WARNING: BETA VERSION
TRY AT YOUR OWN RISK!
DO NOT UPGRADE UNLESS YOU KNOW WHAT YOU ARE DOING
DOWNGRADE IS NOT EASILY POSSIBLE!!
Changelog:
important!!1. Fix: reset to default problem
2. Fix: wireless range problem
3. Chg: pppoe package for idle disconnect timeout
4. Add: support connection of NAT track to 4096
find files here:When upgrading from 1.7.x.x based firmware: you MUST Reset your WL500g to defaults via the restore button at the back after upgrading to this firmware!
you do not have to do this when you upgrade from 1.8.x.x based firmware!
but we RECOMMEND you to do a restore to defaults.
Do not import saved settings from older/other firmwares! this can cause unstability to your device
Mirror @ Chupa.nl
http://files.wl500g.info/asus/wl500g...0g_1936_EN.zip
cK LEe notified me by mail of the existence.
