Page 3 of 19 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 283
Thread: alpha rt-n firmware releases
    Still I do not understand why when I use
    mount tab
    smb tab
    in the commands list doesn't apear mount.cifs and smbfs
    I modified the file "/usr/local/sbin/post-mount" but the automount is not working.
    #! /bin/sh
    /opt/etc/init.d/rc.unslung start
    insmod /opt/modules/smbfs.ko
    sleep 6
    smbmount //192.168.109.130/torrent /opt/torrent/ -o username=Foxem,password=XXXX
    Then I created in /opt/etc/init.d/S10smbfs
    sleep 6
    could you please tell me what I am doing wrong?
    The Netherlands - Eindhoven
    Quote Originally Posted by Foxem View Post
    Sorry, I'm not well known with network share mounting
    perhaps you could do the module loading before rc.unslung start?
    I found this working solution
    sleep 10
    /opt/bin/smbmount //192.168.109.130/torrent /opt/torrent/ -o username=user,password=XXXXX
    sleep 10
    ah yes ofcourse! (silly me)
    that's because it's not located in the firmware
    Did the firewall-rules move somewhere else? I tried to open a port for ssh, but no matter what i write into the post-firewall, i can't get a connection to the router from the internet. A portforwarding to my laptop i set up in the web-if for another service does work, but doesn't show up in the post-firewall like it used to on the wl500w.
    kind regards
    Benj
    Quote Originally Posted by bef View Post
    kind regards
    Benj
    iptables -I INPUT -p tcp --dport 22 -j ACCEPT (22 default port, change it if you use other)
    iptables -L -n to see the applied rules INPUT chain. (1st chain)
    Quote Originally Posted by hggomes View Post
    Ok, perhaps i shouldn't mess with the firewall at 2 o'clock in the morning and not look at it again. -.-
    A small typo later and it works, thank you
    high load,no cpu activity
    Have anyone noticed a high load avaragae but no cpu activity?
    I get this from top:
    top - 08:21:10 up 8:45, 0 users, load average: 2.00, 2.02, 2.10
    Tasks: 44 total, 1 running, 43 sleeping, 0 stopped, 0 zombie
    Cpu(s): 0.7%us, 0.7%sy, 0.0%ni, 98.4%id, 0.0%wa, 0.0%hi, 0.3%si, 0.0%st
    Mem: 126204k total, 124124k used, 2080k free, 1448k buffers
    Swap: 501912k total, 140k used, 501772k free, 103908k cached
    PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
    1258 admin 15 0 1640 636 492 R 1.6 0.5 0:12.71 top
    1254 admin 15 0 1232 556 424 S 0.3 0.4 0:01.06 dropbear
    2 admin 10 -5 0 0 0 S 0.0 0.0 0:00.00 kthreadd
    4 admin 10 -5 0 0 0 S 0.0 0.0 0:00.01 events/0
    5 admin 10 -5 0 0 0 S 0.0 0.0 0:00.06 khelper
    24 admin 10 -5 0 0 0 S 0.0 0.0 0:01.16 kblockd/0
    50 admin 25 0 0 0 0 S 0.0 0.0 0:00.00 pdflush
    51 admin 15 0 0 0 0 S 0.0 0.0 0:00.01 pdflush
    52 admin 10 -5 0 0 0 S 0.0 0.0 0:00.77 kswapd0
    53 admin 20 -5 0 0 0 S 0.0 0.0 0:00.00 aio/0
    588 admin 20 -5 0 0 0 D 0.0 0.0 0:00.00 pptp-rx-0
    589 admin 20 -5 0 0 0 D 0.0 0.0 0:00.00 pptp-tx-0
    590 admin 10 -5 0 0 0 S 0.0 0.0 0:01.12 mtdblockd
    669 admin 15 0 1616 296 240 S 0.0 0.2 0:00.01 klogd
    672 admin 15 0 1008 208 148 S 0.0 0.2 0:00.01 eapd
    675 admin 15 0 1192 376 240 S 0.0 0.3 0:00.29 nas
    680 admin 15 0 1208 508 384 S 0.0 0.4 0:02.13 httpd
    689 admin 10 -5 0 0 0 S 0.0 0.0 0:00.01 khubd
    696 nobody 15 0 960 476 336 S 0.0 0.4 0:00.51 dnsmasq
    731 admin 25 0 1400 352 280 S 0.0 0.3 0:00.00 rcamdmain
    766 admin 11 -5 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_0
    767 admin 10 -5 0 0 0 S 0.0 0.0 0:00.19 usb-storage
    780 admin 11 -5 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_1
    781 admin 10 -5 0 0 0 S 0.0 0.0 0:05.11 usb-storage
    797 admin 15 0 1416 468 372 S 0.0 0.4 0:00.08 watchdog
    809 admin 15 0 1176 324 252 S 0.0 0.3 0:00.14 dropbear
    816 admin 15 0 1628 356 280 S 0.0 0.3 0:00.02 udhcpc
    850 admin 10 -5 0 0 0 S 0.0 0.0 0:00.07 kjournald
