Results 1 to 15 of 17
Thread: transmission.cgi using 100% cpu
    Feb 2005
    Germany - Frankfurt
    Hi there,
    i installed my WL-HDD from the scratch with the -9 firmware.
    Setup is exactly as in my HowTo (see sig).
    I (and several other users) have the problem that the transmission.cgi is hanging when listing the torrents. At this point it consumes 100% cpu.
    The attached picture shows this behaviour in the browser.
    This are the running processes:
    [admin@blechbuechse torrent]$ ps axf
      PID TTY      STAT   TIME COMMAND
        1 ?        S      0:02 /sbin/init
        2 ?        S      0:00 [keventd]
        3 ?        SN     0:00 [ksoftirqd_CPU0]
        4 ?        S      0:00 [kswapd]
        5 ?        S      0:00 [bdflush]
        6 ?        S      0:00 [kupdated]
        7 ?        S      0:01 [mtdblockd]
       46 ?        S      0:00 telnetd
       51 ?        S      0:01 httpd
       56 ?        S      0:00 klogd
       57 ?        S      0:00 [khubd]
       67 ?        Ss     0:02 watchdog
       69 ?        Ss     0:00  \_ ntp
       78 ?        S      0:00 dropbear
      396 ?        Ss     0:05  \_ dropbear
      397 pts/0    Ss     0:03      \_ -sh
      569 pts/0    R+     0:00          \_ ps axf
       90 ?        S      0:00 [kjournald]
       91 ?        S      0:00 [kjournald]
      117 ?        S      0:00 /sbin/syslogd -m 0 -O /opt/var/log/messages.log -S -l 6 -s 0
      123 ?        Ss     0:00 /opt/sbin/cron
      132 ?        Ss     0:00 /opt/sbin/xinetd -pidfile /var/run/xinetd.pid
      142 ?        Ss     0:05  \_ nmbd
      551 ?        Ss     0:05  \_ [smbd]
      141 ?        S      0:00 /usr/sbin/busybox_httpd -c /opt/etc/httpd.conf -p 8008 -h /opt/share/www
      555 ?        S      0:00  \_ /usr/sbin/busybox_httpd -c /opt/etc/httpd.conf -p 8008 -h /opt/share/www
      556 ?        S      0:00      \_ /bin/sh /opt/share/www/cgi-bin/transmission.cgi
      568 ?        R      0:08          \_ /bin/sh /opt/share/www/cgi-bin/transmission.cgi
      293 ?        Ss     0:00 transmissiond -p 65534 -w 300 -u 41 -d 180 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
      296 ?        S      0:00  \_ transmissiond -p 65534 -w 300 -u 41 -d 180 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
      297 ?        R      2:06      \_ transmissiond -p 65534 -w 300 -u 41 -d 180 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
    - I am using busybox-httpd.
    - I also tried to change the paths in transmission.conf to /tmp/mnt/disc0_3/torrent (maybe the symlink...)
    - I upgraded to Version 1.11+r5740-1
    ...but nothing worked.
    The only way to stop transmission.cgi is to kill the process within console.
    transmissiond is working fine ans downloads are as always
    Any ideas?
    wengi
    Feb 2005
    Germany - Frankfurt
    Noone?
    wengi
    Hi wengi,
    just following up on this 'cause we've discussed this in another thread.
    Have you tried lighttpd to run the transmission.cgi ?
    Maybe the problem is not with the transmission.cgi, but in the way it runs in busybox-httpd
    Feb 2005
    Germany - Frankfurt
    i changed to lightttpd today.
    Status page is ok but pushing a torrent hangs.
    I have no idea how to set cgi (perl?, shell?). That is one of my biggest probs atm.
    I think i will have to try thttpd within the next days....
    wengi
    Hi, I have the same problem.
    Maybe this info can help a little more:
    If I click on "Update" with 2 torrent running, I get the web interface frozen.
    Than from the console:
    [admin@WL-HDD root]$ ps axf
        1 ?        S      0:03 /sbin/init
        3 ?        RN     0:36 [ksoftirqd_CPU0]
        4 ?        S      0:53 [kswapd]
        7 ?        S      0:27 [mtdblockd]
       45 ?        S      0:00 telnetd
       57 ?        S      0:00 klogd
       60 ?        S      0:00 [khubd]
       67 ?        Ss     4:10 watchdog
       69 ?        Ss     0:01  \_ ntp
       76 ?        S      0:01 dropbear
     8970 ?        Ss     0:02  \_ dropbear
     8996 pts/0    Ss     0:00      \_ -sh
     9060 pts/0    R+     0:00          \_ ps axf
       93 ?        S      0:00 [kjournald]
       94 ?        S      0:32 [kjournald]
       96 ?        Ss     4:43 /usr/sbin/nmbd -D
       98 ?        Ss     0:00 /usr/sbin/smbd -D
     8205 ?        S      0:05  \_ /usr/sbin/smbd -D
      125 ?        S      1:03 /sbin/syslogd -m 0 -O /opt/var/log/syslog.log -S -l 7 -s 0
      130 ?        Ss     0:01 /opt/sbin/cron
      139 ?        S      0:01 /usr/sbin/busybox_httpd -c /opt/etc/httpd.conf -p 8008 -h /opt/share/www
     9040 ?        S      0:00  \_ /usr/sbin/busybox_httpd -c /opt/etc/httpd.conf -p 8008 -h /opt/share/www
     9041 ?        S      0:00      \_ /bin/sh /opt/share/www/cgi-bin/transmission.cgi
     9059 ?        R      0:02          \_ /bin/sh /opt/share/www/cgi-bin/transmission.cgi
      203 ?        SNs    0:05 transmissiond -p 65534 --nat-traversal -e -w 300 -u 10 -d -1 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
      206 ?        SN     0:00  \_ transmissiond -p 65534 --nat-traversal -e -w 300 -u 10 -d -1 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
      207 ?        RN   205:15      \_ transmissiond -p 65534 --nat-traversal -e -w 300 -u 10 -d -1 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
      212 ?        S      1:06 httpd
    No if I kill the latest "transmission.cgi":
    [admin@WL-HDD root]$ kill 9059
    the web interface will show one row more, I repet the procedure one more time and the web interface i fully loaded:
    For me it seams that everytime "transmission.cgi" is "looking" to an active or finished torrent it get stuck..
