Originally Posted by
Reyter
Еще вопрос.
Установлены из репозитария:
busybox - 1.10.3-1 - A userland replacement for embedded systems.
busybox-base - 1.10.3-1 - A userland replacement for embedded systems.
busybox-links - 1.10.3-1 - A userland replacement for embedded systems.
coreutils - 6.12-2 - Bunch of heavyweight *nix core utilities
софт-линк на ps ведет на бизибокс.
ps -A упорно выдает illegal option
Куды копать? В кореутилс никакого ps нету. У меня, во всяком случае.
У кого эта команда работает, посмотрите что у вас конкретно установлено.
Вот мой список:
[admin@router root]$ ipkg list_installed
\\ skipped \\
coreutils - 6.9-7 -
\\ skipped \\
diffutils - 2.8.1-6 - contains gnu diff, cmp, sdiff and diff3 to display differences between and among text files
\\ skipped \\
ipkg-opt - 0.99.163-9 -
libtorrent - 0.12.0-2 -
lighttpd - 1.4.18-3 -
ncurses - 5.6-3 - NCurses libraries
ncursesw - 5.6-2 - NCurses libraries with wide char support.
net-tools - 1.60-5 -
pcre - 7.6-2 -
perl - 5.8.8-17 - Practical Extraction and Report Language.
perl-compress-zlib - 1.42-2 - Compress-Zlib - Interface to zlib compression library.
perl-digest-sha1 - 2.11-2 - The module allows you to use the NIST SHA-1 message digest algorithm.
perl-html-parser - 3.55-2 - A collection of modules that parse and extract information from HTML documents.
perl-html-tagset - 3.04-4 - This module contains data tables useful in dealing with HTML.
perl-libwww - 5.805-4 - libwww-perl - The World-Wide Web library for Perl
perl-uri - 1.35-3 - URI - <module_description>
php - 5.2.5-1 -
php-fcgi - 5.2.5-1 -
php-gd - 5.2.5-1 -
php-mbstring - 5.2.5-1 -
procps - 3.2.7-6 - PROCPS System Utilities
rrdtool - 1.2.27-1 - Round-Robin Database tool. Database collator and plotter
rtorrent - 0.8.0-1 -
screen - 4.0.3-2 - A screen manager that supports multiple logins on single terminal
sqlite - 3.5.6-1 -
uclibc-opt - 0.9.28-13 - micro C library for embedded Linux systems
xmlrpc-c - 1.11.00-3 - A library providing modular implementation of XML-RPC for C and C++.
\\ skipped \\
Еще хорошая команда ps axf - показывает все запущенное в древовидной форме.
