Oleg,
here is some part of the answer :
The routeur is in the "Home Gateway Mode".
The host name in the IP settings is set to "Maison"
The cat/etc/hosts gives :
127.0.0.1 localhost.localdomain localhost
192.168.1.1 Maison my.router my.WL500g
The cat/etc/smb.conf
[global]
workgroup = WORKGROUP
guest account = nobody
security = share
browseable = yes
guest ok = yes
guest only = yes
log level = 1
max log size = 100
encrypt passwords = no
preserve case = yes
short preserve case = yes
[share]
path = /tmp/harddisk
The cat /var/log/smb give
If that can help you to help me !!!! Thanks a lot !
Regards
Jean-François
