Well, yesterday I violated a cardinal rule which is to not mess with things when they are working.
Here is my situation: I have a Netgear 624 wireless router which is hooked up to my DSL router. The IP address of this router 192.168.0.1, ssid: test, security disabled
I had my Asus WL-500gx set up as a wireless client:
-it was in Homegate way operating mode
-wireless set as AP channel 6, no security
-wireless bridge as AP
-wireless advanced mode as Ethernet bridge
FW was (and is) 1.9.2.7-3c, I had not been able to get this to work with either the stock firmware or with the newer beta firmware on this site.
After updating the bootloader last night, I can no longer connect. In status, it says disconnected. In wireless status it says connecting to test (rather than connected to test. But very importantly it says it is using channel 1!
Using the wl channel command I see it is indeed using channel 1.
Any recommendations on how to resolve this?
Any way to go back to the old bootloader?
Thanks,
Mark
