Results 1 to 7 of 7
Thread: Firmware with .trx extension rejected by wl-500b
    Jan 2005
    Antwerpen
    Hi everybody!
    I have this weird problem with my wl-500b wlan router. I can't get it to accept .trx files for upload!
    When I try through the web interface the upload seems to work but when the file is uploaded I get the message "Upload abort! Image file is wrong".
    Next up was "firmware restoration". I put my wl-500b in rescue mode and used the restoration tool to upload my firmware.
    The first thing I notice is that the file explorer of this tool only shows .img files. I can however select .trx files by selecting "all files" from the drop-down menu.
    When I do select a .trx file, the tool shows the following error: "Header crc-32 error". It won't let me upload this file extension.
    On the cd that came with my wl-500b I found the original firmware version in .img format. Just out of curiosity I tried to upload it and guess what... it gets accepted!
    Am I missing something here? Is there a way to update my wl-500b with new firmware or am I stranded?
    Any help would be greatly appreciated.
    Greets,
    Jay Jay
    PS: The firmware I tried to use:
    unofficial
    http://wl500g.dyndns.org/1.9.2.7-3/W...1.9.2.7-3a.trx
    official
    http://www.asuscom.de/pub/ASUS/wirel...L500bv2_EN.zip
    As seems you have wl-500 router, which is different from wl-500b, wl-500g and friends. It's old and unsupported.
    Jan 2005
    Antwerpen
    Okay I see...
    Thanks for the quick response!
    You say it's unsupported, but do you know of any unofficial firmware versions for this wl-500?
    Or is there a way to convert .trx files to .img files? (just dreaming out loud :-)
    I've no idea.
    Apr 2004
    Netherlands
    Quote Originally Posted by jayjay
    Okay I see...
    Now you know you have a WL-500 you might want to check the Asus website for the latest firmware.
    The firmwares for WL-500b, g and gx will most likely not work on your router, so there's no need in converting the trx files.
    Jan 2005
    Antwerpen
    Jep, I had the same idea so I checked their site immediately. Unfortunately it seems that there was only a minor update after the original firmware. I'll try it out this evening anyway...
    Dang, that's too bad. Oh well, I'll have to buy a new wlan router anyway some time this year. My provider is planning on boosting download speed to 51 mbps (theoretically that is :-). I'm stuck with 11 mbps now :-/
    Anyone can give me a hint for a good wlan router set?
    Thanks for the replies guys!
    Apr 2004
    Netherlands
    WL-500g or WL-500gx ofcourse
  1. old firmware for WL-500b
    By krtekhb in forum WL-500b Firmware Releases
    Last Post: 02-12-2005, 09:48
  2. No wireless on wl-500b whit new firmware
    By ancorato in forum WL-500g Q&A
    Last Post: 20-04-2005, 09:30
  3. Firmware for WL-500B
    By Pandabeer in forum WL-500g Q&A
    Last Post: 13-04-2004, 17:27
  4. Use firmware for WL-500G in WL-500B
    By Technik in forum WL-500g/WL-500gx Tutorials
    Last Post: 10-04-2004, 18:42