    851 admin 10 -5 0 0 0 S 0.0 0.0 0:00.02 kjournald
    852 admin 11 -5 0 0 0 S 0.0 0.0 0:00.00 kjournald
    868 admin 16 0 1616 312 256 S 0.0 0.2 0:00.15 syslogd
    876 admin 15 0 11024 2340 1712 S 0.0 1.9 0:00.06 smbd
    878 admin 15 0 6548 1632 1060 S 0.0 1.3 0:00.14 nmbd
    882 admin 18 0 1052 344 284 S 0.0 0.3 0:00.00 cron
    887 admin 21 0 1444 500 416 S 0.0 0.4 0:00.00 xinetd
    889 admin 18 0 11024 996 368 S 0.0 0.8 0:00.00 smbd
    899 admin 25 10 11124 6632 3512 S 0.0 5.3 0:00.05 transmission-da
    900 admin 25 10 11124 6632 3512 S 0.0 5.3 0:00.00 transmission-da
    901 admin 25 10 11124 6632 3512 S 0.0 5.3 1:14.09 transmission-da
    1253 admin 18 0 11100 3176 2460 S 0.0 2.5 2:21.25 smbd
    1 admin 18 0 1400 548 468 S 0.0 0.4 0:00.66 init
    1255 admin 15 0 1624 480 412 S 0.0 0.4 0:00.01 sh
    3 admin 34 19 0 0 0 S 0.0 0.0 0:00.18 ksoftirqd/0
    1266 admin 15 0 1184 340 252 S 0.0 0.3 0:00.02 httpd
    Is this normal? I had dd-wrt before oleg and it was a similar problem there. I think it was the upnp who did't work as it should there.
    I've got som dead pptp processes what is that?
    Nov 2006
    Quote Originally Posted by ofverstedt View Post
    It is a ugly feature of obsolete kernel+Broadcom SDK. Unfortunately, Broadcom ignore anybody who wasn't buy their SDK.
    Moreover, even DD-WRT team has some kind of full access this SDK, they can't (or don't want) to fix it.
    It is accel-pptp daemon kernel threads, probably "top" shows incorrect status.
    Hey can I compile the upnp deamon in this firmware as well?
    or does it need some configuration?
    I kinda like my upnp portforwarding back
    RAID1 on RT-N16
    I've been using a self-compiled version of Oleg 1.9.2.7-10 (2008-03-30) on a 500GP with RAID1 (based on this tread http://wl500g.info/showthread.php?t=15550 comments and modules md.o and raid1.o) with two 1Tb Iomega disks on RAID1.
    I've just bought a RT-N16 and I want to re-build the system. This new router uses kernel 2.6. Can someone help me getting the right modules and tell me how to compile everything.
    For what I notice the wiki on http://code.google.com/p/wl500g/wiki...CustomFirmware is only for Kernel 2.4
    Thank's in advance
    it's pretty much the same as for kernel 2.4
    setting everything up for the wl500 series as in the how-to is pretty much the same, you just need these extra things:
    you need kernel 2.6.22.19
    just link it to "linux-2.6" in the /broadcom/src/linux dir.
    then just checkout the svn rt-n branch into the dir... lets say /broadcom/src/rt-n
    do "make kernel" and "make" in the rt-n dir
    then cd into /broadcom/src/gateway dir and do "make" and "make install"
    after that you can just grab the .trx from /broadcom/src/gateway/mipsel-uclibc
    I hope that's a bit clear
    ofcourse you can download my builds as well, then you just need to compile the kernel modules I guess
    Nov 2006
    You tried to ask "how to get upnp works"?
    Sorry, didn't test it yet due to other high-priority tasks (stability, WPA2, etc.). I apologize problem occurs because many kernel calls changed in 2.6. So, some code modifications required.
    @wpte
    Thanks a lot for your reply.
    I have a few questions regarding which option should I follow:
    1. compile the firmware
    In here should I use the GPL_1927.zip sources (as stated in http://code.google.com/p/wl500g/wiki...stomFirmware)?
    2. compile only the kernel modules (I think this one is preferable because is easier since I only need to update the firmware with your builds )
    How can I compile only the required kernel modules?
    Regards,
    Last Post: 14-10-2009, 12:10
    Last Post: 13-07-2008, 02:28
    Last Post: 18-04-2008, 00:34
  4. Visit WL-500g Firmware Releases forum
    By Oleg in forum WL-550gE Firmware Discussion
    Last Post: 18-09-2006, 11:22
    Last Post: 21-10-2004, 15:55
