Results 31 to 45 of 66
Thread: [HowTo] Getting started (Firmware upgr, Storage, Samba, SSH)
    Apr 2005
    Belgium
    Correct me if I'm wrong, but shouldn't your [ext3] section have only one "path" line?
    So probably, you should only have
    path=/tmp/harddisk/part1
    and not
    path=/tmp/harddisk
    Yes i know.. i have corrected that to.
    That was why i keept endning up the same place.
    Do u know if i can make one big ext3 partiton, maybe in partition magic.
    and just use that. or do i have to format the hd by the router, for it to be reconizede by the router.
    It´s stupid having a fat32 and a ext3 partition
    Quote Originally Posted by lebeno
    and not
    path=/tmp/harddisk
    Jan 2005
    Kysice,Czech Republic
    your unit has got to have assigned a host name
    It is mentioned somewhere in this thread but I somehow missed it and it took me an hour to find out what was wrong. Your unit needs to have assigned a host name - you need Oleg´s 1.9.2.7-5a (or later, if available:-)) firmware for that (it is bugged in earlier versions, as I understood) and you can do it through the webinterface (IP Config >> WAN & LAN >> LAN IP Setting >> Host Name). You can tell the difference whether it is assigned or not from the telnet command line(or how to call it:-)) - if it is like this:
    [admin@wl500g root]$ where wl500g stands for the name and admin for the user name, you ale alright, if it is like this: [admin@(none) root]$, you need to fix something up.
    I hope this helps somebody, it would have saved some time to me:-).
    seems to me that you only have one path (path=/tmp/harddisk) with a subdirectory in it (part1).
    if you mount /tmp/harddisk as an ext3 partitiosn then /tmp/harddisk/part1 is a directoty in that partition
    you should have something like this instead:
    /tmp/harddisk/part1 (for ext3)
    /tmp/harddisk/part2 (/for fat32)
    Hello,
    to anyone who uses an usb storage device on their asus with samba. Do you experience problems with writing 'big' (>100mb) files to the device? I tried all Oleg firmware versions without result. Currently running 1957-5a. I'm using an 80gb fat32 drive.
    And what's more, as i aproach the drive through my asus, it's recognised as an 4gb hd? While when i connect it directly through usb on my pc, it's recognised as 80 gb. Anyone a hint? Should i try make an ext3 partition?
    tnx
    With the newer versions of samba (and the firmware), it's better to use
    encrypt passwords = no
    as default, otherwise you get errors.
    You can also choose to create a password file for samba (search the forum).
    I am also having a problem with writing big files to my hd with samba....
    Does a newer firmware help? Or is this a reply to an other post
    Question permission denied
    sometimes during the tutorial i get "permission denied". do i need to change that? and if i need to, how?
    tnx
    similar problem here. I use a 80GB drive formatted with ext3. When mounting from a Linux-PC only 4 GB are shown as available and 0 used. Actually perhaps 10GB are used. My first guess is that the samba version used in the Asus is old. But I couldn't find something on samba lists.
    tatnat
    Quote Originally Posted by sharky123
    Hello,
    tnx
    Jun 2005
    Hogwarts
    Quote Originally Posted by kuka
    Hi, great HowTo!
    I succesfully created the partitions with fdisk.
    But there's no way to create the Swap on Windows partition.
    [admin@(none) root]$ mkeswap /dev/scsi/host0/bus0/target0/lun0/part1
    -sh: mkeswap: not found
    Is it possible only to create one big ext3 partition? How?
    I'm a noob in unix.
    Can you help me, please?!
    read my friend
    mkswap is the correct command, it is written some pages below me
    i have managed to start samba and stuff, but now i have a problem...
    i can acces the share$ folder, and i can copy stuff from it, but i cannot write/erase enything in windows?!?!
    Can anyone tell me whats going on?
    I have all the settings in smb.conf like it should be, so i really dont know why this thing dosent work!?!
    Anyone?
    Fresh
    Sep 2005
    Thumbs up It works!
    Thanks a lot hezik for this howto, ssh and samba work like a charm.
