Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 65
Thread: Firmware v1.9.2.7 CR2 [Oleg]
    Firmware v.1.9.2.7 CR2 problems with RADIUS auth
    Just updated my WL300g with the new v.1.9.2.7 CR2 firmware and, as I use RADIUS authentication, I could no longer access the wireless network, but via ethernet I can access the AP, configure it via web and access it via telnet or ssh. The RADIUS server is not even contacted by the AP with this firmware. Nevertheless, the v.1.9.2.7 CR1 firmware works like a charm! Maybe I'm putting this message in the wrong forum, but as the WL300g forum is kinda empty and as Oleg offers also custom firmware for this AP, I decided to post this here.
    Thanks in advance!
    Quote Originally Posted by solha
    Thanks in advance!
    Yes, this is expected. Looks like I'm was right - radius does not work with ASUS 1.9.2.7, thank you for your report. I will disable WPA2 back as it was in the 1.9.2.7-1.
    Exclamation
    People, I've been having a problem not reported here yet, as far as I've read.
    I've configured static ip's in the lan network and the lease time is set to 24h. Each 24h the computers in the lan lose their ip address and internet connection and get up again a few seconds later, but just long enough to drop alot of things from online availability.
    Previously I used firmware version 1.8.1.3, but since I started testing/using firmware version 1.9.2.7-1 and now firmware version 1.9.2.7-2, this problem started to happen.
    Thx in advance for any answer.
    The error code returned by windows in the events logging:
    The IP address lease 192.168.1.2 for the Network Card with network
    address xxxxxxxxxxx has been denied by the DHCP server 0.0.0.0
    (The DHCP Server sent a DHCPNACK message).
    Quote Originally Posted by Raposo
    Do you've anything in the wl-500g logs? Most likely you've some other dhcp server on you network.
    I'll try to get the logs tomorrow, but I'm almost sure I have no other dhcpd in the network, and this problem just started to happen after using this firmware, never happened in 1.8.1.3, the one I used before this version.
    LPR Daemon Flood
    Hi all,
    First of all, I'd like to thank Oleg and others for their great work on the WL-500g.
    Here is the strange thing I have detected : since I upload and use the firmware 1.9.2.7 CR2 [Oleg], I can observe this thing in the system log :
    "Dec 30 06:16:41 kernel: lp_wait_ready timeout
    Dec 30 06:16:41 kernel: lp_write timeout
    Dec 30 06:16:46 kernel: lp_wait_ready timeout
    Dec 30 06:16:46 kernel: lp_write timeout
    etc ...
    A real flood from the LPR daemon when my printer is switch off.
    And when I switch on my printer (Deskjet 920C), it prints, sometimes, without any request, this kind of information :
    "PARPORT: DESKJET 920C"
    Of course, In one hand, I don't want my printer to print thing alone ; And in the other hand, I want to switch off my printer when I don't use it.
    Thank you for your support.
    Quote Originally Posted by N3oXid
    Hi all,
    etc ...
    Ok, I will check on this, looks like debug output.
    In the mean time I'm suggesting you to write to ASUS Tech support.
    Question USB Plug-‘n'-share speaker
    hi, ppl
    ive been away for some time, so i dont know whats new at this forum.
    what i would like to to know is if this firmware support "USB Plug-‘n'-share speaker" reported by asus on the latest firmware avaible???
    Is this the exact message? I mean character case and so on?
    Also, have you tried using RAW printing instead?
    Aug 2004
    Quote Originally Posted by jimmy
    ...i would like to to know is if this firmware support "USB Plug-‘n'-share speaker" reported by asus on the latest firmware avaible???
    She does
    Oct 2004
    Portugal
    Exclamation
    Oleg
    I already shutdown WL-500g for 20m, but the WL-500g are continue to restart!!
    The Wl-500g restart only when I suft on the internet, but not all the time!
    After WL-500g restart must of the time, can't connect to the internet..
    When I shutdown the power and power on, the wl-500g connect normaly..
    Jan 1 00:00:11 pppoe-relay[74]: PADO packet from 00:90:1a:10:11:cb on interface eth1 does not have Relay-Session-Id tag
    Jan 1 00:00:11 kernel: lp driver: get device ID
    Jan 1 00:00:11 kernel: neg fail
    Jan 1 00:00:22 wan: disconnected manually
    Jan 1 00:00:23 pppd[79]: Hangup (SIGHUP)
    Jan 1 00:00:23 pppd[79]: Terminating on signal 15.
    Jan 1 00:00:23 pppd[79]: Failed to negotiate PPPoE connection: 4 Interrupted system call
    Jan 1 00:00:23 pppd[79]: Exit.
    Jan 1 00:00:24 dnsmasq[40]: read /etc/hosts - 4 addresses
    Jan 1 00:00:24 dnsmasq[40]: reading /tmp/resolv.conf
    Jan 1 00:00:25 wan: connected manually
    Jan 1 00:00:27 pppoe-relay[74]: recv (receivePacket): Network is down
    Jan 1 00:00:27 pppd[116]: PPPoE: Use eth1 for PPPoE discovery
    Jan 1 00:00:27 pppd[118]: pppd 2.4.1 started by admin, uid 0
    Jan 1 00:00:27 pppd[118]: Sending PADI
    Jan 1 00:00:32 pppoe-relay[74]: PADO packet from 00:90:1a:10:11:cb on interface eth1 does not have Relay-Session-Id tag
    Jan 1 00:00:32 pppoe-relay[115]: PADO packet from 00:90:1a:10:11:cb on interface eth1 does not have Relay-Session-Id tag
    I willl do an downgrade to the firmware!
    Home Page
    Marco Sousa from PORTUGAL
    Quote Originally Posted by int
    Oleg
    Try disabling pppoe relay first.
    Thanks in advance!
    Would you like to try firmware with some things fixed?
    Anybody with working radius setup is also welcome.
    Oct 2004
    Portugal
    Exclamation
    When I connect to WL after intro my password this(in attach) apears in my browser..
    I do a refresh, and them the page open well.
    Oleg, now after I disable PPPoE Relay, the wl connects well, but the WL also restart very times... (17 times for now)
    I do a downgrade to the firmware!
    With fw 1.7.5.9-5 Oleg WL are working very well.
    Home Page
    I had these messages in my syslog when I killed the lpr process using telnet. I happened to have a printer plugged into the parallel port that was off, and one plugged in the USB port that was on.
    I am having problems with a dropped connection w/ the new firmware, although I have a suspicion it is more from my broadband provider than from the router. I'll keep you posted on how setting to a fixed speed in the web admin tool works.
    Last Post: 13-04-2005, 23:26
  2. Firmware v1.7.5.9 CR2 [Oleg]
    Last Post: 06-10-2004, 08:12
  3. Firmware v1.7.5.6 CR2 [Oleg]
    Last Post: 05-05-2004, 03:10
    Last Post: 03-05-2004, 11:13
    Last Post: 07-04-2004, 17:22
