вот бутлог
Jan 1 02:00:02 syslogd started: BusyBox v1.15.3
Jan 1 02:00:02 kernel: klogd started: BusyBox v1.15.3 (2010-01-24 20:40:42 MSK)
Jan 1 02:00:02 kernel: CPU revision is: 00029029
Jan 1 02:00:02 kernel: Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Jan 1 02:00:02 kernel: Primary data cache 16kB, 2-way, linesize 16 bytes.
Jan 1 02:00:02 kernel: Linux version 2.4.37.7 (root@localhost) (gcc version 3.4.6) #1 2010-01-24 20:44:23 MSK
Jan 1 02:00:02 kernel: Setting the PFC to its default value
Jan 1 02:00:02 kernel: Determined physical RAM map:
Jan 1 02:00:02 kernel: memory: 01000000 @ 00000000 (usable)
Jan 1 02:00:02 kernel: On node 0 totalpages: 4096
Jan 1 02:00:02 kernel: zone(0): 4096 pages.
Jan 1 02:00:02 kernel: zone(1): 0 pages.
Jan 1 02:00:02 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Jan 1 02:00:02 kernel: IP Protocols: ICMP, UDP, TCP, IGMP
Jan 1 02:00:02 kernel: IP: routing cache hash table of 2048 buckets, 16Kbytes
Jan 1 02:00:02 kernel: TCP: Hash tables configured (established 1024 bind 2048)
Jan 1 02:00:02 kernel: Linux IP multicast router 0.06 plus PIM-SM
Jan 1 02:00:02 kernel: ip_conntrack version 2.1 (5953 buckets, 11906 max) - 328 bytes per conntrack
Jan 1 02:00:02 kernel: ip_conntrack_pptp version 1.9 loaded
Jan 1 02:00:02 kernel: ip_nat_pptp version 1.5 loaded
Jan 1 02:00:02 kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 02:00:02 kernel: ipt_time loading
Jan 1 02:00:02 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Jan 1 02:00:02 dnsmasq[67]: started, version 2.51 cachesize 512
Jan 1 02:00:02 dnsmasq[67]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N DHCP no-scripts no-TFTP
Jan 1 02:00:02 dnsmasq[67]: read /etc/hosts - 2 addresses
Jan 1 02:00:02 kernel: usb.c: registered new driver usbdevfs
Jan 1 02:00:02 kernel: usb.c: registered new driver hub
Jan 1 02:00:02 kernel: usb-ohci.c: USB OHCI at membase 0xb8003000, IRQ 6
Jan 1 02:00:02 kernel: usb-ohci.c: usb-00:03.0, PCI device 14e4:471a
Jan 1 02:00:03 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 02:00:03 kernel: hub.c: USB hub found
Jan 1 02:00:03 kernel: hub.c: 2 ports detected
Jan 1 02:00:03 kernel: ehci_hcd 00:03.1: PCI device 14e4:471a
Jan 1 02:00:03 kernel: ehci_hcd 00:03.1: irq 6, pci mem b8003800
Jan 1 02:00:03 kernel: usb.c: new USB bus registered, assigned bus number 2
Jan 1 02:00:03 kernel: ehci_hcd 00:03.1: USB 0.0 enabled, EHCI 1.00, driver 10 Dec 2004/2.4
Jan 1 02:00:03 kernel: usb.c: registered new driver usblp
Jan 1 02:00:03 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 02:00:03 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 02:00:03 kernel: Initializing USB Mass Storage driver...
Jan 1 02:00:03 kernel: usb.c: registered new driver usb-storage
Jan 1 02:00:03 kernel: USB Mass Storage support registered.
Jan 1 02:00:03 kernel: vlan1: Setting MAC address to 00 1b fc 60 e0 c6.
Jan 1 02:00:03 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
Jan 1 02:00:04 kernel: hub.c: new USB device 00:03.1-1, assigned address 2
Jan 1 02:00:04 pppd[85]: Plugin rp-pppoe.so loaded.
