WL500g restart very times...
With:
Firmware v.1.9.2.7 CR2 [Oleg]
Firmware v.1.9.2.7 CR1 [Oleg]
and maybe 1.9.2.7 but I have not test!
New firmware, which contains several fixes are available for download.
The exact changes are:
- WPA2 & WME enabled, but WPA is not fully functional as seems
- Fixed WL-500gx USB 1.1 devices support
- Fixed ASUS firmware firewall problems (PPTP passthrough should work now)
- Fixed wshaper problems (was not functional in the 1.9.2.7-1)
- Added WL-500gx rootfs support
With:
Home Page
Marco Sousa from PORTUGAL
Hi i have uploaded 1.9.27CR2 from oleg and i have problem with my ftp. I can conect on it i see everything on ftp but i cant download nothing. An with original from asus it works. Where is the problem ??
And another one question. With original it works but the speed is only 300 kB/s. I have readed that there is USB1.1 and the transfer on USB1.1 is 1000 kB/s. Can you help me that i can download with full sped ?? plss
Yes, I've noticed the same problem with ftp on 1.9.2.7 CR1. I get the directory and file listing, but when I try to download the file, I get the file, but the resulting downloaded size is 0kb. The USB hard disk is 40gb with NTFS , and maybe that is causing the problem.
I have a 160GB WD. I have watch a system log and there has it found corectly.
And can you help me with the transfer speed pls.
Turn off your wl500g for ten minutes and then turn it on.Originally Posted by int
How you're accessing ftp - anonymously or using create account. If you've created account, then please write down Rights, which you've assigned to user.Originally Posted by Viper_Jaro
Also, does upload works for you?
I have accesed als anonymous als supervisor. And nothing. Always i can only list the directories and nothing to downloaden.
To the user acces, where can i find the ruls or samples ???
Read user manual.Originally Posted by Viper_Jaro
Does upload works for you?
Tried download - works fine for anonymous, but I do not have ntfs here. You may probably need to try with fat.
Hello people!!
Add Portugal to the Time Zone!
Portugal are like (GMT) England !
thks for this forum
Home Page
i havent tried upload.
And download dont work :-(
Either use England, or provide me an abbrevated time zone name to be added.Originally Posted by int
Alternatively you could contact ASUS technical support to add this.
Time Zone:Originally Posted by Oleg
http://www.timeanddate.com/worldclock/city.html?n=133
Home Page
I have tryied my second USB key and it work perfectly. I dont now why with that USB HDD works it no when the origi bios work.
