Still I do not understand why when I use
mount tab
smb tab
in the commands list doesn't apear mount.cifs and smbfs
mount tab
smb tab
I modified the file "/usr/local/sbin/post-mount" but the automount is not working.
#! /bin/sh
/opt/etc/init.d/rc.unslung start
insmod /opt/modules/smbfs.ko
sleep 6
smbmount //192.168.109.130/torrent /opt/torrent/ -o username=Foxem,password=XXXX
Then I created in /opt/etc/init.d/S10smbfs
sleep 6
could you please tell me what I am doing wrong?
Did the firewall-rules move somewhere else? I tried to open a port for ssh, but no matter what i write into the post-firewall, i can't get a connection to the router from the internet. A portforwarding to my laptop i set up in the web-if for another service does work, but doesn't show up in the post-firewall like it used to on the wl500w.
kind regards
Benj
Have anyone noticed a high load avaragae but no cpu activity?
I get this from top:
Is this normal? I had dd-wrt before oleg and it was a similar problem there. I think it was the upnp who did't work as it should there.top - 08:21:10 up 8:45, 0 users, load average: 2.00, 2.02, 2.10
Tasks: 44 total, 1 running, 43 sleeping, 0 stopped, 0 zombie
Cpu(s): 0.7%us, 0.7%sy, 0.0%ni, 98.4%id, 0.0%wa, 0.0%hi, 0.3%si, 0.0%st
Mem: 126204k total, 124124k used, 2080k free, 1448k buffers
Swap: 501912k total, 140k used, 501772k free, 103908k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1258 admin 15 0 1640 636 492 R 1.6 0.5 0:12.71 top
1254 admin 15 0 1232 556 424 S 0.3 0.4 0:01.06 dropbear
2 admin 10 -5 0 0 0 S 0.0 0.0 0:00.00 kthreadd
4 admin 10 -5 0 0 0 S 0.0 0.0 0:00.01 events/0
5 admin 10 -5 0 0 0 S 0.0 0.0 0:00.06 khelper
24 admin 10 -5 0 0 0 S 0.0 0.0 0:01.16 kblockd/0
50 admin 25 0 0 0 0 S 0.0 0.0 0:00.00 pdflush
51 admin 15 0 0 0 0 S 0.0 0.0 0:00.01 pdflush
52 admin 10 -5 0 0 0 S 0.0 0.0 0:00.77 kswapd0
53 admin 20 -5 0 0 0 S 0.0 0.0 0:00.00 aio/0
588 admin 20 -5 0 0 0 D 0.0 0.0 0:00.00 pptp-rx-0
589 admin 20 -5 0 0 0 D 0.0 0.0 0:00.00 pptp-tx-0
590 admin 10 -5 0 0 0 S 0.0 0.0 0:01.12 mtdblockd
669 admin 15 0 1616 296 240 S 0.0 0.2 0:00.01 klogd
672 admin 15 0 1008 208 148 S 0.0 0.2 0:00.01 eapd
675 admin 15 0 1192 376 240 S 0.0 0.3 0:00.29 nas
680 admin 15 0 1208 508 384 S 0.0 0.4 0:02.13 httpd
689 admin 10 -5 0 0 0 S 0.0 0.0 0:00.01 khubd
696 nobody 15 0 960 476 336 S 0.0 0.4 0:00.51 dnsmasq
731 admin 25 0 1400 352 280 S 0.0 0.3 0:00.00 rcamdmain
766 admin 11 -5 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_0
767 admin 10 -5 0 0 0 S 0.0 0.0 0:00.19 usb-storage
780 admin 11 -5 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_1
781 admin 10 -5 0 0 0 S 0.0 0.0 0:05.11 usb-storage
797 admin 15 0 1416 468 372 S 0.0 0.4 0:00.08 watchdog
809 admin 15 0 1176 324 252 S 0.0 0.3 0:00.14 dropbear
816 admin 15 0 1628 356 280 S 0.0 0.3 0:00.02 udhcpc
850 admin 10 -5 0 0 0 S 0.0 0.0 0:00.07 kjournald
851 admin 10 -5 0 0 0 S 0.0 0.0 0:00.02 kjournald
852 admin 11 -5 0 0 0 S 0.0 0.0 0:00.00 kjournald
868 admin 16 0 1616 312 256 S 0.0 0.2 0:00.15 syslogd
876 admin 15 0 11024 2340 1712 S 0.0 1.9 0:00.06 smbd
878 admin 15 0 6548 1632 1060 S 0.0 1.3 0:00.14 nmbd
882 admin 18 0 1052 344 284 S 0.0 0.3 0:00.00 cron
887 admin 21 0 1444 500 416 S 0.0 0.4 0:00.00 xinetd
889 admin 18 0 11024 996 368 S 0.0 0.8 0:00.00 smbd
899 admin 25 10 11124 6632 3512 S 0.0 5.3 0:00.05 transmission-da
900 admin 25 10 11124 6632 3512 S 0.0 5.3 0:00.00 transmission-da
901 admin 25 10 11124 6632 3512 S 0.0 5.3 1:14.09 transmission-da
1253 admin 18 0 11100 3176 2460 S 0.0 2.5 2:21.25 smbd
1 admin 18 0 1400 548 468 S 0.0 0.4 0:00.66 init
1255 admin 15 0 1624 480 412 S 0.0 0.4 0:00.01 sh
3 admin 34 19 0 0 0 S 0.0 0.0 0:00.18 ksoftirqd/0
1266 admin 15 0 1184 340 252 S 0.0 0.3 0:00.02 httpd
I've got som dead pptp processes what is that?
It is a ugly feature of obsolete kernel+Broadcom SDK. Unfortunately, Broadcom ignore anybody who wasn't buy their SDK.
Moreover, even DD-WRT team has some kind of full access this SDK, they can't (or don't want) to fix it.
It is accel-pptp daemon kernel threads, probably "top" shows incorrect status.I've got som dead pptp processes what is that?
Hey can I compile the upnp deamon in this firmware as well?
or does it need some configuration?
I kinda like my upnp portforwarding back![]()
I've been using a self-compiled version of Oleg 1.9.2.7-10 (2008-03-30) on a 500GP with RAID1 (based on this tread http://wl500g.info/showthread.php?t=15550 comments and modules md.o and raid1.o) with two 1Tb Iomega disks on RAID1.
I've just bought a RT-N16 and I want to re-build the system. This new router uses kernel 2.6. Can someone help me getting the right modules and tell me how to compile everything.
For what I notice the wiki on http://code.google.com/p/wl500g/wiki...CustomFirmware is only for Kernel 2.4
Thank's in advance
it's pretty much the same as for kernel 2.4
setting everything up for the wl500 series as in the how-to is pretty much the same, you just need these extra things:
you need kernel 2.6.22.19
just link it to "linux-2.6" in the /broadcom/src/linux dir.
then just checkout the svn rt-n branch into the dir... lets say /broadcom/src/rt-n
do "make kernel" and "make" in the rt-n dir
then cd into /broadcom/src/gateway dir and do "make" and "make install"
after that you can just grab the .trx from /broadcom/src/gateway/mipsel-uclibc
I hope that's a bit clear
ofcourse you can download my builds as well, then you just need to compile the kernel modules I guess
@wpte
Thanks a lot for your reply.
I have a few questions regarding which option should I follow:
1. compile the firmware
In here should I use the GPL_1927.zip sources (as stated in http://code.google.com/p/wl500g/wiki...stomFirmware)?
2. compile only the kernel modules (I think this one is preferable because is easier since I only need to update the firmware with your builds)
How can I compile only the required kernel modules?
Regards,
