Jan 1 06:00:11 xinetd[153]: xinetd Version 2.3.14 started with no options compiled in.
Jan 1 06:00:11 xinetd[153]: Started working: 2 available services
Jan 1 06:00:13 thttpd[172]: bind 0.0.0.0 - Address already in use
Jan 1 06:00:15 thttpd[172]: thttpd/2.25b PHP/5.2.0 starting on port 82
Jan 1 06:00:15 thttpd[172]: started as root without requesting chroot(), warning only
Jan 16 22:34:03 kernel: VFS: Can't find ext3 filesystem on dev sd(8,0).
Jan 16 22:34:03 kernel: MSDOS FS: Using codepage 866
Jan 16 22:34:03 kernel: MSDOS FS: IO charset cp1251
Jan 16 22:34:03 kernel: FAT: bogus logical sector size 0
Jan 16 22:34:03 kernel: VFS: Can't find a valid FAT filesystem on dev 08:00.
Jan 16 22:34:03 kernel: FAT: freeing iocharset=cp1251
Jan 16 22:34:03 kernel: VFS: Can't find ext3 filesystem on dev sd(8,2).
Jan 16 22:34:03 kernel: VFS: Can't find a valid FAT filesystem on dev 08:02.
Jan 16 22:34:04 dropbear[177]: Child connection from ::ffff:192.168.1.2:1812
Jan 16 22:34:11 dropbear[177]: password auth succeeded for 'root' from ::ffff:192.168.1.2:1812
Jan 16 22:34:12 ntp client: Synchronizing time with ntp.tomsk.ru ...
Jan 16 22:34:54 pptp[112]: anon log[logecho
ptp_ctrl.c:670]: Echo Reply received.
Jan 16 22:35:01 /opt/sbin/cron[193]: (MSapogov) CMD (run-parts /opt/etc/cron.5mins)
Jan 16 22:35:54 pptp[112]: anon log[logecho
Jan 16 22:36:54 pptp[112]: anon log[logecho
Jan 16 22:37:54 pptp[112]: anon log[logecho
Jan 16 22:38:54 pptp[112]: anon log[logecho
Jan 16 22:39:05 smbd[306]: [2007/01/16 22:39:05, 0] smbd/password.c
ass_check_smb(513)
Jan 16 22:39:05 smbd[306]: Error : UNIX and SMB uids in password files do not match for user 'Mikhail'!
ass_check_smb(513)
Jan 16 22:39:05 smbd[306]: [2007/01/16 22:39:05, 0] smbd/nttrans.c:call_nt_transact_ioctl(2516)
Jan 16 22:39:05 smbd[306]: call_nt_transact_ioctl: Currently not implemented.
Jan 16 22:39:54 pptp[112]: anon log[logecho
Jan 16 22:40:01 /opt/sbin/cron[308]: (root) CMD (run-parts /opt/etc/cron.5mins)
