i've forgotten : the UPnP is set to Yes in my Router, and my SIP client
check if it is behind a UPnP router
i use this routeur with a SIP client to make Voice calls.
When i register my Client to an external SIP Proxy, the to and from address are correct, but IP address inside SIP messages stay as local address (192.168.x.x)
, escalially STP address
So all initial messages sended by the SIP Proxy (INVITE messages) are sended to a wrong address.
My question is : How can i NAT all IP address inside messages from Internal address an External address (ALG function or bind function) ?
Thanks
Someboby can help me about Translation IP address inside SIP messages ?
Nobody can help me about SIP Natting ?
i've tried with an Alcatel Speedtouche Router, and i can NAT the SIP addresses by a bind on Port 5060
how can i make the same thing on the ASUS WL500gx ?
thanks
