Results 1 to 15 of 196
Thread: Firmware v1.9.2.7 CR4 [Oleg]
    Hi I followed your instructions but I get the following error when trying to do
    ipkg.sh update
    Downloading http://wl500g.dyndns.org/ipkg/Packages ...
    wget: //opt/tmp/ipkg/Packages: No such file or directory
    ipkg_download: ERROR: Failed to retrieve http://wl500g.dyndns.org/ipkg/Packages, returning
    ipkg_update: Error downloading http://wl500g.dyndns.org/ipkg/Packages to /opt/lib/ipkg/lists/wl500g
    Any Ideas?
    has anyone tested the mt-daapd package? any chance that it would work
    http://www.nslu2-linux.org/wiki/Unslung/Mt-daapd
    and thx for the great work.
    mount -text3 -oloop,noatime /tmp/harddisk/opt.ext3 /opt
    installing packages (install real ipkg first):
    ipkg.sh update
    ipkg.sh install ipkg
    Once done:
    echo "src unslung http://wl500g.dyndns.org/unslung" >> /opt/etc/ipkg.conf
    ipkg update
    ipkg list
    Apr 2004
    Adelaide, Australia
    Quote Originally Posted by mullog
    Any Ideas?
    Add "mkdir -p /opt/tmp/ipkg" to the instructions.
    No reason I can think of why mt-daapd won't work ...
    -- Rod
    Oct 2004
    Portugal
    Oleg
    fw 1.9.2.7 CR4 [Oleg]
    !!!reboot issue!!!
    Home Page
    Marco Sousa from PORTUGAL
    usb webcam
    just installed this firmware to try and get a webcam to work and try as I might whenever I change the webcam driver from pwc 8.8 to OV511 2.10 and do a save and restart its back to pwc 8.8
    the webcam is a trust 150 spacecam portable which I believe needs the OV driver?
    I have been unable to do this with any firmware I have tried up to now
    If the cam revert to a PWC driver, it mean it is not properly reconised. You will need to try another webcam, or to get working drivers for it. I think somebody posted drivers for other webcam, but you will have to search for them. Not sure they will work.
    Quote Originally Posted by hugo
    thanks for that, its my first time trying custom firmware so support is most welcome, tried 3 webcams now and i can see in the status log that they are not recognised, don't know if i can afford to buy to many more
    Aug 2004
    Hi
    Quote Originally Posted by hobbes
    You only need to check the Asus Handbook for supported cams. If none fits your needs go into shops near you and see which ones they sell, tehn look up google for the used chipset (ovv5xx or philips). Cheap is the Terracam Pro if you get one, and good are the bigger Logitech ones... or ask ebay .
    Greets
    Wds
    To share my experiences with you:
    On my set of two WL-500g's WDS does work with WPS-PSK and AES (on Channel 11).
    Both are in AP mode and one of them is connected to a router.
    Last Post: 13-04-2005, 23:26
    Last Post: 11-01-2005, 18:22
    Last Post: 06-10-2004, 08:12
    Last Post: 03-05-2004, 11:13
    Last Post: 07-04-2004, 17:22
