Problem mounting second harddisk
I can't mount second harddisk on my WL-500gP with oleg -10 firmware.
Is this a limitation of this kernel?
I get:
[admin@NAS /]$ mount /dev/discs/disc1/part2 /tmp/harddisk
mount: Mounting /dev/discs/disc1/part2 on /tmp/harddisk failed: Invalid argument
The folder /tmp/harddisk exists and is empty.
Before mounting i have set up the disk with fdisk:
Disk /dev/discs/disc1/disc: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders
/dev/discs/disc1/part1 1 32 257008+ 82 Linux swap
/dev/discs/disc1/part2 33 163 1052257+ 83 Linux
/dev/discs/disc1/part3 164 14593 115908975 83 Linux
There is no error with the partitions:
[admin@NAS /]$ e2fsck -p /dev/discs/disc1/part2
ext2fs_check_if_mount: No such file or directory while determining whether /dev/discs/disc1/part2 is mounted.
/dev/discs/disc1/part2: clean, 21608/140832 files, 105175/263064 blocks
[admin@NAS /]$ e2fsck -p /dev/discs/disc1/part3
ext2fs_check_if_mount: No such file or directory while determining whether /dev/discs/disc1/part3 is mounted.
/dev/discs/disc1/part3: clean, 11/14499840 files, 455012/28977243 blocks
Asus WL-500g.Premium with Oleg firmware version 1.9.2.7-10. dropbear - samba - lighttp - php - mysql - ftp - nzbget - transmission - mediatomb - syslog-ng
