Results 1 to 4 of 4
Thread: WebCam-PWC-Module 9.0.2 for lattest Olegs Firmware
    Wink WebCam-PWC-Module 9.0.2 for lattest Olegs Firmware
    if someone like to use it, I hacked a Diff for Oleg's lattest Cust-Firmware to bring up the PWC-Module from Version 8.12 to 9.02 that's the latest version for kernel-series 2.4.* as far as i know.
    It has support for a few more webcams.
    cd to the DIR where the broadcom directory exists, then do a
    zcat wl500g-1.9.2.7-5a-pwc-patch.gz | patch -p0
    The rest of it, just go head like usually.
    By the way, the Makefiles5.diff problem will be solved with this patch also !!
    To get the new Version into the Kernel wasn't that different, only to get used to Oleg's way of Diff-Files handling (I don't understand the Reverse-Option in the patch.sh file) made it a little hard.
    Hope someone like it
    have fun with it, sincerly
    Andy
    P.S.: My Web-Cam Problem is solved too, I just rewrote the EEPROM in it
    Greetings from 1XXXX (Berlin/Germany)
    Question
    Hi,,I can see 3 downloads (one was a test from me) does any body has Problems with it ??
    Does it Work ??
    Does it Help ??
    is it usefull ??
    I'm working right now at Version 10.0.2 (this was the last one with a patch for the 2.4'er Kernel) and the Intel CAM-Series is any body interrested ??
    Any way, I'M working at it because a friend of my like to have it.
    Andy
    I'm interested in integrating this, let me know of your progress. I'm just a bit busy with WAN port dies bug.
    Be sure to test all the stuff carefully.
    Jun 2005
    Portugal
    hi ppl
    Take a look at :
    http://wl500g.info/showthread.php?t=2846
    Kind Regards,
    João Seabra
  1. NFS/ftp with Olegs custom firmware
    By gerd in forum WL-HDD Q&A
    Last Post: 25-04-2005, 12:16
  2. Having trouble to compile Olegs Firmware...
    By max2950 in forum WL-500g Custom Development
    Last Post: 08-03-2005, 14:27
  3. OpenWrt Firmware or Olegs 1.7.5.9-5
    By rdk in forum WL-500g Q&A
    Last Post: 16-09-2004, 19:28