    Feb 2005
    Germany - Frankfurt
    Yep, same behaviour here.
    wengi
    Jun 2005
    Slovenia
    I do not have such behaviour. And transmission.cgi was not changed for some time. So, could you please try
    sh -x /opt/share/www/cgi-bin/transmission.cgi
    to see where it stops. It could be some external tool that freezes.
    Feb 2005
    Germany - Frankfurt
    Hi oleo,
    thanks for your reply.
    i attached the result of your request.
    The normal call of transmission.cgi is working well at the moment, so you will not see any problems in the attachment.
    The cgi hangs when i try to push a torrent from queued to active.
    Is there a shell command for this push request?
    wengi
    Jun 2005
    Slovenia
    Try this:
    QUERY_STRING='ACTION=Push&ID=21' sh -x /opt/share/www/cgi-bin/transmission.cgi
    ID is the line number.
    Feb 2005
    Germany - Frankfurt
    i now did a
    And saw this part:
    <table>
    <thead><tr><td></td><td>Queued</td><td>status</td></tr>
    </thead><tbody>
    <tr><td><input name=ID value=1 type=radio></td>
    <td>OOo_2.4.0_Win32Intel_install_de.exe</td>
    </tbody></table>
    So i did a
    QUERY_STRING='ACTION=Push&ID=1' sh -x /opt/share/www/cgi-bin/transmission.cgi
    I hope this is the right command to push the torrrent with ID 1 from q to a.
    It stopped here:
    + echo OOo_2.4.0_Win32Intel_install_de.exe</td>
    + [ -f /tmp/mnt/disc0_3/torrent/work/OOo_2.4.0_Win32Intel_install_de.exe/.info ]
    + echo <td><div style='position:relative;'>
    + [ Active = Seeding -o Active = Active ]
    + [ -f /tmp/mnt/disc0_3/torrent/work/OOo_2.4.0_Win32Intel_install_de.exe/.status ]
    + STATUS=status not available
    + echo <div style='position:relative;'>status not available
    + echo  Start: 30 May 11:28
     Start: 30 May 11:28
    + [ -n  ]
    The full file is attached.
    Opening a second shell and doing a list shows that torrent ID1 is now active. But the first shell is still hanging in transmission.cgi (since more than 15 mins).
    CPU usage of transmission.cgi (process "sh") is 100%.
    wengi
    Jun 2005
    Slovenia
    It stops at the following:
     echo "<div style='position:relative;'>${STATUS}"
                    echo " Start: ${STARTTIME}"
                    [ -n "${ENDTIME}" ] && echo " End: ${ENDTIME}"
                    [ -n "${SCRAPE}" ] && echo " ${SCRAPE}"
    And I do not see problem here. So it must be elsewhere.
    Try to replace interpreter in first line
    with
    #!/opt/bin/busybox sh
    after you installed busybox-base packages.
    Or maybe bash.
    Feb 2005
    Germany - Frankfurt
    Strange.
    i installed the three busybox 1.10.2 packages and rebooted.
    busybox 1.10.2 is now used as default.
    Pushing the torrent several times via shell wa allways fine.
    Trying to push the torrent via local lynx ends in hang up.
    Pushing via IE or FF over a ssh tunnel works fine now....
    I have no idea what is going on but i will test some torrents with the new busybox version.
    thanks for now
    wengi
    EDIT: Modifiying transmission.cgi as you recommended doesn't make a difference (tested).
    Feb 2005
    Germany - Frankfurt
    After some time of testing i can report the following:
    installing ipkg-busybox does the trick.
    Everything works fine except for the local installed lynx browser.
    Lynx still hangs on pushing torrents.
    Maybe this is something with core-/fileutils replacing the orig. busybox commands in the new firmware and diffs in the coding (german umlaute äüö and other special chars)
    But this seems to be an acceptable workaround.
    Thanks oleo
    wengi
    It is working also for me.
    You install the busybox package and replace the interpreter in the first line of transmission.cgi as advised by Oleo.
    Thanks!!
    Jun 2005
    Slovenia
    It would be nice if someone can isolate a problem or maybe ask Oleg to upgrade stock busybox. But then, maybe the problem is with old uClibc 0.9.19 use in Oleg firmware and just upgrading would help. Again Oleg is endpoint address.
  1. init çàíèìàåò áîëüøå 95% CPU
    By vladf in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 12-12-2008, 00:15
  2. 2 same wl-500gP with diff. CPU performance?
    By dyonisos in forum WL-500gP Q&A
    Last Post: 07-04-2008, 21:13
  3. Increase cpu speed
    By Sir Lancelot in forum WL-500gP Firmware Discussion
    Last Post: 28-12-2006, 18:05
