What is your firmware version?
Anyone ever had the problem that the wifi goes down?
It happened to me twice now.
once it kept broadcasting but didn't respond to any connection requests.
the second time right now it didn't broadcasted at all, while according to the router, the network was up.
I did wl down and wl up, after that it worked again
1.9.2.7-rtn-r1633
my friend has similair problems since R1484
http://code.google.com/p/wl500g/source/detail?r=1484
it's not that frequent, but now and then, it just stops working
I don't observe such behavior on my RT-N16, probably I never load WiFi as much as you. Anyway, WiFi driver itself wasn't modified, only many patches against kernel.
It will be best, if you can trace starting on which revision problem appears.
I know only the settings changed, and it does deliver a slightly better performance, at least better compatibility with older wifi products
I do have a wireless ethernet bridge (my old wl500w) which does try to keep the link alive, but it's nothing like a high load.
As I said, its since that revision I had those problems, just like a friend of mine
I'm not sure... can you advice me some commands I should run when it happens? to check the status etc? "wl status" probably, but maybe some advanced things I'm not aware of
In other words, you want to say me that r1478 is OK, and r1484 has problems?
sorry to disappoint you, but yes, I guess so
I Hate to bring things up like that
I mean, I don't think I configured it wrong: just everything on auto basicly, 40mhz, wpa-personal aes and wmm enabled.
I enabled wmm since it tripled the max speed on my wireless ethernet bridge
Maybe it's better to analyze it before jumping into actions? lly, what would you like to know when wifi stops working?
I will agree with you, in case of I have some debugging instruments.
Unfortunately, we can use only ioctl calls (wl binary).
First of all, check that are nas + eapd processes are in memory. Second, issue "wl status" - maybe is shows something. Also try to set wl0_obss_coex=0 - it is major change in r1484 commit
it just happened again this morning.
wl status:
eapd and nas are running.Code:SSID: "*******" Mode: Managed RSSI: 0 dBm noise: -76 dBm Channel: 4 BSSID: *************** Capability: ESS ShortSlot Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ] 802.11N Capable: Chanspec: 2.4GHz channel 4 40MHz (0x2e04) Control channel: 6 802.11N Capabilities: Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 32 ]
wlan led is on, but doesn't blink when I try to connect.
seems to be happening overnight all the time
I haven't tried "wl0_obss_coex=0" yet, but that's pretty much the same as R1448 I guess.
Anyway, my router was running for over 9 days, so maybe I need to wait that long again before it happens
I have an active laptop cooler under my router, so everything of this shouldn't happen because of the overheating in the summer
I wanted to try out of switching on GSO has some good impact to TCP performance but noticed that ethtool does not exist for the router. Is it really so?
So my plan was something like:
I've checked in include/linux/netdevice.h that GSO flag exists (NETIF_F_GSO):Code:ethtool -K eth0 gso on
and this should work without ethernet driver/HW support.Code:/* Net device features */ unsigned long features; #define NETIF_F_SG 1 /* Scatter/gather IO. */ #define NETIF_F_IP_CSUM 2 /* Can checksum only TCP/UDP over IPv4. */ #define NETIF_F_NO_CSUM 4 /* Does not require checksum. F.e. loopack. */ #define NETIF_F_HW_CSUM 8 /* Can checksum all the packets. */ #define NETIF_F_HIGHDMA 32 /* Can DMA to high memory. */ #define NETIF_F_FRAGLIST 64 /* Scatter/gather IO. */ #define NETIF_F_HW_VLAN_TX 128 /* Transmit VLAN hw acceleration */ #define NETIF_F_HW_VLAN_RX 256 /* Receive VLAN hw acceleration */ #define NETIF_F_HW_VLAN_FILTER 512 /* Receive filtering on VLAN */ #define NETIF_F_VLAN_CHALLENGED 1024 /* Device cannot handle VLAN packets */ #define NETIF_F_GSO 2048 /* Enable software GSO. */ #define NETIF_F_LLTX 4096 /* LockLess TX */
Also ethtool_set_gso function exists in net/core/ethtool.c
Is there any way to switch it on without writing code for ioctl call?
Seems like ethtool 2.6.34 doesn't work on rt-n16
it works only for br0Code:[admin@router-n /tmp]$ ./ethtool -K eth0 gso on Cannot set device generic segmentation offload settings: Invalid argument [admin@router-n /tmp]$ ./ethtool -K vlan2 gso on Cannot set device generic segmentation offload settings: Invalid argument [admin@router-n /tmp]$ ./ethtool -k vlan2 Offload parameters for vlan2: Cannot get device rx csum settings: Invalid argument Cannot get device tx csum settings: Invalid argument Cannot get device scatter-gather settings: Invalid argument Cannot get device tcp segmentation offload settings: Invalid argument Cannot get device udp large send offload settings: Invalid argument Cannot get device generic segmentation offload settings: Invalid argument Cannot get device flags: Invalid argument Cannot get device GRO settings: Invalid argument no offload info available
so, ethtool doesn't support broadcom eth devicesCode:[admin@router-n /tmp]$ ./ethtool -K br0 gso on [admin@router-n /tmp]$ ./ethtool -k br0 Offload parameters for br0: Cannot get device rx csum settings: Operation not supported Cannot get device udp large send offload settings: Operation not supported Cannot get device flags: Operation not supported Cannot get device GRO settings: Operation not supported rx-checksumming: off tx-checksumming: off scatter-gather: off tcp-segmentation-offload: off udp-fragmentation-offload: off generic-segmentation-offload: on generic-receive-offload: off large-receive-offload: off ntuple-filters: off receive-hashing: off
ASUS WL5xx: FW 1.9.2.7-d-rXXXX / îáñóæäåíèå ïðîøèâêè [RU] / firmware discussion [EN] | bip irc proxy
ASUS RT-N1x: FW 1.9.2.7-rtn-rXXXX / îáñóæäåíèå ïðîøèâêè [RU] / firmware discussion [EN] | fake ident daemon
