Results 1 to 15 of 22
Thread: [USB] Audio/Sound Device
    Nov 2003
    Eindhoven
    The idea is to create in the near future a database with reported working and non working devices
    please report here if you have a device that WORKS or does NOT WORK
    please also report if you have upgraded and the device stays working or not
    your post should look like this:
    Tested: WORKING!
    Model: WL-500g
    Firmware: 1.6.5.2 / 1.6.5.3
    Device
    Brandname: HP (Hewlett Packard)
    Brandtype: Laserjet 2200DN
    USB Interface: 1.1 compliant
    URL To manufacturer: http://www.hp.com
    URL To product: http://h10010.www1.hp.com/wwpc/us/e...6263-28861.html
    Application used to test: used Asus tools or modified (describe please) tools
    Tested: NOT WORKING!
    Model: WL-500gx
    Firmware: 1.9.2.7-4
    Device
    Brandname: Creative
    Brandtype: Soundblaster Audigy 2 NX
    USB Interface: 2.0 compliant
    URL To manufacturer: http://www.creative.com/
    URL To product: http://www.soundblaster.com/products/audigy2NX/
    Both audio.o and ALSA drivers complain about some "synch pipe" problem
    Maplins 5.1 USB audio adaptor
    Tested: WORKING!
    Model: WL-500g
    Firmware: 1.9.2.7-4
    Device
    Brandname: Yoga
    Brandtype: AD-100
    URL To product:available at maplins
    Works fine with "asus speaker express" plugin for M$ media player (tested on MP9)
    Device costs £12.99. Has one socket only, for headphone type audio jack from your speakers etc (or any other audio device of your choice). Has USB cable of aprox 0.5m length. Has an on-off switch - recommend turning on before testing to avoid frustration .
    Grabbing this from an older thread, haven't tried these devices myself. Thus I can't include much info. Maybe someone else will fill in the blanks.
    Thread: http://wl500g.info/showthread.php?postid=10953#poststop
    Sony CAV-U5 USB Digital converter
    Tested: WORKING!
    Sitecom CN-126 USB 5.1 audio adaptor
    Tested: WORKING! (with Madplay, not the ASUS plugin?)
    May 2005
    Netherlands
    Working!
    Tested: WORKING!
    Model: WL-500gd
    Firmware: 1.9.4.0
    Device:
    Brandname: Trust
    Brandtype: SoundForce 2012
    URL To manufacturer: http://www.trust.com
    URL To product: http://www.trust.com/products/product.aspx?artnr=14189
    Comodow PD552 - Working with Asus plugin
    Tested: WORKING!
    Model: WL-500g
    Firmware: Oleg's 1.9.2.7-5a
    Device
    Brandname: Comodow (sold as noname on net auction)
    Brandtype: PD552 ("USB 3D SOUND")
    USB Interface: USB 2.0 full speed
    URL To manufacturer: http://www.comodow.com
    URL To product: http://www.comodow.com/en/enpd552.htm
    This is the cheapest thing I've found on the market, and it works, also with an USB hub.
    Application used to test: I used the Asus Speaker Express Plugin for Media Player 9, which comes bundled with firmware version 1.9.2.7. The plugin makes Media Player 10 seems to crash a lot here, and every time it does, the plugin is turned off. The problem may be related to the firewall (ZoneAlarm). Another interesting detail is that the music streamed through router seems to be about half a second ahead of the regular speakers.
    I'm streaming the music over the wireless network. If I download a webpage the audio stream will halt temporarly. I have not tested this wired.
    I will now look into testing the other streaming alternatives as described elsewhere on this site, with a focus on playing from the USB drive.
    .tommyb
    Tested: WORKING!
    Model: WL-500g Deluxe
    Firmware: 1.9.2.7-6b
    Device
    Brandname: LineX
    Brandtype: USB FM Transmitter
    URL To manufacturer: ?
    URL To product:
    http://www.themindfactory.com/Produc...linex_usb.html
    http://www.thinkgeek.com/electronics/audio/6f4e/
    Using WMP10.
    Sep 2005
    Tested: WORKING WITH PROBLEMS
    Model: WL-500gd
    Firmware: Oleg's 1.9.2.7-6a
    Device:
    Brandname: Trust
    Brandtype: SoundForce 2010
    URL To product: http://www.trust.com/products/product.aspx?artnr=14188
    The device is supported by the kernel, but i get annoying glitches or gaps during playback. See post http://wl500g.info/showthread.php?t=3388.
    Not recommended.
    Sep 2005
    Conrad stereo USB audio adapter
    Tested: WORKING!
    Model: WL-500gx
    Device
    Brandname: Conrad
    Brandtype: Artikel-Nr.: 994248 - 62
    URL To manufacturer: http://www.conrad.de
    URL To product: http://www1.conrad.de/conrad/layout2...refview=search
    Application used to test: madplay resamples at 48khz, sounds good.
    Tested: WORKING!
    Model: WL-500gx
    Device
    Brandname: self build - see here
    Brandtype: PCM2902E-Stereo Audio CODEC w/USB Interface
    URL To manufacturer: http://ti.com/
    URL To product: http://focus.ti.com/docs/prod/folder...t/pcm2903.html
    Application used to test: I used the Asus Speaker Express Plugin for Media Player 10
    Tested: WORKING!
