Hello,
I followed guide to install kfurge and then mlnet to a WL700GE router. If I start /shares/MYVOLUME1/rc.local manually, mlnet starts, and I can access it via port 4080. However, it does not start automatically after boot.
What could be wrong?
Thank you very much in advance.
Cheers,
redrunner
Contents of my rc.local file:
pool=`nvram get apps_pool`
share=`nvram get apps_share`
internal_hdd=/dev/ide/host2/bus0/target0/lun0/disc
if [ \! -f /tmp/rc.local.done ]; then
# Indicate we've already done this
touch /tmp/rc.local.done
# Mount /opt and connect in various system files
if [ -e /shares/${pool}/opt ]; then
mount -o bind /shares/${pool}/opt /opt
cat /proc/mounts > /opt/etc/fstab
ln -s /opt/etc/shells /tmp/shells
ln -s /opt/etc/fstab /tmp/fstab
export PATH=/opt/bin:/opt/sbin:${PATH}
export LD_LIBRARY_PATH=/opt/lib:${LD_LIBRARY_PATH}
# Start utelnetd on local interface only!
/apps/bin/utelnetd -i br0 &
/opt/etc/init.d/S51dropbear
# Sleep for a little bit to not interfere with normal system startup
# before we kill a bunch of Asus processes.
sleep 5
# The killing of watchdog is necessary
# to allow the disk to spin down (watchdog is a horribly written hack
# anyway!)
killall -q -9 watchdog
# Do the necessary steps so the internal HDD will spin down
mount -o remount,noatime,nodiratime /shares/${pool}
hdparm -S 180 ${internal_hdd}
smartctl -dT ${internal_hdd}
echo "interrupt=no" > /proc/miscio/power_enable_config
/opt/etc/init.d/mlnet
Dear Marc,
Where can I find the mentioned newest firmware?
thanks a lot
rr
Under your nose:
http://wl500g.info/showthread.php?t=12615
Marc
