Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958
Прошивка 1.9.2.7-rtn от энтузиастов на WNR3500L
Page 1 of 8 123 ... LastLast
Results 1 to 15 of 570
Thread: Прошивка 1.9.2.7-rtn от энтузиастов на WNR3500L
    Lightbulb Прошивка 1.9.2.7-rtn от энтузиастов на WNR3500L
    1.9.2.7-rtn Netgear WNR3500L
    NETGEAR WNR3500L Open Source Wireless N (Draft) Router Open Source Guide & Resources
    Chipsets:
    CPU: Broadcom BCM4718 (Draft IEEE 802.11n compliant)
    • Four way set associative 32-KB instruction cache
    • Two way set associative 32-KB data cache
    • 64 entry translation look aside buffer (TLB)
    • Dual band radio transceiver
    • Two integrated USB 2.0 EHCI host ports
    • A 8/16-bit parallel external bus interface (EBI)
    • Enhanced 10/100/1000 Ethernet MAC controller
      with TCP segmentation and checksum upload
    Switch: Broadcom BCM53115s
    • It enables deployment of GIGABIT ethernet.
    • It contains non-blocking 5-port 10/100/1000
      switch silicon that integrates
    • Five 10/100/1000 PHYs.
    • Two fully integrated GMII/RGMII/MII interfaces ,
      two IMPs (Inband management ports)
    • It provides four selectable QoS per port
    Memory
    • SDRAM: 64 MB (Samsung K4T56163Q)
    • Flash: 8 MB (Macronix MX25L6405D)
    http://infodepot.wikia.com/wiki/Netgear_WNR3500L
    Memory used by the latest router firmware:
    WARNING !!! WNR3500 v.2 (the one with 4MB of flash and 16 MB of RAM)
    SDRAM:
    • Flash: 5.2 MB
    Module and Software Specification
    • WNR3500L is running Linux 2.4.20.
    WNR3500L
    http://www.myopenrouter.com/article/13860/...uide-Resources/
    http://wl500g.info/showpost.php?p=171417&postcount=2
    NETGEAR WNR3500L 480- MIPS 74K
    . 8 - 64 ,
    , NETGEAR Gigabit Ethernet
    WAN LAN 350 /.
    802.11n .
    http://kb.netgear.com/app/products/model/a_id/2615
    http://documentation.netgear.com/wnr...5-01/index.htm
    http://firmware.netgear-forum.com/in...erface=WNR3500
    Quote Originally Posted by marincax View Post
    RT-N16-1.9.2.7-rtn-r2181.trx Netgear WNR3500L - ,
    , (BCM4718/BCM53115),
    (64/8 MB), Asus RT-N16 (128/32 MB) ...
    GPIO LED ... http://forum.ixbt.com/topic.cgi?id=14:51784-4
    WNR3500L
    SES button Led enable / disable
    "gpio enable 1" / "gpio disable 1"
    Power Led yellow (enable) / green (disable)
    "gpio enable 7" / "gpio disable 7"
    Internet Led yellow (enable) / green (disable)
    "gpio enable 2" / "gpio disable 2"
    Power Led On (enable) / Off (disable)
    "gpio enable 3" / "gpio disable 3"
    Wireless Led always On / Off
    "gpio enable 0" / "gpio disable 0"
    Flash Layout of Default WNR3500L Firmware
    Flash layout specifies the offsets for different components of a firmware in flash.
    It varies from firmware to firmware, but one should make sure that for WNR3500L first 4*64K blocks
    are used for CFE and last two 64K blocks are used for board data and nvram respectively.
