Like cyrus, dovecot gives me also some errors, which I can't explain.
dovecot.conf
base_dir = /opt/var/run/dovecot
protocols = imap
ssl_disable = yes
disable_plaintext_auth = no
log_path =/opt/var/log/dovecot.log
info_log_path =/opt/var/log/dovecot.info
#login_user = root#dovecot
login_process_size = 32
login_process_per_connection = yes
login_processes_count = 3
login_max_processes_count = 128
first_valid_uid = 1
last_valid_uid = 0
default_mail_env = maildir:/tmp/harddisk/mail/%u/Maildir
auth_verbose = yes
auth default {
# Space separated list of wanted authentication mechanisms:
# plain digest-md5 cram-md5 apop anonymous
mechanisms = plain
passdb passwd-file {
args = /opt/etc/dovecot/users
userdb static {
args = uid=info gid=info home=/tmp/harddisk/mail/%u
/opt/etc/dovecot/users is owned by dovecot:dovecot with chmod 777
The only mailbox available is 'info' owned by info:info
The error from /opt/var/log/dovecot.log:
dovecot: Jul 16 10:48:39 Error: Auth process died too early - shutting down
dovecot: Jul 16 10:48:39 Error: auth(default): Panic: Leaked file fd 7: dev 0.5 inode 175292
dovecot: Jul 16 10:48:39 Error: child 7846 (auth) killed with signal 6
I can't find a solution to solve this, because I can't find the actual error.
update:
after a reboot all things are correctly started, but when I restart dovecot I get the error above
1857 ? S 0:00 \_ dovecot-auth
1861 ? S 0:00 \_ [imap-login]
1860 ? S 0:00 \_ [imap-login]
1862 ? S 0:00 \_ [imap-login]
I can't match that.
