Hi Engy,
Please read below. I think I found what you need to modify the firmware.
Engy,
Here is the letter from the guy who changed the firmware for the similar CDMA mode.
Please read below. I trunslated it in English.
If you can change the Flash-file system for the Asus, you should put the following file from the attached archive to the folder
/usr/local/custom/
dial
dialup
dialup.chat
update
The file post-boot should be placed /usr/local/sbin/post-boot
More details about this issue at
http://oleg.wl500g.info,
http://www.wl500g.info/showthread.ph...ighlight=mkswa
p).
In the above discribed files you should change the "vendor=0x16D8
product=0x5533" to the ID of your modem, you can find out about the ID at the Widows Device manager.
In UI Adam Firmware you should choose 'dialup', this is the one where you can find login/password/dial number.
Engy here is my Modem ID.
USB\Vid_16d8&Pid_5543&Rev_0000
Engy I am attaching the file on the bottom in russian. Just for your reference. This is the original.
Если Вы умеете менять flash-файловую систему на раутере, то
поместите следующие файлы из приаттаченного архива в папку
/usr/local/custom/
dial
dialup
dialup.chat
update
А файл post-boot поместить /usr/local/sbin/post-boot
(подробнее об этом http://oleg.wl500g.info,
p).
В вашеперечисленных файлах поменяйте "vendor=0x16D8
product=0x5533" на ID Вашего модема, узнать ID можно в
Windows Device Manager.
В UI прошивки Адама нужно выбрать опцию 'dialup', это та,
где есть только login/password/dial number.
Skier.
This is not a good usage of user dialup files. In attachement is a sample usage of user dialup files with koppel firmware. But this is not a driver for gprs device but only you tell to system to use usbserial module for your usb device with specified vid/pid.
Engy,
Are you saying that this is not a good idea to use user dialup files this way?
And what every you attaching is the same thing from KOPPEL firmware.
Engy I will keep looking for Linux driver for my Modem, but I have no luck so far.
Would you still recommend to use it if I won't be able to find the driver?
How can I integrate it in WL500gx-1.9.2.7-7f-USB-1.64.trx?
Thanks in Advance for your advice.
Skier
Engy,
Here what I found on one russian forum. Will it work as a driver?
They used it for Linux system, for my particular modem. Works fine.
1. modprobe cdc_acm
2. mknod /dev/usb/ttyACM0 c 166 0
3. Make a script /etc/ppp/peers/cdma-evdo:
921600
connect '/usr/sbin/chat -s -v "" "AT&F0E0V1S0=0" OK ATD#777 CONNECT'
debug
updetach
crtscts
noipdefault
nodetach
novj
lcp-echo-failure 0
nobsdcomp
novjccomp
nopcomp
noaccomp
noauth
user mobile
modem
usepeerdns
defaultroute
connect-delay 5000
4. В /etc/ppp/pap-secrets добавить
mobile * internet
5. pppd /dev/usb/ttyACM0 call cdma-evdo
6. Do not forget to copy after the first session resolv.conf из /etc/ppp в /etc
08.12.2006 01:19 (Msk) Neptune-1
Hi Engy,
Sorry for asking the stupid question. But I am very new in it. What kind of program will you use to create the .gz.tar archives? I opened the archive with
WinRar and cannot create the right type of installation archive. I changed the VID and PID.
Skier.
Engy,
Here is the attached archive with changed VID and PID.
Skier.
Engy,
Finaly I made the file it in a right way. With the help of my LINUX friend. But it doesn't work. I am attaching the log. Can you say what is wrong. I am attaching the modified dialsample.tar.gz for my modem.
Skier
Hi Engy,
The new firmware from Adam
http://koppel.cz/cdmawifi/download/165/
works with my modem. Thanks a lot for your help.
Skier.
Engy thanks a lot. Great work. Now a lot of people can use there modems with ASUS.
Thanks again.
Skier