    The flash layout for default NETGEAR firmware is as follows:
    0x00000000-0x00040000 : "boot"
    0x00040000-0x00790000 : "linux"
    0x000d0f7c-0x00790000 : "rootfs"
    0x00790000-0x007a0000 : "ML1"
    0x007a0000-0x007b0000 : "ML2"
    0x007b0000-0x007c0000 : "T_Meter1"
    0x007c0000-0x007d0000 : "T_Meter2"
    0x007d0000-0x007e0000 : "POT"
    0x007e0000-0x007f0000 : "board_data"
    0x007f0000-0x00800000 : "nvram"
    http://www.myopenrouter.com/article/...es/?textpage=5
    WNR3500L
    • 1)
      erase linux
      reboot
    • 2) 192.168.1.1/24 ( 192.168.1.2)
    • 3) code.chk
    • 4)
      tftp -i 192.168.1.1 PUT code.chk
    • 5) 3-4 ...
    http://forum.netgear.ru/viewtopic.php?id=1723
    Arrow WNR3500L Firmware Upgrade Using Serial Console
    The firmware can be updates using one of two methods; you can either use the serial console or the GUI.
    First, we'll describe the method for the former, using the cable you just created.
    The steps to flash the router using serial interface are as follows:
    (One can use minicom, PuTTY or other similar utility for this, I have used minicom.)
    • Connect the serial end of the cable to the serial header of your board and USB end to your host PC.
    • Make sure the putty/minicom windows is in front.
    • Power on the board.
    • As soon as you power on the board, you have to hit control-C to enter the CFE prompt.
    • You may have to hit it a couple of times.
    If you are successful you will see this message :
    CFE for WNR3500L version: v1.0.36
    Build Date: Tue Aug 11 15:09:14 CST 2009
    Init Arena
    Init Devs.
    Boot partition size = 262144(0x40000)
    Found a 8MB ST compatible serial flash
    et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.10.56.28
    CPU type 0x19740: 453MHz
    Tot mem: 65536 KBytes
    Device eth0:  hwaddr 00-24-B2-89-28-3A, ipaddr 192.168.1.1, mask 255.255.255.0
            gateway not set, nameserver not set
    Startup canceled
    CFE> ^C
    CFE> ^C
    CFE> ^C
    At the CFE prompt type in tftpd. This will start a tftp server and you will get the following lines at the CFE prompt:
    CFE> tftpd
    Start TFTP server
    Reading ::
    At your host PC make sure that you have an IP 192.168.1.x and this interface should be connected to one of the LAN ports
    of your board. Now go to the directory where you have kept the .chk file to be flashed and give the following command :
    $ tftp m binary 192.168.1.1 c put firmware.chk
    Once you give this command firmware upgrade will start. In PuTTY/minicom you should see something like this :
    Reading :: Done. 5443642 bytes read
    Programming...done. 5443642 bytes written
    Write len/chksum offset @ 0x0074FFF8...done.
    Decompressing..........done
    Init Arena
    Init Devs.
    Tot mem: 65536 Kbytes
    http://www.myopenrouter.com/article/...F23?textpage=2
    How To Reflash Factory Firmware on the NETGEAR WRN3500L Without A Serial Cable
    Arrow Serial Port Connection to Access the WNR3500L
    Setting up a Serial Port Connection to Access the WNR3500L Board:
    If you're going to be working with your router a lot, or especially working with multiple routers,
    it's convenient to have an externally accessible serial port. However, you should remember that
    soldering third-party circuits to your router's mainboard voids the warranty, and if you make
    a mistake, you can cause permanent damage to your router. Proceed at your own risk.
    Items Needed:
    An FTDI 3.3V USB-to TTL serial cable (TTL-232R-3V3)-1.8 m
    diagonal cutting pliers (optional).
    needlenose pliers (optional).
    Installation:
    WNR3500L comes with an inbuilt serial cable header.
    You just need to open your router box to see it.
    It has been shown in the figure below:
    The USB-Serial cable initially looks as follows:
    As all pins on the serial end of the cable are not useful ( We need only three pins) we need to open
    the serial end of the cable and separate three pins that are useful to us from the rest of the pins.
    These pins are :
    • Pin 1 (GND pin): Black coloured , it is connected to pin 6 of serial header.
    • Pin 4 (Tx pin) : Orange coloured , it is connected to pin 2 of serial header.
    • Pin 5 (Rx Pin) : Yellow coloured , it is connected to pin 5 of serial header.
    The figures given below show the USB-Serial cable after the above mentioned
    modification and how it is connected to the serial header of WNR3500L.
    That's it - your setup is ready!
