Hi.
I just installed 1.9.2.7-d-r1087 version of this great firmware, connected a usb flash stick, formatted it and installed some software.
I want to use a bluetooth dongle with the router.
I installed bluez-utils and bluez-libs and when I do hcitool scan it says "Segmentation fault". Can someone please explain how to load bluetooth modules or bluetooth setup ?
Thank you.
