Originally Posted by
hsddlawley
I take your statement to mean that MS did not lay traces on the board for usb support?
They do not trace usb pins from the bottom of the chip
But could one carefully tie into the chip directly from the bottom of the board?
Unlikely.
If the chipset provides native support are any other support componets needed outside of a usb port? Is there pinout of the chipset posted anywhere on the net?
Well, yes several resistors are needed. The pinout is as following
USB1+ P20
USB1- P21
USB1ctrl P22
USB2+ N21
USB2- N22
USB2ctrl N20
For the first you should try grounding + or - via 15K resistors, so dmesg should stop saying can't assign address. Can't remember which line exactly should be grounded - for now it acts as presense indicator, due to a missing grounding.