    How To Debrick Your NETGEAR WNR3500L Using A USB-TTL Cable on Windows
    Jan 2009
    Russia, Chehov
    Lightbulb
    , http://www.dd-wrt.com/routerdb/de/do...3500L.chk/3817
    dd-wrt, , .chk. . . admin password .
    1.9.2.7-rtn-r2181.trx rtn16.bin dd-wrt. . , . . . WPS . 12- 12,5 , . IPTV WiFi , .
    . ( 00:FF:FF:FF:FF:FF) WPS( ) - ( rtn , ), (, ssh) . WAN , LAN WLAN ( ). . RTN.
    Jan 2009
    Russia, Chehov
    , PPPoE, 5 , 100 , 1 WiFi n Dlink DWA131.
    1. WiFiLan
    2. WiFiTorrent
    3. LanLan
    4. LanTorrent
    . . WPS .
    PHP Code:
    release/src/router/shared/led.c
    +//                                WLAN  DIAG  WHITE AMBER  DMZ  AOSS  BRIDG MYST
    static int dir320[]     = { -99,   1,     4,    3,  255,  255,  255,   -5       };
    -       static
    int wnr3500[]    = { 255,   1,     3,    7,  255,  255,  255,  255       };
    +       static
    int wnr3500[]    = { 255,   3,     1,    7,  255,    2,  255,  255       };
    271         case MODEL_DIR320:
    272                 b dir320[which];
    273                 break;
    274         case MODEL_WL500GPv2:
    275         case MODEL_WL520GU:
    276                 if (which != LED_DIAG) return 0;
    277                 b 0;  // Invert power light as diag indicator
    278                 if (mode != LED_PROBEmode = !mode;
    279                 break;
    280         case MODEL_RTN12:
    281                 if (which != LED_DIAG) return 0;
    282                 b = -2// power light
    283                 break;
    284         case MODEL_RTN10:
    285         case 'MODEL_RTN16':
    286                 if (which != LED_DIAG) return 0;
    287                 b = -1// power light
    288                 break;
    289         case 'MODEL_WNR3500L':
    290                 b wnr3500[which];
    291                 break;
    release/src/router/rc/buttons.c
    +       case [B]MODEL_WNR3500L[/B]:
    reset_mask << 4;
    ses_mask << 6;
    ses_led LED_WHITE;
    +               break;
    #ifdef DEBUG_TEST
    cprintf("reset count = %d\n"count);
    #else
    if (count >= 3) {
    nvram_set("restore_defaults""1");
    nvram_commit();
    +                               eval(
    "mtd-erase""-d""nvram");
    //nvram_set("restore_defaults", "1");
    +                               //nvram_commit();
    sync();
    reboot(RB_AUTOBOOT);
    #ifdef TCONFIG_USB
    +                                       case '5':       // !!TB: unmount all USB drives
    +                                               add_remove_usbhost("-1"0);
    +                                               break;
    #endif
    http://repo.or.cz/w/tomato.git/commi...eca3f87bc7a584
    DD-WRT?
    boardrev "0x1213"
    Tomato boardrev:
    release/src/router/shared/id.c
                       HW_*         boardtype   boardnum   boardrev  boardflags   others
    58 RT-N16         BCM4718        0x04cf       45        0x1218    0x0310      hardware_version=RT-N16-00-07-01-00 regulation_domain=0X10US sdram_init=0x419