    If only everything was this easy...
    No post-boot dir.
    Great post, but it looks like I haven’t got a /post-boot dir.
    When I try: “echo "/usr/sbin/smbd -D" >> /usr/local/sbin/post-boot” I receive the following error message:
    -sh: cannot create /usr/local/sbin/post-boot: Directory nonexistent
    Any ideas?
    (firmware: WL500gx-1.9.2.7-6b)
    Apr 2004
    Netherlands
    post-boot is a file.
    Make sure you use a recent firmware from Oleg and then execute (if the /usr/local/sbin dir doesn't exist):
    - flashfs enable
    - mkdir /usr/local/sbin
    - touch post-boot
    - touch pre-boot
    - touch post-firewall
    - touch post-mount
    - flashfs save
    - flashfs commit
    Nov 2005
    Eindhoven @ The Netherlands
    Can't get the samba share working, what's going wrong?
    I did try this tutorial to enable a samba share at my external usb harddisk, but i can't access it through a share. What's going wrong?
    Here is all my information:
    [admin@(none) root]$ cat /etc/smb.conf
    workgroup = WERKGROEP
    server string = OpenWRT Samba Server
    wins support = no
    dns proxy = no
    name resolve order = lmhosts hosts bcast
    log file = /opt/var/log/samba/log.%m
    max log size = 1000
    syslog = 0
    security = share
    encrypt passwords = true
    obey pam restrictions = yes
    guest account = nobody
    passwd program = /usr/bin/passwd %u
    load printers = no
    [share]
    comment = /tmp/harddisk
    path = /tmp/harddisk
    writeable = yes
    browseable = yes
    force user = admin
    [admin@(none) root]$ ps
    PID Uid VmSize Stat Command
    1 admin 700 S /sbin/init
    2 admin SW [keventd]
    3 admin SWN [ksoftirqd_CPU0]
    4 admin SW [kswapd]
    5 admin SW [bdflush]
    6 admin SW [kupdated]
    7 admin SW [mtdblockd]
    41 admin 292 S telnetd
    46 admin 392 S httpd eth1
    49 admin 340 S klogd
    53 nobody 428 S dnsmasq
    54 admin 388 S syslogd -m 0 -O /tmp/syslog.log -S -l 7
    56 admin 500 S nas /tmp/nas.lan.conf /tmp/nas.lan.pid lan
    59 admin SW [khubd]
    69 admin 276 S lpd
    71 admin 260 S p9100d -f /dev/usb/lp0 0
    73 admin 260 S p9101d -f /dev/printers/0 1
    76 admin 340 S waveservermain
    78 admin 348 S rcamdmain
    82 admin SW [usb-storage-0]
    83 admin SW [scsi_eh_0]
    93 admin 324 S infosvr br0
    94 admin 480 S watchdog
    96 admin 340 S ntp
    104 admin 428 S dropbear
    113 admin SW [kjournald]
    115 admin 404 S stupid-ftpd
    117 admin 744 R dropbear
    118 admin 528 S -sh
    124 admin 392 R ps
    [admin@(none) root]$ cat /usr/local/sbin/post-boot
    dropbear
    /usr/sbin/smbd -D
    /usr/sbin/nmbd -D
    What is going wrong? It look to me that Samba is not started, but howcome?
    Any help apriciated.
    Tnx,
    Roland
  1. Firmware upgrading HOWTO
    Last Post: 30-07-2008, 21:00
  2. Started with Custom 1.1.28. Need some help
    By fleppuhstein in forum WL-HDD Q&A
    Last Post: 04-04-2005, 21:01
  3. Samba in 1.9.2.7-4 firmware
    By viper_002 in forum WL-500g Q&A
    Last Post: 31-03-2005, 19:24
  4. RCAMD started 3 times ?
    By max2950 in forum WL-500g Q&A
    Last Post: 09-03-2005, 12:45
  5. Samba and Firmware 1.9.2.7-RC3
    By Arobs45 in forum WL-500g Q&A
    Last Post: 20-01-2005, 14:49
