I'm playing with this thought. I don't know if it's possible, but here it goes.
A friend of mine who also owns a premium just bought a house near mine.
Less than 250m away and 'almost' line of sight., now with the right antenna's this distance can be covered, but other forums are for that problem.
Now assuming that we can have a stable link I was thinking about the following, to connect our 2 networks together with the premiums, but I don't know which way to go. Neither of us uses the router functionality of the premium, but run it in an 'client' AP only mode. 'cause we are running seperate routers for our internet connection which leads to a switch where the clients are conneted. (all wired), the premiums are in both cases directly connected to the main router(s)
What I want to do is use each other's shares and use each other's internet connection in case of fall-back/redundancy scenario.
- at the time we both have a 192.168.1.x network, will we have to change this?
- do I have to / can I create seperate vlan's for this, just to only use the internet connection, but secure the clients in my lan from accessing from clients from my friends lan?
- What about 'stacking' the 2 internet connections? we both have 24mbit connections but from other (network)providers. (that's why the fall-back)? (this is not a must have, only nice-to-have)
- how to setup clients? is one gateway enough, or do I have to specify more gateway's (ip addressing?)
- I suppose this is kind of a bridge mode, but don't know for sure...
I've enclosed a picture of our network(s)
I hope someone can point me in the right direction.
