Upgrade to CR3a as I wrote before.
today i had the second time an crash of the pppoed. After a restart everything works fine. will this problem fixed i the next cr release? I want to try out 1.9.2.7 CR3a now.
Bye Enno
My FW is 1.9.2.7 CR3
Here is my log:
yesterday:
Jan 1 04:48:22 pppd[2849]: pppd 2.4.3 started by admin, uid 0
Jan 1 04:48:57 pppd[2849]: Timeout waiting for PADO packets
Jan 1 04:48:57 pppd[2849]: Fatal signal 11
Jan 1 04:48:57 pppd[2849]: Exit.
today:
Jan 1 01:00:05 pppd[71]: pppd 2.4.3 started by admin, uid 0
Jan 1 01:00:05 kernel: lp driver: get device ID
Jan 1 01:00:40 pppd[71]: Timeout waiting for PADO packets
Jan 1 01:00:40 pppd[71]: Fatal signal 11
Jan 1 01:00:40 pppd[71]: Exit.
I have upgraded from 1.8.1.7-3 to 1.9.2.7-3, thanks for all the work Oleg, but I found that the router loses its LAN host name after a number of hours.
I then have to use the direct IP address for web admin and telnet. This means that samba drive mapping stop working until I reboot the router.
I have checked the hosts file and it is still OK.
The router kept its host name with 1.8.1.7-3. but samba kept failing as already described.
Thanks
Hi Oleg,Originally Posted by Oleg
attached you will find the log after 24h, the wl500g doesn't reconnect after the ISP disconnected the line. I had manually to reconnect.
Regards Georg
Ok, I see. Same thing happened to me. ppp-2.4.3 seems to be buggy, I will probably will go to 2.4.2...Originally Posted by GeorgJ
Also, what happened after
Jan 11 22:38:16 pppd[232]: Connection terminated.
Jan 11 22:38:16 pppd[232]: PPP session is 4339
Jan 11 22:38:16 pppd[232]: Using interface ppp0
Jan 11 22:38:16 pppd[232]: Connect: ppp0 <--> eth1
Jan 11 22:38:16 pppd[232]: Modem hangup
Jan 11 22:38:46 pppd[232]: Modem hangup
Jan 11 22:38:46 pppd[232]: Connection terminated.
Hi Oleg!Originally Posted by Oleg
Nothing happened, I had to reconnect manually.
Regards Georg
Nothing? I mean do you've anything in the log below this point? Saying something like Exit?
Could you please post complete log?
Incidently I rebooted and not only reconnected the router. The log was cleared. I will send you the log after this happens again tonight, around 23:30.Originally Posted by Oleg
Regards Georg
Ok, thanks. In the mean time I will post 1.9.2.7-3b with ppp-2.4.2, which is more stable as seems. I'm started testing it right now. This will took 24h also...
I'm new at this. I've just bought a wl500G. Reception is good for only a few metres away, but transmission failes even to a PC on the next floor in my house. I've upgrade the drivers for the PCI cards...didn't help. Fiddled with the original and a new (external) antenna and it won't work! Now i'm told your latest firmware upgrade makes it possible to control and dramatically increase the signal strenght of the 500G. Is that true and if so, how do i install the firmware on my router? (I told you, i'm new at this ) My operating system is WinXP.
Start by reading the manuals. How to upgrade firmware is described in detail. Doesn't harm to read first and then askOriginally Posted by Michael57
Quick howto:
go to http://my.router, logon to it as admin, and go to tab system setup, click firmware update, point to directory where you have downloaded the new firmware and click update.
Wait until your browser screen gets updated and presto.
Here is the new log. It didn't reconnect at all, even not manually.Originally Posted by Oleg
I will install the b-version.
Good Night.
Georg
Just installed this firmware for Samba. Works really flawless on my environment!
Thanx for the excellent work, Oleg!
Oleg, I've download the firmware (I've bought the wl 500g two days ago and I've tried to connect my HP 710C printer (parralel). But it still doesn't work. I've understood that with the new firmware this problem should be solved. But my system (XP-SP2) doesn't recognize the TRX extension. Which program do i need to instaal the new firmware?Originally Posted by Oleg
