Results 1 to 15 of 51
Thread: Howto add serial port to WL-500gx/gp
    Apr 2004
    Hungary, Budapest
    Post Howto add serial port to WL-500gx/gp
    The Asus wl500g deluxe has uart pinout onboard, so 2 serial ports can be added to the unit.
    The only difference between wl500g and wl500gx that the deluxe does not require a UART chip, so a simple RS232 transceiver will do the trick.
    Here are my experiences adding a single serial port to the router
    The parts you need:
    - 1 MAX3232 IC (SO-IC)
    - 5 1uF capacitors
    - cables, connectors
    I attached the PCB layout I made, and a few pictures that might help.
    There are 2 jumpers on the pcb, which switches between the Tx-Rx, so it doesn't matter what kind of serial cable you actually use.
    Good juper configurations:
    ._ ._ and _. _.
    Don't mix them! Next time i'm going to use a switch instead
    You need to connect the router's 3.3v, GND, UART_TX0, UART_RX0 pins to the left side of the pcb, set the jumpers, and connect a DB9 connector to the right side.
    Note: Actually i was able to add the serial port without actually removing the warranty sticker. I left the screw with the sticker untouched, and stretched the unit just enough to get the connector on the pins.
    Important: Don't try this, unless you know what you are doing. I take no responsibility for damaging your router
    CFE version 1.0.37 for BCM947XX (32bit,SP,LE)
    Build Date: ¤*  7¤ë 16 19:48:38 CST 2004 (root@PaNLinux)
    Copyright (C) 2000,2001,2002,2003 Broadcom Corporation.
    Initializing Arena.
    Initializing Devices.
    et0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 1.3.2.0
    rndis0: Broadcom USB RNDIS Network Adapter (P-t-P)
    CPU type 0x29007: 200MHz
    Total memory: 0x1000000 bytes (16MB)
    Total memory used by CFE:  0x80300000 - 0x80436CF0 (1273072)
    Initialized Data:          0x803311B0 - 0x80333540 (9104)
    BSS Area:                  0x80333540 - 0x80334CF0 (6064)
    Local Heap:                0x80334CF0 - 0x80434CF0 (1048576)
    Stack Area:                0x80434CF0 - 0x80436CF0 (8192)
    Text (code) segment:       0x80300000 - 0x803311B0 (201136)
    Boot area (physical):      0x00437000 - 0x00477000
    Relocation Factor:         I:00000000 - D:00000000
    Device eth0:  hwaddr 00-11-D8-XX-XX-XX, ipaddr 192.168.1.1, mask 255.255.255.0
            gateway not set, nameserver not set
    Rescue Flag disable.
    Reading :: TFTP Server.
    Failed.: Timeout occured
    Loader:raw Filesys:raw Dev:flash0.os File: Options:(null)
    Loading: ...... 1748992 bytes read
    Entry at 0x80001000
    Closing network.
    Starting program at 0x80001000
    CPU revision is: 00029007
    Primary instruction cache 8kB, physically tagged, 2-way, linesize 16 bytes.
    Primary data cache 4kB, 2-way, linesize 16 bytes.
    Linux version 2.4.29 (josephus@arrakis) (gcc version 3.3.5) #1 Sun Mar 6 02:01:59 CET 2005
    Josephus
    HuWiCo - Hungarian Wireless Community
    http://www.huwico.hu
    Apr 2004
    Adelaide, Australia
    WL500gx serial port success
    I have successfully connected to the serial port on J5.
    I've used a small converter board from a usb->serial cable (an old phone data cable), and will mount that board inside the case, with just a USB device port added to the back panel. Pictures later ...
    Here is the output from the serial console on boot (running Oleg's firmware).
    Build Date: ¤G  3¤ë  1 16:49:41 CST 2005 (root@PaNLinux)
    Initializing Arena.
    Total memory: 0x2000000 bytes (32MB)
    Total memory used by CFE:  0x80300000 - 0x80436F10 (1273616)
    Initialized Data:          0x803313D0 - 0x80333760 (9104)
    BSS Area:                  0x80333760 - 0x80334F10 (6064)
    Local Heap:                0x80334F10 - 0x80434F10 (1048576)
    Stack Area:                0x80434F10 - 0x80436F10 (8192)
    Text (code) segment:       0x80300000 - 0x803313D0 (201680)
    Device eth0:  hwaddr 00-11-D8-??-??-??, ipaddr 192.168.??.??, mask 255.255.255.0
    Loading: .. 3560 bytes read
    Entry at 0x80001000
    Closing network.
    cpu probe
    prom init
    cpu report
    Primary instruction cache 8kb, linesize 16 bytes (2 ways)
    Primary data cache 4kb, linesize 16 bytes (2 ways)
    Linux version 2.4.20 (root@omnibook) (gcc version 3.2.3 with Broadcom modifications) #62 Mon Mar 14 21:39:22 MSK 2005
    Setting the PFC value as 0x15
    Determined physical RAM map:
     memory: 02000000 @ 00000000 (usable)
    On node 0 totalpages: 8192
    zone(0): 8192 pages.
    zone(1): 0 pages.
    zone(2): 0 pages.
    Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc console=ttyS0,115200
    CPU: BCM5365 rev 1 at 200 MHz
    Calibrating delay loop... 199.47 BogoMIPS
    Memory: 30128k/32768k available (1755k kernel code, 2640k reserved, 220k data, 68k init, 0k highmem)
    Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
    Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
    Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
    Checking for 'wait' instruction...  unavailable.
    POSIX conformance testing by UNIFIX
    PCI: Fixing up bus 0
    PCI: Fixing up bridge
    PCI: Fixing up bus 1
    Linux NET4.0 for Linux 2.4
    Based upon Swansea University Computer Society NET3.039
    Initializing RT netlink socket
    Starting kswapd
    Journalled Block Device driver loaded
    devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
    devfs: boot_options: 0x1
    NTFS driver v1.1.22 [Flags: R/O]
    pty: 256 Unix98 ptys configured
    Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
    ttyS00 at 0xb8000300 (irq = 3) is a 16550A
    ttyS01 at 0xb8000400 (irq = 0) is a 16550A
    loop: loaded (max 8 devices)
    PPP generic driver version 2.4.2
    PPP Deflate Compression module registered
    PPP BSD Compression module registered
    MPPE/MPPC encryption/compression module registered
     Amd/Fujitsu Extended Query Table v1.1 at 0x0040
    number of CFI chips: 1
    Flash device: 0x400000 at 0x1c000000
    Physically mapped flash: squashfs filesystem found at block 936
    Creating 5 MTD partitions on "Physically mapped flash":
    0x00000000-0x00040000 : "pmon"
    0x00040000-0x003e0000 : "linux"
    0x000ea190-0x003e0000 : "rootfs"
    0x003f0000-0x00400000 : "nvram"
    0x003e0000-0x003f0000 : "config"
    sflash: found no supported devices
    NET4: Linux TCP/IP 1.0 for NET4.0
    IP Protocols: ICMP, UDP, TCP
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP: Hash tables configured (established 2048 bind 4096)
    ip_conntrack version 2.1 (256 buckets, 2048 max) - 344 bytes per conntrack
    ip_conntrack_pptp version 1.9 loaded
    ip_nat_pptp version 1.5 loaded
    ip_tables: (C) 2000-2002 Netfilter core team
    ipt_time loading
    NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    IPv6 v0.8 for NET4.0
    IPv6 over IPv4 tunneling driver
    NET4: Ethernet Bridge 008 for NET4.0
    802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
    All bugs added by David S. Miller <davem@redhat.com>
    FAT: bogus logical sector size 38400
    NTFS: Unable to set blocksize 512.
    VFS: Mounted root (squashfs filesystem) readonly.
    Mounted devfs on /dev
    Freeing unused kernel memory: 68k freed
    Algorithmics/MIPS FPU Emulator v1.5
    eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 1.3.2.0
    robosw_attach_ocp: no Robo device on OCP bus
    PCI: Enabling device 01:03.0 (0004 -> 0006)
    eth1: Broadcom BCM4320 802.11 Wireless Controller 3.90.7.0
    device eth1 entered promiscuous mode
    eth0.1: No such device
    device eth0 entered promiscuous mode
    br0: port 2(eth0) entering learning state
    br0: port 1(eth1) entering learning state
    br0: port 2(eth0) entering forwarding state
    br0: topology change detected, propagating
    br0: port 1(eth1) entering forwarding state
    usb.c: registered new driver usbdevfs
    usb.c: registered new driver hub
    usb-uhci.c: $Revision: 1.275 $ time 20:26:03 Mar  3 2005
    usb-uhci.c: High bandwidth mode enabled
    PCI: Enabling device 01:02.0 (0000 -> 0001)
    usb-uhci.c: USB UHCI at I/O 0x100, IRQ 2
    usb-uhci.c: Detected 2 ports
    usb.c: new USB bus registered, assigned bus number 1
    hub.c: USB hub found
    hub.c: 2 ports detected
    PCI: Enabling device 01:02.1 (0000 -> 0001)
    usb-uhci.c: USB UHCI at I/O 0x120, IRQ 2
    usb.c: new USB bus registered, assigned bus number 2
    usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
    PCI: Enabling device 01:02.2 (0000 -> 0002)
    ehci_hcd 01:02.2: PCI device 1106:3104
    ehci_hcd 01:02.2: irq 2, pci mem c00af000
    usb.c: new USB bus registered, assigned bus number 3
    PCI: 01:02.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
    ehci_hcd 01:02.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
    hub.c: 4 ports detected
    usb.c: registered new driver usblp
    printer.c: v0.13: USB Printer Device Class driver
    usb.c: registered new driver audio
    audio.c: v1.0.0:USB Audio Class driver
    Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    PCI devices found:
        Class 0501: PCI device 14e4:0800 (rev 1).
        Class 0200: PCI device 14e4:4713 (rev 1).
