It should work, try repluging cam and rebooting router.Originally Posted by WlanMan
Probably.- Can you make LPR, Waveserver, Jetdirekt printing jobs and maybe infosvr disable over web interface ?
Could you please try disabling "Bidirectional communications" in the printer properties of your windows box?Originally Posted by FIB
Already done that - no change, sorry.
btw, do you use RAW printing?Originally Posted by FIB
Yes, RAW port 9100
Start telnet/ssh session to router and type this:Originally Posted by FIB
And try printing again.Code:killall p910nd p910nd -f /dev/usb/lp0 0
That makes me able to print again, great. Can I insert the codelines in post-boot to make it a permanent fix for me?
yes, sure. as seems drivers do not expect bidirectional communication, so printing hangs at some point.
I would like to know if anyone has any positive effect with bidirectional RAW printing. Otherwise I will remove it, as it only causes problems as seems.
Anyway, thanks for the trick - and firmware.
What is ment by this? Is this a fix for the bug where upnp ports are never closed?Originally Posted by Oleg
BTW, Thanks for the good work!
BR, René
I'm unable to test currently, hp lost my printer when repairing.. still waiting for a new oneOriginally Posted by Oleg
Well, it disables using of old upnp rules if you've disabled upnp in the router.Originally Posted by rej
With my hp dj 3420 I've seen bidir communications, but windows still does not report any usefull info, such as ink level...Originally Posted by Antiloop
Nope. Tried several times. Had this isue with R4 also, green picture but i think no syslog entrys. Just had no time to tell here.Originally Posted by Oleg
The Cam worked on a x86 linux and windows box, so i am curious what the problem can be on 500g ...
Please, can you tell me what the wlan_update tool does, i started it acidentely (no --help parameter check ) and now have afterburner supported. I know it patches something in the chipset eeprom, is this possible harmfull and is it reversible ?
What does this mean it maybe fixes the range problem ?
One last, is the output of "free" meaningfull in any way ? Free mem value changes in a way that seems strange when loading and killing software.
Also samba is not working, deamons die without notice but i may have missed some configuration point.
Greets
Nice release after all.
Same for me with a Canon i865.Originally Posted by Oleg
