При установке kismet требует libpcap, а его в репозитории нет. Пробую собрать.
Действия (кратко):
1. ipkg-opt install optware-devel
2. svn co http://svn.nslu2-linux.org/svnroot/optware/trunk optware
3. make directories
4. make ipkg-utils
5. Беру за основу маки-файл libpcap.mk. Немного правлю:
PHP Code:
# libpcap
# You must replace "libpcap" and "LIBPCAP" with the lower case name and
# upper case name of your new package. Some places below will say
# "Do not change this" - that does not include this global change,
# which must always be done to ensure we have unique names.
# LIBPCAP_VERSION, LIBPCAP_SITE and LIBPCAP_SOURCE define
# the upstream location of the source code for the package.
# LIBPCAP_DIR is the directory which is created when the source
# archive is unpacked.
# LIBPCAP_UNZIP is the command used to unzip the source.
# It is usually "zcat" (for .gz) or "bzcat" (for .bz2)
# You should change all these variables to suit your package.
LIBPCAP_SITE=http://www.tcpdump.org/release
LIBPCAP_VERSION=0.9.7
LIBPCAP_SOURCE=libpcap-$(LIBPCAP_VERSION).tar.gz
LIBPCAP_DIR=libpcap-$(LIBPCAP_VERSION)
LIBPCAP_UNZIP=zcat
# LIBPCAP_IPK_VERSION should be incremented when the ipk changes.
LIBPCAP_IPK_VERSION=2
# LIBPCAP_PATCHES should list any patches, in the the order in
# which they should be applied to the source code.
#LIBPCAP_PATCHES=$(LIBPCAP_SOURCE_DIR)/configure.patch
# If the compilation of the package requires additional
# compilation or linking flags, then list them here.
LIBPCAP_CPPFLAGS=
LIBPCAP_LDFLAGS=
ifneq (no, $(IPV6))
LIBPCAP_CONFIGURE_OPTS=--enable-ipv6
endif
# LIBPCAP_BUILD_DIR is the directory in which the build is done.
# LIBPCAP_SOURCE_DIR is the directory which holds all the
# patches and ipkg control files.
# LIBPCAP_IPK_DIR is the directory in which the ipk is built.
# LIBPCAP_IPK is the name of the resulting ipk files.
# You should not change any of these variables.
LIBPCAP_BUILD_DIR=$(BUILD_DIR)/libpcap
LIBPCAP_SOURCE_DIR=$(SOURCE_DIR)/libpcap
LIBPCAP_IPK_DIR=$(BUILD_DIR)/libpcap-$(LIBPCAP_VERSION)-ipk
LIBPCAP_IPK=$(BUILD_DIR)/libpcap_$(LIBPCAP_VERSION)-$(LIBPCAP_IPK_VERSION)_$(TARGET_ARCH).ipk
# This is the dependency on the source code. If the source is missing,
# then it will be fetched from the site using wget.
$(DL_DIR)/$(LIBPCAP_SOURCE):
$(WGET) -P $(DL_DIR) $(LIBPCAP_SITE)/$(LIBPCAP_SOURCE)
# The source code depends on it existing within the download directory.
# This target will be called by the top level Makefile to download the
# source code's archive (.tar.gz, .bz2, etc.)
libpcap-source: $(DL_DIR)/$(LIBPCAP_SOURCE) $(LIBPCAP_PATCHES)
# This target unpacks the source code in the build directory.
# If the source archive is not .tar.gz or .tar.bz2, then you will need
# to change the commands here. Patches to the source code are also
# applied in this target as required.
# This target also configures the build within the build directory.
# Flags such as LDFLAGS and CPPFLAGS should be passed into configure
# and NOT $(MAKE) below. Passing it to configure causes configure to
# correctly BUILD the Makefile with the right paths, where passing it
# to Make causes it to override the default search paths of the compiler.
# If the compilation of the package requires other packages to be staged
# first, then do that first (e.g. "$(MAKE) <bar>-stage <baz>-stage").
$(LIBPCAP_BUILD_DIR)/.configured: $(DL_DIR)/$(LIBPCAP_SOURCE) $(LIBPCAP_PATCHES)
# $(MAKE) <bar>-stage <baz>-stage
rm -rf $(BUILD_DIR)/$(LIBPCAP_DIR) $(LIBPCAP_BUILD_DIR)
$(LIBPCAP_UNZIP) $(DL_DIR)/$(LIBPCAP_SOURCE) | tar -C $(BUILD_DIR) -xvf -
# cat $(LIBPCAP_PATCHES) | patch -d $(BUILD_DIR)/$(LIBPCAP_DIR) -p1
mv $(BUILD_DIR)/$(LIBPCAP_DIR) $(LIBPCAP_BUILD_DIR)
