Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: Firmware v1.9.3.5 BETA
    pppd starts on demand...
    Well, after further testing, I've found that pppd doesn't "link" automaticaly on reboot. But only when I launch internet explorer... So I guess the pppd link when a client send request to the wan port?
    And of course, ddns and ntp services do not start untill link is established... this is why I've thought (in my previous post) that all the starting process was erratic.
    See above: pppd links after 2 minites... just when I run internet explorer.
    Jan 1 01:00:03 USB webcam: attached
    Jan 1 01:00:07 pppd[85]: pppd 2.4.1 started by (unknown), uid 0
    Jan 1 01:00:07 pppd[85]: Using interface ppp0
    Jan 1 01:00:07 pppd[85]: local IP address 10.64.64.64
    Jan 1 01:00:07 pppd[85]: remote IP address 10.112.112.112
    Jan 1 01:00:17 USB storage: vfat fs mounted to /tmp/harddisk
    Jan 1 01:00:17 FTP server: daemon is started
    Jan 1 01:02:28 pppd[85]: Starting link
    Jan 1 01:02:28 pppd[85]: Serial connection established.
    Jan 1 01:02:28 pppd[85]: Connect: ppp0 -> /dev/pts/0
    Jan 1 01:02:28 pppd[85]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
    Jan 1 01:02:28 pppd[85]: Warning - secret file /tmp/ppp/chap-secrets has world and/or group access
    Jan 1 01:02:29 pppd[85]: Remote message: CHAP authentication success, unit 10669
    Jan 1 01:02:29 pppd[85]: Local IP address changed to 213.219.187.198
    Jan 1 01:02:29 pppd[85]: Remote IP address changed to 213.219.187.1
    Jan 1 01:02:30 ddns update: connected to members.dyndns.org (63.208.196.94) on port 80.
    Jan 1 01:02:31 ddns update: request successful
    Jan 1 01:02:33 ddns: ddns update ok
    Mar 1 13:25:40 PPPoE: connect to ISP
    Mar 1 13:25:49 ntp client: time is synchronized to time.windows.com
  2. ok
    the idle timer not work right ?
    ok no problem i have a flatrate but for people he doesn 't have a Flatrate it s a big problem
    comes a Update from OLIG ?
    i understand it when i check Tx than terminate the ISP the connecting, when Tx is not checked the terminate the Router the connecting
    is that right ?
    Twisterchen
    Apr 2004
    Netherlands
    Quote Originally Posted by Twisterchen
    is that right ?
    Sorry Twisterchen, I totally do not understand your question....
    Re-read my previous post in this thread, it explains Tx option (As it theoretically should work).
  4. ok my problem is
    i have only set idle timer to 300 sec but my router does not disconnect after 300 sec
    no Tx selected i dont understand it for what i need this
    Fix 10 problems:
    5. Idle timeout and Tx only does not work with PPPoE.
    but my connecting does not disconnect
    Twisterchen
    Apr 2004
    Netherlands
    The basics: An idle timer needs to reset in order to stop it from reaching the threshold on which it terminates the connection. This reset signal can be given on receiving (Rx) or transmitting (Tx) packets to and from the WAN.
    With all those scriptkiddies and virusses wondering around in cyberspace, you will allways receive incoming connections (=packets) even while you are doing nothing. Therefore anyone who wants the disconnect timer working properly should enable the Tx option. This should terminate the connection after the time-out time when you (or the router) doesn't send any packets anymore.
    The problem is that the Tx option was broken in previous firmwares and Asus tried to fix it in this one.
    I hope you understand now....
    Bug report and DNS question
    Hi.
    I installed firmware 1.9.3.5 and found out that "Setting Management->Save As a File" is not working, I get a zero-length file every time.
    Now a DNS question: is it possible to configure DNS entries for the local, privately addressed hosts of my home network?
    Thanks.
    Rui
    Hello,
    for me, it´s impossible to connect ISP (T-Online/Germany) with FW 1.9.3.5. I don´t know where the problem is, any ideas?
    Ronny
    Jan 1 01:00:06 pppd[66]: pppd 2.4.1 started by (unknown), uid 0
    Jan 1 01:00:06 pppd[66]: Using interface ppp0
    Jan 1 01:00:06 pppd[66]: local IP address 10.64.64.64
    Jan 1 01:00:06 pppd[66]: remote IP address 10.112.112.112
    Jan 1 01:00:32 pppd[66]: Starting link
    Jan 1 01:00:32 pppd[66]: Serial connection established.
    Jan 1 01:00:32 pppd[66]: Connect: ppp0 -> /dev/pts/0
    Jan 1 01:00:33 pppd[66]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
    Jan 1 01:01:03 pppd[66]: LCP: timeout sending Config-Requests
    Jan 1 01:01:03 pppd[66]: Connection terminated.
    Jan 1 01:01:34 pppd[66]: Starting link
    Jan 1 01:01:34 pppd[66]: Serial connection established.
    Jan 1 01:01:34 pppd[66]: Connect: ppp0 -> /dev/pts/0
    Jan 1 01:01:35 pppd[66]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
    Jan 1 01:01:35 pppd[66]: LCP terminated by peer
    Jan 1 01:01:35 pppd[66]: Modem hangup
    Jan 1 01:01:35 pppd[66]: Connection terminated.
  8. i have no problem to connect do t-online / Germany
    i connected
    useless version (at least for me)
    Idel Timeout: Try to set "0", does not work in the web interface (same in the last release version)
    PPP Connection to T-Online, connects and the disconnects
    WLAN: IP Address assignment by DHCP does not work (same in the last release version)
    I'm back to an 1.8.. Version, but these old version aren't Rockstable
    either. This Router starts to become frustating.
    Regards
    chris
    It still seems one of the best routers feature-wise... At least, with custom firmware
    I'm just waiting for the source code for something greater than 1.9.2.7 to be released, because everything so far has one problem or another. Heck, not a single ASUS firmware can serve DNS properly without adjustment.
    a couple of 1.9.3.5 beta probs
    I was trying out my WL-500g deluxe (using the correct beta firmware - but there are no responses on that thread) and I found that I could not telnet into the router as I could with FW v1.9.2.7-cr3. So how can I do that?
    Also, when setting up in client mode, I could never change from channel 1. I could set other channels, but they were ignored. <- apparently this is irrelevant. However, I never could get it to connect to my other router with this FW no matter what.
    Great Forum and I have been learning alot.
    Thanks,
    Mark
    can't change the router name ...
    I can't change the default router name ... it's always my.router
  1. Firmware v1.9.3.9 BETA
    By Antiloop in forum WL-530g Firmware Releases
    Last Post: 04-06-2006, 14:38
  2. Firmware v1.9.3.6 BETA
    By Antiloop in forum WL-300g Firmware Releases
    Last Post: 18-11-2005, 10:49
  3. Firmware v1.9.3.6 BETA
    Last Post: 27-04-2005, 08:54
  4. Firmware v1.9.3.6 BETA
    By Antiloop in forum WL-500gx Firmware Releases
    Last Post: 20-03-2005, 03:40
  5. Firmware v1.7.5.7 BETA
    Last Post: 13-05-2004, 00:03
