Hi.
I've been playing around with an IPv6 tunnel from HE, whilst It works, sort of, I have a few problems.
First, the settings for the router interface. Lets say, for example, I am issued the following:
Client IPv6 address: 2001:123:abcd:123::2
Server IPv6 address: 2001:123:abcd:123::1
In the router interface settings (WL500gpV2) we have:
LAN IPv6 Setting
Static IPv6 address: (Not sure what I should enter here)
Netsize (bits of hostpart): 64
Enable router advertisements: Yes
WAN IPv6 Setting
Static or local IPv6 address: 2001:123:abcd:123::2 (I assume?)
Remote IPv6 gateway: 2001:123:abcd:123::1 (I assume?)
WAN DNS IPv6 Setting
DNS Server: (Not sure what goes here there's only RDNS listed on the tunnel page at HE)
Having used the settings above, I can ping6 various sites from the router, however, I get request timed out when I try to ping -6 any ipv6 site from my PC.
Another problem, if I go to testmyipv6.net or any similar sites, they all report I'm using IPv4 and not IPv6, so something is obviously broken with my configuration.
Finally, once I get this working correctly, is there anything else that needs to be done. I did notice that running an iptables -L on the router only had entries for IPv4. Will I need to manually enter rules for IPv6?
Windows 7
Firmware: WL500gpv2-1.9.2.7-d-r2381
Thanks
Edit: made some changes and now a little closer:
In the router I changed the Static LAN address to 2001:470:1f0b:823::1
I used The DNS address 2001:470:0:70::2
I reset the IPv4 and IPv6 stack via netsh and rebooted
I was able to reach ipvg.he.net from the router but I got Destination host unreachable from the PC.
I manually added the address 2001:470:1f0b:823::3 to the IPv6 interface and added the DNS address also.
After a release and renew I was able to ping -6 ipv6.he.net from the PC and I was able to reach ipv6.google.com via the browser. I was not able to reach ipv6.he.net from the browser and when I checked whatsmyipv6.com it still showed only an IPv4 address. Clearly, I am still doing something wrong.
Here is the most recent ipconfig:
Windows IP Configuration
Host Name . . . . . . . . . . . . : ******
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 00-1D-7D-04-77-**
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2001:***:1f0b:823::3(Preferred)
IPv6 Address. . . . . . . . . . . : 2001:***:1f0b:823:972:322:9617:bc8d(Preferred)
Link-local IPv6 Address . . . . . : fe80::972:***:9617:bc8d%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.143(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, January 15, 2011 12:32:23 AM
Lease Expires . . . . . . . . . . : Sunday, January 16, 2011 12:32:23 AM
Default Gateway . . . . . . . . . : 2001:470:1f0a:823::1
fe80::e2cb:4eff:fea8:6ef3%11
192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 2001:470:0:70::2
192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{3DEBEC41-0DB9-4781-8058-726218A5B202}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
C:\Windows\System32>ping -6 ipv6.he.net
Pinging ipv6.he.net [2001:470:0:64::2] with 32 bytes of data:
Reply from 2001:470:0:64::2: time=332ms
Reply from 2001:470:0:64::2: time=331ms
Reply from 2001:470:0:64::2: time=334ms