    Model: WL-500g
    Firmware: 1.9.2.7
    Device
    Brandname: HE280B
    Brandtype: USB 2.0
    URL To manufacturer: http://www.geeks.com/details.asp?invtid=HE-280B
    I've only tested this with the media player plugin and it works perfect.
    Hama Virtual 5.1 Audio Adapter
    Tested: WORKING!
    Model: WL-500gx (Deluxe V)
    Firmware: 1.9.2.7-6c-pre5
    Device
    Brandname: Hama
    Brandtype: 0005711 Virtual 5.1 Audio Adapter
    USB Interface: 1.1 and 2.0 compliant
    URL To manufacturer: http://www.hama.de
    URL To product:http://www.hama.de/portal/articleId*116368/action*2563
    Output works fine tested with madplay / Input untested
    Device costs <15EUR
    Tested: WORKING (with patch)
    Model: WL-500g
    Requires a patch to the usb audio kernel module!
    Device
    Brandname: Creative
    Feb 2005
    Cologne, Germany
    Thumbs up Works!
    Tested: WORKING!
    Model: WL-500g
    Firmware: 1.9.2.7-7b
    Device
    Brandname: Hercules
    Brandtype: Gamesurround Muse Pocket LT USB
    URL To manufacturer: http://www.hercules.com
    URL To product: http://europe.hercules.com/showpage....&p=108&b=0&f=0
    Tested with EsounD daemon and Winamp (with patched ESD output plugin). Esd runs at 48000Hz sampling rate.
    Feb 2006
    Bangalore,India
    Exclamation
    Quote Originally Posted by daniel632
    Model: WL-500g
    Device
    Brandname: Creative
    I am trying to get my SoundBlaster Audigy2NX working, but i'm not successful.
    Herewith i'm attcahcing the log for reference;
    [admin@wl500g root]$ cd /tmp
    [admin@wl500g /tmp]$ ls
    etc lp0 resolv.conf waveserver.info
    harddisk nas.lan.conf syslog.log
    local nas.wan.conf var
    [admin@wl500g /tmp]$ wget ftp://192.168.1.14/audio.o
    Connecting to 192.168.1.14[192.168.1.14]:21
    audio.o 100% |*****************************| 68852 --:-- ETA
    [admin@wl500g /tmp]$ wget ftp://192.168.1.14/esd
    esd 100% |*****************************| 90568 --:-- ETA
    [admin@wl500g /tmp]$ chmod 777 esd
    [admin@wl500g /tmp]$ ps
    PID Uid VmSize Stat Command
    1 admin 560 S /sbin/init
    2 admin SW [keventd]
    3 admin SWN [ksoftirqd_CPU0]
    4 admin SW [kswapd]
    5 admin SW [bdflush]
    6 admin SW [kupdated]
    7 admin SW [mtdblockd]
    43 admin 320 S telnetd
    48 admin 380 S httpd
    51 admin 388 S syslogd -m 0 -O /tmp/syslog.log -S -l 7
    53 admin 344 S klogd
    54 admin SW [khubd]
    67 admin 276 S lpd
    69 admin 260 S p9100d -f /dev/usb/lp0 0
    71 admin 260 S p9101d -f /dev/printers/0 1
    74 admin 352 S waveservermain
    76 admin 88 S < waveserver
    80 admin 324 S infosvr br0
    81 admin 448 S watchdog
    83 admin 348 S ntp
    92 admin 540 S -sh
    99 admin 392 R ps
    [admin@wl500g /tmp]$ kill waveservermain
    kill: 7: Illegal number: waveservermain
    [admin@wl500g /tmp]$ killall waveservermain
    [admin@wl500g /tmp]$ rmmod audio
    [admin@wl500g /tmp]$ insmod audio.o
    Using audio.o
    [admin@wl500g /tmp]$ ./esd -d /dev/sound/dsp -tcp -public &
    [admin@wl500g /tmp]$ - using device /dev/sound/dsp
    unsupported playback rate: 44100
    Audio device open for 44.1Khz, stereo, 16bit failed
    Trying 44.1Khz, 8bit stereo.
    Audio device open for 44.1Khz, stereo, 8bit failed
    Trying 48Khz, 16bit stereo.
    4 admin SW [kswapd]
    54 admin SW [khubd]
    67 admin 276 S lpd
    83 admin 348 S ntp
    92 admin 540 S -sh
    104 admin 340 S ./esd -d /dev/sound/dsp -tcp -public
    105 admin 392 R ps
    more over, the esd plugin says server error even if i configure the proper ip address of the wl500g in winamp(ver3) plugin config.
    pls help me out
  1. USB Sound streamer, possible?
    By hertzsae in forum WL-500g Q&A
    Last Post: 25-02-2007, 16:00
  2. Wl-Hdd as USB device?
    By Reflex in forum WL-HDD Q&A
    Last Post: 12-07-2005, 17:27
  3. Audio device instead of web camera??
    By tim in forum WL-500g Q&A
    Last Post: 21-06-2005, 20:06
  4. Replies: 0
    Last Post: 05-05-2005, 20:20
  5. Replies: 0
    Last Post: 09-11-2004, 00:45