(cd $(LIBPCAP_BUILD_DIR); \
$(TARGET_CONFIGURE_OPTS) \
CPPFLAGS="$(STAGING_CPPFLAGS) $(LIBPCAP_CPPFLAGS)" \
LDFLAGS="$(STAGING_LDFLAGS) $(LIBPCAP_LDFLAGS)" \
./configure \
--build=$(GNU_HOST_NAME) \
--host=$(GNU_TARGET_NAME) \
--target=$(GNU_TARGET_NAME) \
--with-pcap=linux \
--prefix=/opt \
$(LIBPCAP_CONFIGURE_OPTS) \
ac_cv_linux_vers=2.4.22 \
touch $(LIBPCAP_BUILD_DIR)/.configured
libpcap-unpack: $(LIBPCAP_BUILD_DIR)/.configured
# This builds the actual binary. You should change the target to refer
# directly to the main binary which is built.
$(LIBPCAP_BUILD_DIR)/libpcap.a: $(LIBPCAP_BUILD_DIR)/.configured
$(MAKE) -C $(LIBPCAP_BUILD_DIR)
# You should change the dependency to refer directly to the main binary
# which is built.
libpcap: $(LIBPCAP_BUILD_DIR)/libpcap.a
# If you are building a library, then you need to stage it too.
$(STAGING_DIR)/opt/lib/libpcap.a: $(LIBPCAP_BUILD_DIR)/libpcap.a
$(MAKE) -C $(LIBPCAP_BUILD_DIR) DESTDIR=$(STAGING_DIR) install
libpcap-stage: $(STAGING_DIR)/opt/lib/libpcap.a
# This rule creates a control file for ipkg. It is no longer
# necessary to create a seperate control file under sources/pound
$(LIBPCAP_IPK_DIR)/CONTROL/control:
@install -d $(LIBPCAP_IPK_DIR)/CONTROL
@rm -f $@
@echo "Package: libpcap" >>$@
@echo "Architecture: $(TARGET_ARCH)" >>$@
@echo "Priority: $(LIBPCAP_PRIORITY)" >>$@
@echo "Section: $(LIBPCAP_SECTION)" >>$@
@echo "Version: $(LIBPCAP_VERSION)-$(LIBPCAP_IPK_VERSION)" >>$@
@echo "Maintainer: $(LIBPCAP_MAINTAINER)" >>$@
@echo "Source: $(LIBPCAP_SITE)/$(LIBPCAP_SOURCE)" >>$@
@echo "Description: $(LIBPCAP_DESCRIPTION)" >>$@
@echo "Depends: $(LIBPCAP_DEPENDS)" >>$@
@echo "Suggests: $(LIBPCAP_SUGGESTS)" >>$@
@echo "Conflicts: $(LIBPCAP_CONFLICTS)" >>$@
# This builds the IPK file.
# Binaries should be installed into $(LIBPCAP_IPK_DIR)/opt/sbin or $(LIBPCAP_IPK_DIR)/opt/bin
# (use the location in a well-known Linux distro as a guide for choosing sbin or bin).
# Libraries and include files should be installed into $(LIBPCAP_IPK_DIR)/opt/{lib,include}
# Configuration files should be installed in $(LIBPCAP_IPK_DIR)/opt/etc/libpcap/...
# Documentation files should be installed in $(LIBPCAP_IPK_DIR)/opt/doc/libpcap/...
# Daemon startup scripts should be installed in $(LIBPCAP_IPK_DIR)/opt/etc/init.d/S??libpcap
# You may need to patch your application to make it use these locations.
$(LIBPCAP_IPK): $(LIBPCAP_BUILD_DIR)/libpcap.a
rm -rf $(LIBPCAP_IPK_DIR) $(BUILD_DIR)/libpcap_*_$(TARGET_ARCH).ipk
$(MAKE) -C $(LIBPCAP_BUILD_DIR) DESTDIR=$(LIBPCAP_IPK_DIR) install
$(MAKE) $(LIBPCAP_IPK_DIR)/CONTROL/control
echo $(LIBPCAP_CONFFILES) | sed -e 's/ /\n/g' > $(LIBPCAP_IPK_DIR)/CONTROL/conffiles
cd $(BUILD_DIR); $(IPKG_BUILD) $(LIBPCAP_IPK_DIR)
# This is called from the top level makefile to create the IPK file.
libpcap-ipk: $(LIBPCAP_IPK)
# This is called from the top level makefile to clean all of the built files.
libpcap-clean:
-$(MAKE) -C $(LIBPCAP_BUILD_DIR) clean
# This is called from the top level makefile to clean all dynamically created
# directories.
libpcap-dirclean:
rm -rf $(BUILD_DIR)/$(LIBPCAP_DIR) $(LIBPCAP_BUILD_DIR) $(LIBPCAP_IPK_DIR) $(LIBPCAP_IPK)
6. make libpcap-ipk
Когда доходит до сборки IPK - возникают ошибки (вложение содержит полный лог):
PHP Code:
make[1]: Leaving directory `/tmp/harddisk/optware/builds/libpcap'
make /tmp/harddisk/optware/builds/libpcap-0.9.7-ipk/CONTROL/control
make[1]: Entering directory `/tmp/harddisk/optware'
make[1]: Leaving directory `/tmp/harddisk/optware'
echo | sed -e 's/ /\n/g' > /tmp/harddisk/optware/builds/libpcap-0.9.7-ipk/CONTROL/conffiles
cd /tmp/harddisk/optware/builds; PATH=/tmp/harddisk/optware/staging/opt/bin:/tmp/harddisk/optware/staging/bin:/opt/bin:/opt/sbin:/bin:/sbin:/usr/bin:/usr/sbin TAR_OPTIONS=--format=ustar ipkg-build -c -o root -g root /tmp/harddisk/optware/builds/libpcap-0.9.7-ipk
/tmp/harddisk/optware/staging/bin/ipkg-build: /tmp/harddisk/optware/staging/bin/ipkg-build: 197: getopts: not found
/tmp/harddisk/optware/staging/bin/ipkg-build: shift: 200: Illegal number: -1
make: *** [/tmp/harddisk/optware/builds/libpcap_0.9.7-2_mipsel.ipk] Error 2
Пожалуйста укажите на мои ошибки.
