Page 8 of 13 FirstFirst ... 678910 ... LastLast
Results 106 to 120 of 192
Thread: [How-To] Sane Scanner-Server with XSane Frontend
  1. #106
    hi
    I found that install scanner.o to modules but I have other kernel :
    Using //opt/lib/modules/2.4.37.7/kernel/drivers/usb/scanner.o
    //opt/lib/modules/2.4.37.7/kernel/drivers/usb/scanner.o: error reading ELF section data //opt/lib/modules/2.4.37.7/kernel/drivers/usb/scanner.o: No space left on device
    but in free i have:
    $ free
                  total         used         free       shared      buffers
      Mem:        29960        27556         2404            0          720
     Swap:       506008          760       505248
    Total:       535968        28316       507652
  2. #107
    Jul 2007
    Germany, Bonn
    I will check that.
    Regards
    Oliver
    Regards / Grüße,
    Oliver
    Clients: Kathrein UFS910 FullHD Sat Receiver, PS3, PCs, Canon MP830 an Sane Scanner-Server, Kyocera-Mita FS1020D über Printserver
  3. #108
    hp dsc 1510
    hi, i finally got time to do install everything from the beginning. I got from sane-find-scanner
    found USB scanner (vendor=0x03f0 [HP], product=0x4c11 [PSC 1500 series]) at libusb:001:003
    and from scanimage -L
     device `hpaio:/usb/PSC_1500_series?serial=MY5ADD13KM0498' is a Hewlett-Packard PSC_1500_series all-in-one
    from scanimage -T i got
    process 380: arguments to dbus_connection_send() were incorrect, assertion "connection != NULL" failed in file dbus-connection.c line 3141.
    This is normally a bug in some application using the D-Bus library.
      D-Bus not compiled with backtrace support so unable to print a backtrace
    Aborted
    I searched on the forum for this and found http://wl500g.info/showthread.php?t=20098.
    Is it possible to make the hp dsc 1510 work without dbus?
  4. #109
    I also trying to get samsung scx-4200 working, first all look fine scanimage is working just fine so driver is working. But can't connect from my desktop computer to scanner, telnet to port 6566 can't connect.
    added /etc/service "saned 6566/tcp" because that not been there but no help, and /opt/etc/init.d/S01sane-backends look just correct.
    So now im just out of idea what im doing wrong, so little help is welcome. Only diffrence to tutorial is my firmware is koppel made if that marks anything.
    EDIT: Checked all again and noticed that port again lost from /etc/service/saned file after i reboot my router, so what to do to correct this problem?
    Xinetd -d Also give erros and not to start.
    10/4/28@16:08:35: DEBUG: 129 {handle_includedir} Reading included configuration
    file: /opt/etc/xinetd.d/saned [file=/opt/etc/xinetd.conf] [line=15]
    10/4/28@16:08:35: ERROR: 129 {service_fill} Port not specified and can't find se
    rvice: saned with getservbyname
    Service defaults
            Instances = 60
            CPS = max conn:25 wait:30
            Bind = All addresses.
            Only from:  localhost(HOST) 10.0.0.0/255.0.0.0(NET) 172.16.0.0/255.240.0
    .0(NET) 192.168.1.0/255.255.255.0(NET)
            No access: No blocked sites
            Logging to syslog. Facility = authpriv, level = info
            Log_on_success flags = HOST PID
            Log_on_failure flags = HOST
    10/4/28@16:08:35: DEBUG: 129 {cnf_start_services} mask_max = 0, services_started
     = 0
    10/4/28@16:08:35: CRITICAL: 129 {init_services} no services. Exiting...
    EDIT: Full reinstall helps and scanner is working now, not know what was wrong previusly, noticed my router network connection have random dropouts (ipkg give random unknow host errors) problem is on 500gp side, network connection is working fine other computers.
  5. #110
    Jul 2007
    Germany, Bonn
    nice to hear
    samsung scx-4200 is well supported!
    Regards
    Oliver
    Regards / Grüße,
    Oliver
  6. #111
    Jul 2007
    Germany, Bonn
    @rm_fontes: I have to ask the sane-mailing-list again. Don't know whats the problem...
    Regards / Grüße,
    Oliver
  7. #112
    Hi, everyone
    I have installed everything like in 1st post, but when I start front-end xsane.exe i recieve answer that there is no devices.
    IP of my router 192.168.1.1. I start scan from 192.168.1.31
    this is my log
    17:43:53 22-05-2010 (info|authpriv|xinetd) xinetd[448]: START: saned pid=1267 from=192.168.1.31
    17:43:53 22-05-2010 (debug|daemon|saned) saned[1267]: saned (AF-indep+IPv6) from sane-backends 1.0.21 starting up
    17:43:53 22-05-2010 (debug|daemon|saned) saned[1267]: check_host: access by remote host: 192.168.1.31
    17:43:55 22-05-2010 (debug|daemon|saned) saned[1267]: check_host: getaddrinfo for local hostname failed: Name or service not known
    17:43:55 22-05-2010 (debug|daemon|saned) saned[1267]: init: access by host 192.168.1.31 denied
    17:43:55 22-05-2010 (debug|daemon|saned) saned[1267]: saned exiting
    as far as i understand there is not enough permissions. but where??
