Thanks oleo
ipkg update && ipkg upgrade
Thanks oleo
regarding the transmission port: which webserver are you using?
If it is the default (busybox) you should have a look at /opt/etc/init.d/S80busybox_httpd.
Look for a line like "LISTENING_PORT=8008".
wengi
Yea I figured it out last night poking around in the folders for opt/etc/ init.d found it in there. I was wondering If I decide to use lighttfpd to is better because it has ssl. It was one of the tutorials in the post for more tricks and stuff. I just want to make the transmission website secure so other people can't access it from LAN.
Every time I hit "Log" button in the transmission web interface, I get different graph, but every time it's not the right one... e.g. graph shows that transmission was not running for a day, even if it was, or the graph shows values for 2 days ahead, or 2 days in the past... what's up with that?
Maybe troubles with date/time and ntpclient.
Sorry im really stupid at this..
How do i do this??
Please help
Hi all,
I have WL500gP with Oleg FW and with Transmission. Transmissions run without problems but I'm active only if i stop internet firewall. When is firewall runnig my status is pasive. I tried open ports (my listen port for trans. is 9090) but without efect. Can you help me? Thamks.
Try to add this to /usr/local/sbin/post-firewall where XXX is the portnumer.
wengiCode:#!/bin/sh # this opens the port number XXX to internet! iptables -I INPUT -m tcp -p tcp --dport XXX -j ACCEPT
PS: My HowTo, Chapter 14b. (Done for ssh)
i tried it, but without effect. I read your how to, but after save and reboot is port still close.
When i try port here: http://www.canyouseeme.org/ i have reason:
Error: I could not see your service on xx.xx.xxx.xxx on port (9090)
Reason: Connection timed out
When i disable firewall, all is open. But it is unusable
Do a forum search for iptables.
You will find many threads dealing with opening ports and the right order of rules.
wengi