Jan 1 02:00:04 pppd[85]: RP-PPPoE plugin version 3.10 compiled against pppd 2.4.5
Jan 1 02:00:04 pppd[86]: pppd 2.4.5 started by admin, uid 0
Jan 1 02:00:05 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan 1 02:00:05 kernel: Vendor: JetFlash Model: Transcend 2GB Rev: 8.07
Jan 1 02:00:05 kernel: Type: Direct-Access ANSI SCSI revision: 02
Jan 1 02:00:05 kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Jan 1 02:00:05 kernel: sda: Waiting for disc 0 to settle.
Jan 1 02:00:05 kernel: SCSI device sda: 3944446 512-byte hdwr sectors (2020 MB)
Jan 1 02:00:05 kernel: sda: Write Protect is off
Jan 1 02:00:05 kernel: Partition check:
Jan 1 02:00:05 kernel: /dev/scsi/host0/bus0/target0/lun0: p1 p2 <
Jan 1 02:00:05 dropbear[101]: Running in background
Jan 1 02:00:05 dropbear[102]: Child connection from ::ffff:192.168.2.1:47080
Jan 1 02:00:05 kernel: p5 >
Jan 1 02:00:08 dropbear[102]: password auth succeeded for 'admin' from ::ffff:192.168.2.1:47080
Jan 1 02:00:09 pppd[86]: PPP session is 5869 (0x16ed)
Jan 1 02:00:09 pppd[86]: Connected to 00:30:48:d2:7e:e9 via interface vlan1
Jan 1 02:00:09 pppd[86]: Using interface ppp0
Jan 1 02:00:09 pppd[86]: Connect: ppp0 <--> vlan1
Jan 1 02:00:10 pppd[86]: CHAP authentication succeeded
Jan 1 02:00:10 pppd[86]: peer from calling number 00:30:48:D2:7E:E9 authorized
Jan 1 02:00:11 pppd[86]: local IP address 93.85.139.92
Jan 1 02:00:11 pppd[86]: remote IP address 93.84.80.50
Jan 1 02:00:11 pppd[86]: primary DNS address 82.209.240.241
Jan 1 02:00:11 pppd[86]: secondary DNS address 82.209.243.241
Jan 1 02:00:11 dnsmasq[67]: read /etc/hosts - 2 addresses
Jan 1 02:00:11 dnsmasq[67]: using nameserver 82.209.243.241#53
Jan 1 02:00:11 dnsmasq[67]: using nameserver 82.209.240.241#53
Jan 1 02:00:11 PPPoE: connected to ISP
Jan 1 02:00:15 kernel: Adding Swap: 128920k swap-space (priority -1)
Jan 1 02:00:15 e2fsck: /dev/discs/disc0/part1: recovering journal
Feb 16 21:47:31 pppd[86]: System time change detected.
Feb 16 21:47:43 e2fsck: /dev/discs/disc0/part1 has been mounted 30 times without being checked, check forced.
Feb 16 21:48:13 e2fsck: /dev/discs/disc0/part1: 12960/230400 files (0.9% non-contiguous), 107319/460776 blocks
Feb 16 21:48:13 e2fsck: /dev/discs/disc0/part1: clean, 12960/230400 files, 107319/460776 blocks
Feb 16 21:48:13 kernel: kjournald starting. Commit interval 5 seconds
Feb 16 21:48:13 kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on sd(8,1), internal journal
Feb 16 21:48:13 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Feb 16 21:48:14 rc.unslung: start service /opt/etc/init.d/S08samba
Feb 16 21:48:17 rc.unslung: start service /opt/etc/init.d/S10cron
Feb 16 21:48:17 rc.unslung: start service /opt/etc/init.d/S40dbhub
Feb 16 21:48:17 /opt/sbin/cron[151]: (CRON) STARTUP (V5.0)
Feb 16 21:48:20 rc.unslung: start service /opt/etc/init.d/S50main
Feb 16 21:48:21 kernel: IMQ driver loaded.
Feb 16 21:48:21 kernel: Hooking IMQ before NAT on PREROUTING.
Feb 16 21:48:21 kernel: Hooking IMQ after NAT on POSTROUTING.
Feb 16 21:48:22 kernel: HTB init, kernel part version 3.17