    /opt/etc/sane.d/saned.conf
    PHP Code:
    #scan-client.somedomain.firm
    #192.168.1.1
    192.168.1.0/31
    #[2001:7a8:185e::42:12]
    #[2001:7a8:185e::42:12]/64
    PHP Code:
    service saned
            socket_type
    stream
            server
    = /opt/sbin/saned
            protocol
    tcp
            user
    root
            group
    root
            wait
    no
            disable
    no
    attachment my net.conf from hard drive
    RT-N16 - Firmware 1.9.2.7-rtn-r***
  8. #113
    Try
    192.168.1.0/24 instead of 31 (/31 means all but the last bit are fixed therefore only 192.168.1.1 is allowed to connect to the server)
  9. #114
    thanks
    my /opt/etc/sane.d/saned.conf looks like:
    PHP Code:
    #192.168.1.1
    192.168.1.2/24
    now I can scan from all the PC and notebooks in my net.
  10. #115
    HP LJ M1319f MFP
    Router: RT-N16, Firmware: tomato-K26USB-1.27.9045MIPSR2-beta11-vpn3.6, Printer: HP LJ M1319f MFP
    All clients connected to router can print.
    Installed the following (in that sequence): libusb, libtiff, libjpeg, libpng, libieee1284, xinetd, sane-backends, hplip
    Output of all diagnostic tests (..xinetd.d/saned, ../sane.d/dll.conf, ../init.d/S01sane-backends, etc.) in attached file.
    == output of sane-find-scanner ==>
    found USB scanner (vendor=0x03f0, product=0x5817) at libusb:001:002
    == output of scanimage -L ==>
    No scanners were identified.
    I would appreciate any help in getting this to work. I am happy to test ideas...
    Jul 2007
    Germany, Bonn
    sorry I was out of town.
    I will look for a solution.
    Regards
    Oliver
    Regards / Grüße,
    Oliver
  12. #117
    Looking at the sane-devel mailing list it appears a couple of folks had their HP scanner issues go away by using a later version of HPLIP. example
    The current version is 3.10.x [link]. The version which has been compiled for the routers is 2.8.x (link)
    Would it be possible to compile the latest version?
  13. #118
    Jul 2007
    Germany, Bonn
    I will take a look on that.
    Maybe I can maintain hplip (or ask the person who maintains it) and make a newer version.
    Regards
    Oliver
    Regards / Grüße,
    Oliver
  14. #119
    Jul 2007
    Germany, Bonn
    Compiled hplip 3.9.2
    I compiled a new version of hplip for the wl500.
    Version is: 3.9.2
    Would be nice if you could give it a try and post your experiences. To install it do the following:
    Remove the old version of hplip:
    ipkg remove hplip
    Download the new version of hplip:
    http://rapidshare.com/files/39484398...2-1_mipsel.ipk
    Install the new version:
    ipkg install /storagelocation/of_downloaded/file/hplip_3.9.2-1_mipsel.ipk
    If you are asked to edit the dll.conf of sane, type:
    Y
    Check if the following entry is in /opt/etc/sane.d/dll.conf
    grep hpaio /opt/etc/sane.d/dll.conf
    If the output is empty, add the entry:
    echo "hpaio">>/opt/etc/sane.d/dll.conf
    Restart:
    Please post your experiences!!!
    Regards
    Oliver
    Regards / Grüße,
    Oliver
  15. #120
    Thanks for compiling this version. I used wget to download it to my router and then when I try to install, I get:
    ipkg: invalid magic
    Any ideas what the issue might be? Thanks.
  1. [How-To] Sane Scanner-Server mit XSane Frontend
    By carterb in forum German Discussion - Deutsch (DE)
    Last Post: 30-08-2012, 19:01
  2. [How to] rtorrent & ntorrent
    By mancub in forum WL-500gP Tutorials
    Last Post: 18-12-2008, 07:21
  3. [HOW TO] Bluetooth in wl500g
    By TIk in forum WL-500g/WL-500gx Tutorials
    Last Post: 17-09-2008, 21:38
  4. ASUS-Router als USB-Drucker / Scanner / Fax Server geht das alles?
    By WLAN-Fan in forum German Discussion - Deutsch (DE)
    Last Post: 19-03-2008, 13:52
  5. Gameserver
    By blingbling in forum WL-500gP Q&A
    Last Post: 17-07-2006, 15:37
