Results 1 to 6 of 6
Thread: Problem with ipkg update
    First, sorry for my english.
    When i start ipkg update i get error:
    Downloading http://ipkg.nslu2-linux.org/feeds/op...le/Packages.gz
    sh: wget: Permission denied
    An error ocurred, return value: 1.
    Collected errors:
    ipkg_download: ERROR: Command failed with return value 127: `wget -q -P /opt/ipkg-znDmt5 http://ipkg.nslu2-linux.org/feeds/
    or
    error is
    /sbin/flashfs: /sbin/flashfs: 20: cat: Permission denied
    /sbin/flashfs: /sbin/flashfs: 73: [: Permission denied
    tar: Removing leading '/' from member names
    tar: /tmp/local: Unknown file type
    tar: Error exit delayed from previous errors
    /sbin/flashfs: /sbin/flashfs: 73: ls: Permission denied
    Please help me.
    hmmm looks to me like a problem that wengi had some days ago and described it in the german part of this forum.
    FastJack came with the solution for it, so gratz to him if this helps!
    I believe you have bash installed, if so check your /opt/etc/profile and remove the following code:
    PS1="[\u@\h \W]$ "
    PATH=/opt/sbin:/opt/bin:/sbin:/bin:/usr/sbin:/usr/bin
    LD_LIBRARY_PATH=/opt/lib:${LD_LIBRARY_PATH}
    export PS1 PATH LD_LIBRARY_PATH
    restart putty and it should work again hopefully
    hope that helps!
    I solve the problem,
    Thank you all,
    My profile now like this
    # Bash initialization script
    PS1="[\u@\h \W]$ "
    #LD_LIBRARY_PATH=/opt/lib:${LD_LIBRARY_PATH}
    export TERMINFO=/opt/share/terminfo
    alias mc="mc -c"
    command not found
    Hi Friends,
    i detected a similar problem, and can't understand. help please!:
    Letssee contains:
    echo Success!
    chmod is 755
    the problem is:
    login as: root
    root@192.168.1.1's password:
    -bash-3.2# cd /opt/etc/init.d
    -bash-3.2# letssee
    -bash: letssee: command not found
    -bash-3.2# /opt/etc/init.d/letssee
    Success!
    -bash-3.2#
    please HELP Dudes!
    best regards,
    peterke
    re: command not found
    PS: i allready tried to # all the lines in the profile.
    Sorry, my mistake!
    I forgot, that ./ is not in the PATH by default.
    added, resolved.
    thx!!!
  1. Error ipkg update
    By DVB in forum WL-700g Firmware Discussion
    Last Post: 23-06-2008, 22:28
  2. ipkg update error
    By sarlacc in forum WL-500gP Q&A
    Last Post: 20-04-2008, 15:53
  3. ipkg installation problem
    By Syl in forum WL-500gP Q&A
    Last Post: 26-12-2007, 16:01
