Results 1 to 5 of 5
Thread: Mount a LAN Samba share - Help
    Hi All,
    I have a NAS device on my LAN (MyBook World Edition) - it is connected to the router by ethernet and has folders shared using samba.
    What I would like to do is mount these shares using busybox.
    Is this possible and how can I do it - In Ubuntu I just use "smbmount" but this command is not available on busybox.
    Thanks in advance
    Velcrow
    yes its possible!
    Install oleg firmware if you havent allready.
    Download this file http://wl500g.info/showpost.php?p=49867&postcount=2
    save it somewhere on your router.
    connect to your router with your favorite ssh client and do a:
    insmod smbfs.o
    check if it loaded correctly with:
    lsmod
    install samba3 it includes smbmount
    ipkg install samba
    then smbmount should work like you are used to with ubuntu
    hope i could help ya
    Thanks thejew,
    found this post also
    http://wl500g.info/showthread.php?t=...mount+smbmount
    If I install samba3 will that mean smbmount by default - e.g. no need to load this module in on post-boot?
    Jul 2007
    Austria
    Thanks -
    That is exactly what I am trying to do ( and I was enjoying using midnight commander again )
    Can you recommend a package that I could use to sync the files in both folders automatically?
    Velcrow
  1. samba and external share
    By ovidiupys in forum WL-500gP Q&A
    Last Post: 27-02-2008, 20:17
  2. Windows "size on disk" for Samba share
    By JoeW in forum WL-500g Q&A
    Last Post: 15-02-2008, 23:37
  3. samba mount crash
    By johngicu in forum WL-700g Q&A
    Last Post: 29-12-2007, 10:10
  4. Replies: 1
    Last Post: 18-05-2007, 08:30