    59 RT-N12         BCM4716        0x04cd       45        0x1201    0x????
    60 RT-N10         BCM5356        0x04ec       45        0x1402    0x????
    61 WNR3500L       BCM4718        0x04cf       3500      0x1213|02 0x0710|0x1710
    +       case 1:
    +       case 3500:
    +               switch (hw) {
    +               case HW_BCM4718:
    +                       //if (nvram_match("boardrev", "0x1213") || nvram_match("boardrev", "02"))
    +                       return MODEL_WNR3500L;
    +               break;
    release/src/router/rc/init.c
    +       case MODEL_WNR3500L:
    +               mfr = "Netgear";
    +               name = "WNR3500L";
    +               features = SUP_SES | SUP_80211N | SUP_1000ET;
    +               if (!nvram_match("t_fix1", (char *)name)) {
    +                       nvram_set("sromrev", "3");
    +                       nvram_set("lan_ifnames", "vlan1 eth1");
    +                       nvram_set("wan_ifnameX", "vlan2");
    +                       nvram_set("wl_ifname", "eth1");
    +                       nvram_set("vlan1ports", "4 3 2 1 8*");
    +                       nvram_set("vlan2ports", "0 8");
    +                       nvram_set("boardflags", "0x00000710"); // needed to enable USB
    +                       nvram_set("t_fix1", name);
    +               break;
    . Netgear - 3 , Asus - 5 .
    , ... (c)
    (c) . . () ( . )
    .. http://www.kwiksurveys.com/online-su...ILOLJ_67eb9665
    Moscow
    ? erase linux? , board_data, , , DIR-320.
    Jan 2009
    Russia, Chehov
    , tftp ttl=64.
    - Recovery process of the board http://www.myopenrouter.com/article/...es/?textpage=5
    Recovery process of the board:
    A board may become dysfunctional due to various reasons and also the extent of this varies depending on the causes.
    1. After doing a firmware upgrade one may not be able to access the board because of some mismatch in nvram parameters. In such cases a hard factory reset sets all nvram parameters to their default values for that particular firmware and the board becomes functional.
    2. Due to a nvram mismatch, some features work while others dont work. For example, ping works but GUI access does not. In such cases, a hard factory reset solves the issue.
    3. The flashed firmware has a wrong flash layout and in such cases, the boot process will repeat in cycles. If that is the case, the router is bricked and only way to recover is to set up a serial interface to access its console.
    4. It may also happen that flashed firmware has a wrong board id and in such case also boot will not happen. In such case one needs to give the follwing command at the console of the board: "burnboardid <>" (without quotes) Also for USB and Wireless to work simultaneously, boardflags should be 0x00000710.
    WNR3500L-1.9.2.7-rtn-r2255M.trx WNR3500L-1.9.2.7-rtn-r2257M.trx. WNR3500L-1.9.2.7-rtn-r2257M.trx, WNR3500L-1.9.2.7-rtn-r2255M.trx, ?
    Moscow
    2257 DHCP, 2255. , .
    2WAN, 320
    nvram set vlan0ports="2 3 4 5*"
    nvram set vlan1ports="0 5"
    nvram set vlan2ports="1 5"
    nvram set vlan1hwname=et0
    nvram set vlan2hwname=et0
    nvram set wan1_ifname=vlan2
    nvram set wan1_proto=dhcp
    nvram commit
    Moscow
    Quote Originally Posted by elav View Post
    2WAN, 320
    nvram commit
    WNR3500L, RT-N16 .
    DIR-320: 0 - WAN, 1 - LAN1, 2 - LAN2, 3 - LAN3, 4 - LAN4, 5 - CPU, vlan0 = LAN, vlan1 = WAN
    WNR3500L: 0 - WAN, 1 - LAN4, 2 - LAN3, 3 - LAN2, 4 - LAN1, 8 - CPU, vlan1 = LAN, vlan2 = WAN
    - vlan1ports="1 2 3 4 8*" vlan2ports="0 8".
    Доброго времени суток! Хотел перепрошиться на rtn, почитал ветку и решил делать ход конем - через dd-wrt. Скачал dd-wrt.v24-14896_NEWD-2_K2.6_mini-WNR3500L.chk и стал обновлять через веб-морду. Прошися благополучно, после прошивки не смог соединиться с 192.168.1.1 через кабель. В трее горит ошибка соединения по локалке с роутером - "подключение ограничено или отсутствует". Через wi-fi добрался до веб-морды dd-wrt. Попытался прошиться на rtn - не выходит, выскакивает сообщение "соединение было сброшено". Пытался восстановить прошивку по этой методе - http://forum.netgear.ru/viewtopic.php?pid=8213#p8213 , но ничего не вышло, 192.168.1.1 пингуется несколько секунд, потом "пропадает". Может кто-то сталкивался с подобной проблемой? Как быть?
