Results 31 to 45 of 51
Thread: Howto add serial port to WL-500gx/gp
Threaded View
    Apr 2004
    Hungary, Budapest
    Post Howto add serial port to WL-500gx/gp
    The Asus wl500g deluxe has uart pinout onboard, so 2 serial ports can be added to the unit.
    The only difference between wl500g and wl500gx that the deluxe does not require a UART chip, so a simple RS232 transceiver will do the trick.
    Here are my experiences adding a single serial port to the router
    The parts you need:
    - 1 MAX3232 IC (SO-IC)
    - 5 1uF capacitors
    - cables, connectors
    I attached the PCB layout I made, and a few pictures that might help.
    There are 2 jumpers on the pcb, which switches between the Tx-Rx, so it doesn't matter what kind of serial cable you actually use.
    Good juper configurations:
    ._ ._ and _. _.
    Don't mix them! Next time i'm going to use a switch instead
    You need to connect the router's 3.3v, GND, UART_TX0, UART_RX0 pins to the left side of the pcb, set the jumpers, and connect a DB9 connector to the right side.
    Note: Actually i was able to add the serial port without actually removing the warranty sticker. I left the screw with the sticker untouched, and stretched the unit just enough to get the connector on the pins.
    Important: Don't try this, unless you know what you are doing. I take no responsibility for damaging your router
    CFE version 1.0.37 for BCM947XX (32bit,SP,LE)
    Build Date: ¤*  7¤ë 16 19:48:38 CST 2004 (root@PaNLinux)
    Copyright (C) 2000,2001,2002,2003 Broadcom Corporation.
    Initializing Arena.
    Initializing Devices.
    et0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 1.3.2.0
    rndis0: Broadcom USB RNDIS Network Adapter (P-t-P)
    CPU type 0x29007: 200MHz
    Total memory: 0x1000000 bytes (16MB)
    Total memory used by CFE:  0x80300000 - 0x80436CF0 (1273072)
    Initialized Data:          0x803311B0 - 0x80333540 (9104)
    BSS Area:                  0x80333540 - 0x80334CF0 (6064)
    Local Heap:                0x80334CF0 - 0x80434CF0 (1048576)
    Stack Area:                0x80434CF0 - 0x80436CF0 (8192)
    Text (code) segment:       0x80300000 - 0x803311B0 (201136)
    Boot area (physical):      0x00437000 - 0x00477000
    Relocation Factor:         I:00000000 - D:00000000
    Device eth0:  hwaddr 00-11-D8-XX-XX-XX, ipaddr 192.168.1.1, mask 255.255.255.0
            gateway not set, nameserver not set
    Rescue Flag disable.
    Reading :: TFTP Server.
    Failed.: Timeout occured
    Loader:raw Filesys:raw Dev:flash0.os File: Options:(null)
    Loading: ...... 1748992 bytes read
    Entry at 0x80001000
    Closing network.
    Starting program at 0x80001000
    CPU revision is: 00029007
    Primary instruction cache 8kB, physically tagged, 2-way, linesize 16 bytes.
    Primary data cache 4kB, 2-way, linesize 16 bytes.
    Linux version 2.4.29 (josephus@arrakis) (gcc version 3.3.5) #1 Sun Mar 6 02:01:59 CET 2005
    Josephus
    HuWiCo - Hungarian Wireless Community
    http://www.huwico.hu
  1. Alle Howto's, all howto's
    Last Post: 29-03-2013, 13:57
  2. Use an USB-serial port converter
    By Technik in forum WL-500g/WL-500gx Tutorials
    Last Post: 24-04-2012, 10:54
  3. Virtual serial port (CDC Class)
    By Snail.cz in forum WL-500gP Q&A
    Last Post: 09-03-2009, 16:42
  4. WL-500gx with openwrt pre-rc5 howto webserver?
    By ye_old in forum WL-500g Custom Development
    Last Post: 22-03-2006, 12:54
  5. Serial port for WL-500g
    By sveasoft in forum WL-500g Pics & Specs
    Last Post: 08-03-2005, 21:39
