Last edited by vectorm; 07-04-2012 at 14:39. Reason: Всё прекрасно реализовано, читайте здесь внимательнее.
WL500GPv2 + hitachi 320GB + Samsung ML-1615 + ISP Online 80Mbits
Вот такое:
Code:[root@ASUS-Router root]$ insmod cifs insmod: cifs.o: no module by that name found [root@ASUS-Router root]$ cat /proc/filesystems nodev rootfs nodev bdev nodev proc nodev sockfs nodev tmpfs nodev pipefs ext3 nodev ramfs msdos vfat nodev devfs ntfs squashfs nodev usbdevfs nodev usbfs [root@ASUS-Router root]$
Чуть выше здесь посмотрите
И огласите версию прошивки.
Версия прошивки: 1.9.2.7-10
Вот еще одна попытка монтирования:
Code:[root@ASUS-Router root]$ modinfo cifs -sh: modinfo: not found [root@ASUS-Router root]$ mount.cifs Usage: mount.cifs <remotetarget> <dir> -o <options> Mount the remote target, specified as a UNC name, to a local directory. Options: user=<arg> pass=<arg> dom=<arg> Less commonly used options: credentials=<filename>,guest,perm,noperm,setuids,nosetuids,rw,ro, sep=<char>,iocharset=<codepage>,suid,nosuid,exec,noexec,serverino, mapchars,nomapchars,nolock,servernetbiosname=<SRV_RFC1001NAME> directio,nounix,cifsacl,sec=<authentication mechanism>,sign Options not needed for servers supporting CIFS Unix extensions (e.g. unneeded for mounts to most Samba versions): uid=<uid>,gid=<gid>,dir_mode=<mode>,file_mode=<mode>,sfu Rarely used options: port=<tcpport>,rsize=<size>,wsize=<size>,unc=<unc_name>,ip=<ip_address>, dev,nodev,nouser_xattr,netbiosname=<OUR_RFC1001NAME>,hard,soft,intr, nointr,ignorecase,noposixpaths,noacl,prefixpath=<path>,nobrl Options are described in more detail in the manual page man 8 mount.cifs To display the version number of the mount helper: mount.cifs -V [root@ASUS-Router root]$ [root@ASUS-Router root]$ mount.cifs -V mount.cifs version: 1.14-3.5.13 [root@ASUS-Router root]$ modinfo cifs -sh: modinfo: not found [root@ASUS-Router root]$ mkdir /tmp/mnt/Open cannot create directory `/tmp/mnt/Open': File exists [root@ASUS-Router root]$ mount -t cifs -o guest //192.168.1.79/ /tmp/mnt/Open mount: Mounting //192.168.1.79/ on /tmp/mnt/Open failed: No such device [root@ASUS-Router root]$
Ну ей сто лет в обед
Прошейте уже от энтузиастов чтоль
Безумно нравится вывод /proc/filesystems у psa2k наличием ext2.
Если форматирую флэшку без журнала, роутер её не подхватывает. Возможно ли малой кровью добавить поддержку ext2? Или это достижимо только пересборкой прошивки? Как вариант writeback, но хотелось бы вообще без журнала.
Аппарат wl500gP, прошивка 1.9.2.7-d-r2889.
Хард уж слишком шумит, а нужно всего писать 60кб каждые пару секунд круглосуточно. С журналом статическим прозреваю ускоренную кончину флэшки.
Записываю жпеги с ипкамеры, если кому нужны скрипты - кричите.
Code:$ cat /proc/filesystems nodev rootfs nodev bdev nodev proc nodev sockfs nodev tmpfs nodev shm nodev pipefs nodev eventpollfs ext3 nodev ramfs msdos vfat nodev devfs ntfs squashfs nodev usbdevfs nodev usbfs
Возможно. Идете туда же, где брали прошивку, забираете архив с модулями ядра, копируете оттуда ext2.o во внутреннюю память, например,
в /tmp/local/sbin, в скрипте pre-mount добавляете /sbin/insmod /tmp/local/sbin/ext2.o, перезагружаете устройство с сохранением flashfs
P.S. проверьте пути и т.п., устройства с -d прошивкой нет, пишу по памяти.
Просто подгружайте модуль ext2.ko от вашей прошивки в скрипте pre-mount (see how). Остальное прошивка сделает за вас.
Места для размещения модуля во flashfs в вашем аппарате хватит.
2 MercuryV, прям в унисон![]()
► Entware Repository ◄ RT-N66U Router + ZyXEL V352L Phone + WD TV Live Player + WD My Book Live NAS
Спасибо наигромаднейшее вам обоим! Модуль нашёл! Ура!
wl500gP 1.9.2.7-d-r2889
Господа помогите плиз разобраться с НАСои и роутером
Нас весь трафик пускает через интернет, подключен к роутеру через обычный лан порт.
Суть проблемы изложена тут.
http://www.synology-forum.ru/index.p...44&#entry27144
