederlands
    Last Post: 06-12-2007, 21:23
  5. ASUS systematic security proposal
    By r0kanon in forum WL-500gP Firmware Discussion
    Last Post: 07-03-2007, 16:08