        Class 1000: PCI device 14e4:4718 (rev 1).
        Class 0c03: PCI device 14e4:4715 (rev 1).
        Class 0604: PCI device 14e4:0804 (rev 1).
        Class 0b30: PCI device 14e4:0816 (rev 1).
        Class 0500: PCI device 14e4:080f (rev 1).
        Class 0600: PCI device 14e4:5365 (rev 0).
        Class 0c03: PCI device 1106:3038 (rev 97).
        Class 0c03: PCI device 1106:3104 (rev 99).
        Class 0280: PCI device 14e4:4320 (rev 3).
    echo for PaN ::: &&&PaN
    Dec 2004
    NL CheeseCity (Gouda)
    I was wondering if you manage to send output to your serial port.
    There is another thread about adding USB serial ports and all people I heard (including myself) trying to actually use the port found out that the wl500 reboots after sending a few characters to that port. Maybe you run into problems just like us actually using the port. Unfortunately I do not know of any fixes for this problem.
    Regards
    Peter
    Apr 2004
    Adelaide, Australia
    Quote Originally Posted by rwhitby
    Operation is confirmed, and here are the promised pictures. I left room between the ethernet ports and the new usb device port just in case I decide to add the extra two USB host ports later ...
    -- Rod
    Jun 2004
    Delft, The Netherlands
    It took me a few seconds to understand the config. Related to palbeda's remark, this set-up is the other way around. Where palbeda connected a serial<->USB to the USB port of the Asus, in this set-up you connect the serial of the asus to the USB of e.g. a PC. Therefore, no max232 voltage convertor is needed. On the other hand, for home automation applications, a native serial port on the ASUS is to be prefered.
    Apr 2004
    Adelaide, Australia
    Quote Originally Posted by sodb
    If you want a non-console serial port on the wl500g (e.g. for home automation), then the easiest way is to just plug in a pl2303-based usb to serial converter cable). I have sent Oleg a patch to enable such usage in his firmware, and I hope it will be included in the next version he releases.
    -- Rod
    -- Rod
    yes, pl2303 support would be in the next firmware. So it would be possible to connect some cellular phones, which use pl2303 in their data cables.
    Serial I/O (UART)
    Does anybody know of any serial uart i/o pins are exposed on the pcb of this beast? I don;t care for RS232 levels, they'll do me fine at 3.3V as long as they are accesible.
    Also i've not managed to find any info as regards to the cpu..Anybody know what it is?
    Cheers
    dan
    Edit: OPk, i found answers to my own questions now . If anybody else is wondering check this
    Quote Originally Posted by Josephus
    The parts you need:
    - 5 1uF capacitors
    [/CODE]
    There is an alternate way. All these parts are built into a Nokia serial data cable which can be bought quite cheap now. Just connect up 3 wires tx, rx and ground that used to go to the phone to the connector in the WL500gx.
    The other end of the cable has a 9-pin to connect to the PC.
    Quote Originally Posted by WVR
    Well, there is yet another way with single 74HC14N
    Some pictures of my additional serials and Usb's
    Hi all,
    Just for your information. I'll post a schematic later on.
    Hervé
    No stty in my Busybox
    Dear All,
    Well I would like now to check my serials.
    I did not found any stty in the directories neither in the busybox.Is this one missing in the latest Oleg firmware.
    How to get stty?
    Can you descrivbe a test procedure. I looped my serial pins 2 to 3 , so if I send something, it should be back...
    Thanks for help
    Hervé
    Schéma Electrique de montage USB et série
    Hi all,
    This is the schematic to create links USB and serial.
    For the MAX chip use a 3V3 model named MAX3232
    Thanks to all of you who already made pictures, that helped me.
    CU
    Hervé
    Bonjour à tous,
    Ci joint le schema de montage USB et series
    Pour le max bien prendre un modèle 3V3
    donc un MAX3 232 (avec un TROIS en premier chiffre!)
    Merci à ceux qui ont sur ce Post fais les images que j'ai reprises
    pour éclairer le schéma.
    Hervé
    Quote Originally Posted by galmiche
    Dear All,
    How to get stty?
    Thanks for help
    Hervé
    I have the same problem as galmiche. How do I enable stty?
    By default, Oleg's firmware is using the first serial as terminal, and the second one is disabled.
  1. Alle Howto's, all howto's
    Last Post: 29-03-2013, 13:57
  2. Use an USB-serial port converter
    By Technik in forum WL-500g/WL-500gx Tutorials
    Last Post: 24-04-2012, 10:54
  3. Virtual serial port (CDC Class)
    By Snail.cz in forum WL-500gP Q&A
    Last Post: 09-03-2009, 16:42
  4. WL-500gx with openwrt pre-rc5 howto webserver?
    By ye_old in forum WL-500g Custom Development
    Last Post: 22-03-2006, 12:54
  5. Serial port for WL-500g
    By sveasoft in forum WL-500g Pics & Specs
    Last Post: 08-03-2005, 21:39
