Results 31 to 45 of 69
Thread: Wake-on-LAN
    is this "Hidden Admin Page" only available within customized firmwares? If yes, which is the most stable one?
    fraho
    Nov 2003
    Eindhoven
    Quote Originally Posted by fraho
    o.k, just before I start flashing a new firmware on a running system :
    Will this "hidden Admin page" let me send a wake-on-lan-command via Web-Frontend (via port 80)?
    yes it works with stock firmwares and yes it works from WAN side
    your websetup is at the port you define it is, standard it is when enabled at port 8080 from WAN
    wake on wan doesn't work
    for erik_bies
    i've tried to launch ether-wake from my telnet session with the Mac address, and it doesn't work !
    but, if i use a tool on another PC to wake up the first one, it works
    Can you tell me if i have to modify specific files or set specific rules to make this ?
    thanks
    Nov 2003
    Eindhoven
    it does work, I am assuming you use the built-in ether-wake application and not a standalone version found in this thread
    perhaps it doesn't use the same WOL string to wake up the other pc
    I have succesfully used this on:
    Intel NIC (onboard at Intel® Desktop Board D815EEA2/D815EPEA2)
    Nforce NIC (onboard at MSI K7N420Pro Nforce 1)
    Nforce NIC (onboard at MSI K7N2 Delta ILSR Nforce 2)
    wake on lan
    answer to Antiloop
    yes, i use the ether-wake i have found on my wl500gx
    i'm not a linux expert, so coul you tell me the procedure to download a compiled version ?
    thanks
    Nov 2003
    Eindhoven
    Quote Originally Posted by mao44
    answer to Antiloop
    thanks
    no idea what you exactly mean
    the built-in version is supposed to work correctly as said by me above
    I am not aware of any other version that works
    the ether_wake and wakelan doesn't work on my wl500gx and my PC motherboard P5GDC deluxe, but if i use a wol windows lan soft from another PC , it works !
    what port is used ?
    Nov 2003
    Eindhoven
    what port is used ?
    it is some sort of 'magic packet' that is broadcasted at your network, I'm not familair with exact details
    are the pc's connected directly with CABLE to the WL500gx ?
    yes, they are connected directly
    if i use from an other PC a soft which send a Magic Packet, it works
    i have made a web page who send this magic packet
    i've found the pb, i have to use the broadcast option -b with wakelan
    thanks
    Question Problem with Wake on lan using WL500gx
    Hi
    i have some troubles with using wake on lan.
    Current firmware: 1.9.2.7-6b
    When i telnet to my wl500gx and use
    ether-wake <mac address> nothing happen to the target pc
    However, when i use a windows utility (http://www.depicus.com/wake-on-lan/wake-on-lan-gui.aspx) from another PC also connected to the wl500gx it work everytime ok! >> So WOL is working fine on target pc.
    Any suggestions why it isnt working from the wl500gx?
    (and why i need to fill in more info in the windows util (like IP, subnet and port) when this is not nessecery with ether-wake?)
    thnx in advance
    May 2005
    Braga, Portugal
    did you try specifying wich interface to use? for wl_500G deluxe you must use (this one works for me):
    ether-wake -i vlan0 <mac_address>
    Jun 2005
    Budapest, Hungary
    10q !!!!
    I had the same problem with WOL, but now, this solution works well !!!
    THX SocoNaTromba !!
    Thnx alot for this solution SocoNaTromba!
    It works fine now
    thnx again!
    Question WOL - Webserver
    Dear all,
    I am looking for a solution that will automatically wake up my webserver on the LAN by any request that is routed by the wl500g from WAN or LAN. I am using Olegs 1.9.2.7 6b firmware, which has included ether-wake. Also I configured a virtual server that points to my apache box.
    I already searched this forum - and googled but found no solution.
    Thank you in advance.
    v.
