Не хочет это прошивка конектится по ppoe с моим провайдером не в какую вот log
PHP Code:
Jan 1 08:00:04 syslogd started: BusyBox v1.17.3
Jan 1 08:00:04 kernel: klogd started: BusyBox v1.17.3 (2010-10-11 16:30:40 MSD)
Jan 1 08:00:04 kernel: Linux version 2.6.22.19 (root@localhost) (gcc version 4.3.5 (GCC) ) #1 Mon Oct 11 16:41:57 MSD 2010
Jan 1 08:00:04 kernel: CPU revision is: 00019740
Jan 1 08:00:04 kernel: Found a 8MB ST compatible serial flash
Jan 1 08:00:04 kernel: Determined physical RAM map:
Jan 1 08:00:04 kernel: memory: 04000000 @ 00000000 (usable)
Jan 1 08:00:04 kernel: Netfilter messages via NETLINK v0.30.
Jan 1 08:00:04 kernel: nf_conntrack version 0.5.0 (512 buckets, 4096 max)
Jan 1 08:00:04 kernel: ipt_time loading
Jan 1 08:00:04 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 08:00:04 kernel: TCP cubic registered
Jan 1 08:00:04 kernel: NET: Registered protocol family 1
Jan 1 08:00:04 kernel: NET: Registered protocol family 10
Jan 1 08:00:04 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 08:00:04 kernel: IPv6 over IPv4 tunneling driver
Jan 1 08:00:04 kernel: NET: Registered protocol family 17
Jan 1 08:00:04 kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Jan 1 08:00:04 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 08:00:04 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 08:00:04 kernel: Freeing unused kernel memory: 124k freed
Jan 1 08:00:04 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 08:00:04 kernel: emf: module license 'unspecified' taints kernel.
Jan 1 08:00:04 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.10.56.46
Jan 1 08:00:04 kernel: eth1: Broadcom BCM4329 802.11 Wireless Controller 5.10.56.46
Jan 1 08:00:04 kernel: vlan1: dev_set_promiscuity(master, 1)
Jan 1 08:00:04 kernel: device eth0 entered promiscuous mode
Jan 1 08:00:04 kernel: device vlan1 entered promiscuous mode
Jan 1 08:00:04 kernel: device eth1 entered promiscuous mode
Jan 1 08:00:04 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 08:00:04 kernel: br0: port 1(vlan1) entering forwarding state
Jan 1 08:00:05 dnsmasq[213]: started, version 2.55 cachesize 512
Jan 1 08:00:05 dnsmasq[213]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N DHCP no-scripts no-TFTP
Jan 1 08:00:05 dnsmasq-dhcp[213]: DHCP, IP range 192.168.1.101 -- 192.168.1.254, lease time 1d
Jan 1 08:00:05 dnsmasq[213]: read /etc/hosts - 2 addresses
Jan 1 08:00:05 kernel: usbcore: registered new interface driver usbfs
Jan 1 08:00:05 kernel: usbcore: registered new interface driver hub
Jan 1 08:00:05 kernel: usbcore: registered new device driver usb
Jan 1 08:00:06 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan 1 08:00:06 kernel: USB20H mdio control register : 0x80000010
Jan 1 08:00:06 kernel: ohci_hcd 0000:00:04.0: OHCI Host Controller
Jan 1 08:00:06 kernel: ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 1
Jan 1 08:00:06 kernel: ohci_hcd 0000:00:04.0: irq 5, io mem 0x18009000
Jan 1 08:00:06 kernel: usb usb1: configuration #1 chosen from 1 choice
Jan 1 08:00:06 kernel: hub 1-0:1.0: USB hub found
Jan 1 08:00:06 kernel: hub 1-0:1.0: 2 ports detected
Jan 1 08:00:06 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 08:00:06 kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
Jan 1 08:00:06 kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 2
Jan 1 08:00:06 kernel: ehci_hcd 0000:00:04.1: irq 5, io mem 0x18004000
Jan 1 08:00:06 kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
Jan 1 08:00:06 kernel: usb usb2: configuration #1 chosen from 1 choice
Jan 1 08:00:06 kernel: hub 2-0:1.0: USB hub found
Jan 1 08:00:06 kernel: hub 2-0:1.0: 2 ports detected
Jan 1 08:00:06 kernel: usbcore: registered new interface driver usblp
Jan 1 08:00:06 kernel: SCSI subsystem initialized
Jan 1 08:00:07 kernel: Initializing USB Mass Storage driver...
Jan 1 08:00:07 kernel: usbcore: registered new interface driver usb-storage
Jan 1 08:00:07 kernel: USB Mass Storage support registered.
Jan 1 08:00:07 kernel: NTFS driver 2.1.28 [Flags: R/O MODULE].
Jan 1 08:00:07 pppd[289]: Plugin rp-pppoe.so loaded.
Jan 1 08:00:07 pppd[289]: RP-PPPoE plugin version 3.10 compiled against pppd 2.4.5
Jan 1 08:00:07 pppd[290]: pppd 2.4.5 started by admin, uid 0
Jan 1 08:00:17 dnsmasq-dhcp[213]: DHCPREQUEST(br0) 192.168.1.251 00:22:15:c0:1d:56
Jan 1 08:00:17 dnsmasq-dhcp[213]: DHCPACK(br0) 192.168.1.251 00:22:15:c0:1d:56 microsof-ad6e37
Jan 1 08:00:42 pppd[290]: Timeout waiting for PADO packets
Jan 1 08:01:58 pppd[290]: Timeout waiting for PADO packets
Jan 1 08:03:13 pppd[290]: Timeout waiting for PADO packets
Проблема точно не в провайдере на стареньком Asus-WL520 соеденение поднимается без проблем! Прописывал данные получаемые по DHCP в ручную один хрен соеденение не поднималось! Пнитите люди добрые в что сделать уж больно хочется на эту прошивку перелезть!
Из позитивного винт в 2 гига с NTFS определился на ура и замечательно раздавался по sambe и ftp. Причем встроеный в оригинальную прошивку NETGER ftp сервер глючит с MacOs когда монтируешь его в качестве диска! С этой прошивкой ftp монтируется и работает отлично!
