Page 2 of 19 FirstFirst 123412 ... LastLast
Results 16 to 30 of 283
Thread: alpha rt-n firmware releases
    I have them ready now
    I've build the modules straight into the kernel itself, so they're loaded up automatically I think
    haven't try them out yet
    thanks it works
    The Netherlands - Eindhoven
    Quote Originally Posted by Foxem View Post
    thanks it works
    your web interface is still working?
    The web interface for samba configuration is working.
    Currently I don't have anything else installed.
    uuhh, it only shows a white page here
    or do you mean the samba config is the ONLY one working?
    I tried to set lighttpd with fastcgi and php and the web is not working
    nah, you should flash back to r1262 for now
    I'll compile the modules seperately and put them up for download
    how i can change the firmware if the web interface is not working?
    via tftp for example.
    If I use tftp method will all my current installations still be available?
    usually your settings are, but the flashfs is not saved.
    /opt is ofcourse still save
    you can also use the firmware recovery utility from asus if you want
    tftp is standard not activated in modern windows os...
    http://www.asus.com/product.aspx?P_I...ntent=download
    you can download it under utilities... doesn't work on linux btw.
    thanks
    should I wait today the cifs module for the lan mounting?
    thanks
    I just updated everything!
    r1274 is a working version now without the modules
    but I also uploaded the modules for download
    is not working with this new firmware
    and I tried to add modules with this command and is not working
    insmod /opt/modules/smbfs.ko
    insmod /opt/modules/cifs.ko
    Did you chmod them?
    chmod +x /opt/modules/smbfs.ko
    chmod +x /opt/modules/cifs.ko
    they load up fine here.
    I'm able to mount something with smbmount
    dunno if you use that?
    Did you chmod them?
    thx
    it's working with smbmount
    with the last firmware I used mount.cifs
    and I didn't know about chmod
    Last Post: 14-10-2009, 11:10
    Last Post: 13-07-2008, 01:28
    Last Post: 17-04-2008, 23:34
  4. Visit WL-500g Firmware Releases forum
    By Oleg in forum WL-550gE Firmware Discussion
    Last Post: 18-09-2006, 10:22
    Last Post: 21-10-2004, 14:55
