first of all my congratulations to this forum. It helped me a lot, but there are still 2 main parts i canīt get running: samba, ftp
this is running on my wl-500g:
PID USER STATUS RSS PPID %CPU %MEM COMMAND
144 admin R 420 143 2.1 3.0 top
41 admin S 308 1 0.1 2.2 telnetd
103 admin S 732 1 0.0 5.2 nmbd
1 admin S 676 0 0.0 4.8 init
87 admin S 656 1 0.0 4.6 pppd
101 admin S 620 1 0.0 4.4 smbd
143 admin S 516 41 0.0 3.6 sh
90 admin S 496 1 0.0 3.5 watchdog
128 admin S 484 1 0.0 3.4 upnp
100 admin S 428 1 0.0 3.0 dropbear
54 nobody S 408 1 0.0 2.9 dnsmasq
121 admin S 408 1 0.0 2.9 stupid-ftpd
53 admin S 372 1 0.0 2.6 syslogd
78 admin S 364 1 0.0 2.6 rcamdmain
76 admin S 364 1 0.0 2.6 waveservermain
91 admin S 360 90 0.0 2.5 ntp
46 admin S 360 1 0.0 2.5 httpd
52 admin S 328 1 0.0 2.3 klogd
this is my smb.conf:
[global]
workgroup = Arbeitsgruppe
guest account = nobody
security = share
read only = No
guest ok = yes
guest only = yes
log level = 1
max log size = 100
encrypt passwords = no
preserve case = yes
short preserve case = yes
server string = WL-500g
preserve modes = yes
case sensitive = yes
[share$]
comment = WD-HDD
path = /tmp/harddisk/part1
read only = No
browseable = yes
guest ok = yes
this is my partition table (fdisk):
System
/dev/scsi/host0/bus0/target0/lun0/part1 1 400 3212968+
83 Linux
/dev/scsi/host0/bus0/target0/lun0/part2 401 465 522112+
82 Linux swap
/dev/scsi/host0/bus0/target0/lun0/part3 466 1118 5245222+
7 HPFS/NTFS
/dev/scsi/host0/bus0/target0/lun0/part4 1119 10011 71433022+
f Win95 Ext'd (LBA)
/dev/scsi/host0/bus0/target0/lun0/part5 1119 2423 10482381
7 HPFS/NTFS
/dev/scsi/host0/bus0/target0/lun0/part6 2424 4381 15727603+
7 HPFS/NTFS
/dev/scsi/host0/bus0/target0/lun0/part7 4382 10011 45222943+
7 HPFS/NTFS
but now its getting crazy, this what ls puts out in /tmp/harddisk/
[admin@dhcppc0 harddisk]$ ls
bin dvd home none part4 tmp
boot etc initrd opt proc usr
cdaudio floppy lib part1 root var
cdrom ftp_pub lost+found part2 sbin vmlinuz
dev ftp_pvt mnt part3 sys
and part1-4 are only the ntfs partitions...
1.) via ftp i get connection, but there is an empty directory. Why?
2.) But the worst thing ist, i canīt get acces from windows to the harddisk (via telnet no problem). I tried to map the drive and used admin as user but it rejects and complains: user not valid
I can get to the wl-500g via network area but there is nothing shown, no drives, files, etc...
If I try to get there via explorer by \\ip\share$ it rejects me and complans about no access rights...
I read the whole post around here but no solution... Please help me...btw there are ntfs partitions on the extern hd, but I understood, that this problem should be solved by the newiest "oleg"
P.S. sorry for some bad english
