Your stick is mounted to the /tmp/harddisk, not /mnt/usbfs. This is due to firmware differences: firmwares prior 1.8.x.x used /mnt/usbfs, while newer use /tmp/harddisk
I have a problem with the mounting of a usb stick,
the sandisk cruser 512Mb and the same with a apacer handy 128Mb.
I want to test the bluetooth solution. But I am not getting the stick to mount correctly. I also have a compatible hub. But for now I removed the hub and still the mounting is not working.
I need a mount on /mnt/usbfs/
Some points which may help:
-WL500g
-Firmware: 1.9.2.7-3c
-everything below is with the sandisk stick connected directly on the wl500g
-Sticks are FAT32 formated on a windows machine. (I also tried FAT)
-FTP is on.
-there are files on the stick.
Extract from the system log:
Mount:Jan 1 01:00:02 kernel: usb.c: registered new driver hub
Jan 1 01:00:02 kernel: usb-ohci.c: USB OHCI at membase 0xb8004000, IRQ 2
Jan 1 01:00:02 kernel: usb-ohci.c: usb-00:04.0, PCI device 14e4:4715
Jan 1 01:00:02 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 01:00:03 kernel: hub.c: USB hub found
Jan 1 01:00:03 kernel: hub.c: 2 ports detected
Jan 1 01:00:03 kernel: hub.c: new USB device 00:04.0-1, assigned address 2
Jan 1 01:00:03 kernel: usb.c: USB device 2 (vend/prod 0x781/0x5150) is not claimed by any active driver.
Jan 1 01:00:04 kernel: usb.c: registered new driver usblp
Jan 1 01:00:04 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 01:00:05 kernel: usb.c: registered new driver audio
Jan 1 01:00:05 kernel: audio.c: v1.0.0:USB Audio Class driver
Jan 1 01:00:06 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 01:00:06 kernel: Initializing USB Mass Storage driver...
Jan 1 01:00:06 kernel: usb.c: registered new driver usb-storage
Jan 1 01:00:06 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan 1 01:00:06 kernel: Vendor: SanDisk Model: Cruzer Mini Rev: 0.1
Jan 1 01:00:06 kernel: Type: Direct-Access ANSI SCSI revision: 02
Jan 1 01:00:06 kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Jan 1 01:00:06 kernel: SCSI device sda: 1000944 512-byte hdwr sectors (512 MB)
Jan 1 01:00:06 kernel: sda: Write Protect is off
Jan 1 01:00:06 kernel: Partition check:
Jan 1 01:00:06 kernel: p1
Jan 1 01:00:06 kernel: USB Mass Storage support registered.
Jan 1 01:00:07 kernel: lp driver: get device ID
Jan 1 01:00:07 kernel: neg fail
Mar 4 23:08:41 kernel: lp driver: get device ID
Mar 4 23:08:41 kernel: neg fail
Mar 4 22:08:41 kernel: neg fail
Mar 4 22:08:46 kernel: VFS: Can't find ext3 filesystem on dev sd(8,1).
Mar 4 22:08:46 kernel: MSDOS FS: Using codepage 950
Mar 4 22:08:46 kernel: MSDOS FS: IO charset cp950
Mar 4 22:08:46 USB storage: vfat fs mounted to /tmp/harddisk
Mar 4 23:08:46 FTP server: daemon is started
ls -als /mnt:/dev/root on / type squashfs (ro)
none on /dev type devfs (rw)
proc on /proc type proc (rw)
ramfs on /tmp type ramfs (rw)
/dev/discs/disc0/part1 on /tmp/harddisk type vfat (rw,sync)
ls /mnt/usbfs/:Nothing
ls /dev/scsi/host0/bus0/target0/lun0/:ls: /mnt/usbfs/: No such file or directory
ls /dev/scsi/:disc
part1
cat /proc/partitions:host0
mount -t vfat /dev/scsi/host0/bus0/target0/lun0/part1 /mnt/usbfs:major minor #blocks name
8 0 500472 scsi/host0/bus0/target0/lun0/disc
8 1 499851 scsi/host0/bus0/target0/lun0/part1
ps:mount: Mounting /dev/scsi/host0/bus0/target0/lun0/part1 on /mnt/usbfs failed: No such file or directory
Any clues in what I am doing wrong?PID Uid VmSize Stat Command
1 admin 572 S /sbin/init
2 admin SW [keventd]
3 admin SWN [ksoftirqd_CPU0]
4 admin SW [kswapd]
5 admin SW [bdflush]
6 admin SW [kupdated]
7 admin SW [mtdblockd]
42 admin 300 S telnetd
47 admin 440 S httpd
50 admin 356 S syslogd -m 0 -O /tmp/syslog.log -S -l 7
52 admin 316 S klogd
53 admin SW [khubd]
63 admin 272 S lpd
65 admin 248 S p9100d -f /dev/usb/lp0 0
67 admin 248 S p9101d -f /dev/printers/0 1
70 admin 360 S waveservermain
74 admin SW [usb-storage-0]
75 admin SW [scsi_eh_0]
77 admin 316 S infosvr br0
78 admin 476 S watchdog
80 admin 360 S ntp
108 admin 512 S -sh
124 admin 428 S sh -c ps > /tmp/syscmd.log 2>&1
125 admin 372 R ps
Because I am going mad on this....
TIA,
Zipper
if I am not mistaken it get mounted in tmp/harddisk (according to the log).
you may try to switch off ftp in web interface and make all mount job from scripts.
HTH
Roofcat
Thanks for the short but helpfull answer Oleg.
Than the way around this should be:
Looks like this is working.mount -o bind /tmp /mnt
ln -s /tmp/harddisk /mnt/usbfs
